Re: Engine sits for about a weekrated car and got oil pressure.
[Re: Sammy]
#2751860
03/14/20 02:20 PM
03/14/20 02:20 PM
RapidRobert
if you slow the drill speed down to as best you can match the "cranking" RPM on the intergear will it prime? I'm wondering if it is bleeding off somewhere from a leak or not priming in the first place, just thinking out loud. Post what it ends up being.
[Re: RapidRobert]
#2751863
03/14/20 02:33 PM
03/14/20 02:33 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
if you slow the drill speed down to as best you can match the "cranking" RPM on the intergear will it prime? I'm wondering if it is bleeding off somewhere from a leak or not priming in the first place, just thinking out loud. Post what it ends up being. 6 seconds on the drill and it's got oil pressure.
[Re: Sammy]
#2751865
03/14/20 02:36 PM
03/14/20 02:36 PM
Posts: 3,916 usa
lewtot184
usa
Re: Engine sits for about a weekend and have no oil pressure.
[Re: Sammy]
#2751881
03/14/20 03:09 PM
03/14/20 03:09 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
It is loosing the seal between the pump and the block or somewhere else allowing the oil in the lines to drain down to the oil pan level. Look very closely at the O rings and oil line fittings and maybe even the lines to fix any problems with them Are you using the stock type oil pump gasket to the block? If so get rid of that That pump only needs the O rings on the pump body and snout to seal properly
[Re: Sammy]
#2751891
03/14/20 03:27 PM
03/14/20 03:27 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
I've had 1 small block Melling pumps pressure by-pass piston stick open and have no pressure when cold. Also an old 2.2's pump did the same. Big block would be easy to check that piston.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Cab_Burge]
#2751893
03/14/20 03:40 PM
03/14/20 03:40 PM
Posts: 4,213 New York
polyspheric
New York
X2, a pin hole will break suction.
Boffin Emeritus
[Re: AndyF]
#2751900
03/14/20 03:47 PM
03/14/20 03:47 PM
Sammy
Wind Gap,Pa.
You have an internal air leak in the pickup system. Very common problem with the old Milodon dual external setup. It is less common problem with an internal pickup but can still happen. It's the new Milodon oil pump and cover setup.
[Re: Sammy]
#2751913
03/14/20 04:20 PM
03/14/20 04:20 PM
Posts: 31,077 Oregon
AndyF
You have an internal air leak in the pickup system. Very common problem with the old Milodon dual external setup. It is less common problem with an internal pickup but can still happen. It's the new Milodon oil pump and cover setup. If it has an external line then that is usually the problem. If it is all internal then you probably have an issue with the pickup tube. Maybe a small crack in the tube or the block is cracked in the threads or something like that. Internal problems are rare but problems with the external lines are very, very common. I stopped using the external line systems because they were such a hassle.
[Re: Sammy]
#2751916
03/14/20 04:30 PM
03/14/20 04:30 PM
Posts: 3,102 Michigan
A727Tflite
And it loses prime. Can't get oil pressure started. Ran it for about 15 seconds and nothing. Had to put the priming shaft into the distributor hole and use the drill. Pressure came right up. Started right up with 72psi. 6 days later, same thing. This never happened before. What causes this to happen?And how do you fix it. Dual milodon oil lines. It's the new external Black oil pump. When did this all start ? You make no mention of that. Fresh engine build, or been on the road untouched for years or something in between?
[Re: Sammy]
#2751921
03/14/20 04:39 PM
03/14/20 04:39 PM
Posts: 34,958 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
read title ,said to myself ..bet its got "Dual milodon oil lines"
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: MichaelF]
#2751924
03/14/20 04:48 PM
03/14/20 04:48 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Did you loop the suction lines above the pump, so that there always is some oil trapped and can´t go back to the pan?
Michael Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#2751931
03/14/20 05:15 PM
03/14/20 05:15 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
When you have an air leak into the pump, the “loop” makes the situation worse. You now have longer hoses filled with more air than you would with “normal” hoses. A siphon is a siphon. Stop the air leak and you will lose the siphon. I went through a season of this with my car. Never an external leak. I had the older cast 2 piece milodon pump. At seasons end, replaced the pump gearset, all the orings, resurfaced the pump cover, and had it hard anodized. (There were some minor radial scratches in the cover) Never found a clear failed part, but doing this stopped the issue. My suspicion has been that the pump clearances, along with cover scratches, allowed air from the outlet to leak into the inlet. Just my best guess.
[Re: AndyF]
#2751935
03/14/20 05:28 PM
03/14/20 05:28 PM
Sammy
Wind Gap,Pa.
You have an internal air leak in the pickup system. Very common problem with the old Milodon dual external setup. It is less common problem with an internal pickup but can still happen. It's the new Milodon oil pump and cover setup. If it has an external line then that is usually the problem. If it is all internal then you probably have an issue with the pickup tube. Maybe a small crack in the tube or the block is cracked in the threads or something like that. Internal problems are rare but problems with the external lines are very, very common. I stopped using the external line systems because they were such a hassle. Dual external -12AN lines
