Re: Paint job on a budget!? CONTINUED
[Re: 78D150CLUB]
#27499
04/29/07 02:08 AM
04/29/07 02:08 AM
Hi, and greetings from jeepforum.com this post made its way over to us. Im going to apply the rusto technique to my 94 Jeep Wrangler in the next couple of weeks, I have some scratches and dints that will need to be banged out and the paint on my hood has just faded the PO did not take good care of her but im hoping to bring her back to a good ole shine! Just wanted to say my thanks to 69charger for sharing the 6000$ paint job secret that only costs 60$ the charger looks awesome! I'll post pics of my job after I get it completed and im going to spread the word of the rusto job.
#27501
04/29/07 08:00 AM
04/29/07 08:00 AM
Did a hood in black, it looked ok, wet sanded, and then used a polisher and polish.
The paint is really cloudy (greyish), I feel like the polish is making it even more hazy. any ideas on how to eliminate haze?
Is this something that typically shows up?
[Re: 69stanger]
#27502
04/29/07 01:44 PM
04/29/07 01:44 PM
do you stil have to thin that with sprits?? i just ordered my gallon too...
#27503
04/29/07 04:51 PM
04/29/07 04:51 PM
Try using a swirl remover instead of a polish. I have used the Poorboy's SSR3 and SSR2.5 with great results. A decent polisher like the PC 7424 with a cutting pad will also do you a world of good.
#27504
04/29/07 09:20 PM
04/29/07 09:20 PM
Posts: 13 Ohio
69stanger
Ohio
mybuick,
I haven't used it yet, still doing bodywork. In fact I'm still throwing around the idea of using the clear. All I can say is get a feel for the paint's consistency and check the label.
Freedom Of Speed!
[Re: 69stanger]
#27505
04/30/07 12:26 AM
04/30/07 12:26 AM
Well Guys I decided it wasn't very cool of me to be on here talking the talk but not having done anything to my car yet. So today I started on the body work. I got a few of the lighter dings filled and primed no problem but I worked on a couple of bigger dings and had a problem with oversanding, So I ended up with a partially filled dent. Can someone tell me the trick to knowing when its level and not over doing the sanding? Also, for those who are interested I have finally decided that it is going to be painted Black. Marq, I gave a lot of thought to your Two-tone mockup but in the end I want to just use one color and use spray bombs for my jambs and under the hood. The beauty of this method is that I can always add the grey in the future if I get gung-ho again. I also did and experiment reblacking one of my window trims that was peeling. I removed all the loose blacking with a razor blade and sanded it smooth with 80 grit then 320 and painted it with the Plasti-dip spray(rubberized coating) that someone mentioned here a few pages back. I've worked with this stuff before and the consistency of it is a lot like the backout film that was originally on those trims. Unfortunately, I am going to have to paint the car with these trims in place since they are installed under the windows and I'm not removing the windows to paint the car. Sorry for the long winded post, I have attached a pic with some of my Bondo work. If anyone wants to see that blacked out trim peice let me know and I'll put up a pic of that too.
I spoke to my boss who used to be a body man and he answered my sanding question, he said to load it up with primer and block sand it with 180 grit slowly and recoat with primer back and forth this way until I have a smooth finish. I'm gonna try this unless someone has a better idea.
[Re: Radio Joe]
#27507
04/30/07 04:09 PM
04/30/07 04:09 PM
Posted: Mon Apr 30, 2007 1:08 am Post subject: Update -------------------------------------------------------------------------------- Had a situation yesterday, that I think can attest for the toughness of the Rustoleum roller job I did a couple months ago... A friend ad I were out at his deer lease clearing some more mesquite trees. We're winding out way slowly through the pasture and coming up is a group of trees that I have pre determined which route I'm gonna take through them, plan was to take this one particular low hanging branch a little wider. Well a few deer caught our attention, and naturaly I looked and watched em bound away into the brush... all of a sudden there's this horrible scraping, screeching noise filling the cab, I had drifted right up under that branch. My first thought is "holy [Edited by Moparts - Keep it clean]!!!, way to go meat-head!!" ![](/ubbthreads/images/graemlins/thumbs.gif) I stop, we get out expecting to find it gouged down to bare metal. In case yall didn't know, mesquite is a very hard wood covered in equally hard 1,2, & 3" thorns. I hopped into the bed to inspect the cab damage, neither one of use could find so much as a scratch... just few spindly leaves and twigs in the bed. ![](/ubbthreads/images/graemlins/punkrocka.gif) Try that with a CC job
[Re: 69chargeryeehaa]
#27508
04/30/07 04:16 PM
04/30/07 04:16 PM
100k+ views
![](/ubbthreads/images/graemlins/beer.gif)
WOW i should have setup some sort of royality program with moparts!!!
MOPARTs nuthin, Rustoleum & who ever makes rollers should give you an honorary pension plan. ![](/ubbthreads/images/graemlins/bow.gif)
[Re: shawge]
#27511
04/30/07 08:21 PM
04/30/07 08:21 PM
CALLING ALL PEOPLE USING A REGULAR CRAPPY BUFFER!! LOL
im using a 6" craftsman random orbit 3600rpm buffer.. ive tried microfiber bonnets, wool, terry.. was having trouble gettin a shine, and tried a number of different polishes/cutting compounds.. i finally got some good results today, but it was after a combination of like 4 different products.. used the cheap turtle wax polishing compound, then meguiars diamond cut, then some cheap scratch/swirl remover, then wax.. and it came out pretty good... BUT for those of you using a pretty crappy buffer like me (not the baller PC7424 lol), what exactly are u using to get good results??
#27512
04/30/07 08:52 PM
04/30/07 08:52 PM
I'm using this Harbor Freight Polisher with 3m Finesse It polish and It works great. My process was 1000 grit, then 2000 then 3m with a foam pad and it comes out like a mirror (safety red paint). I will have to get pictures to post. Harbor Freight had the polisher on sale for $39. The 3m compound is expensive but I have used it before and it is about the best stuff out there. Takes about a minute to do a 2x2 section to a mirror shine.
#27513
04/30/07 09:20 PM
04/30/07 09:20 PM
I'm using this
dam 9.8 amps i think mine is like 1 amp lol matter fact it is http://www.sears.com/sr/javasr/product.d...UseBVCookie=Yes i knew i shoulda went wit the $60 craftsman one right off the bat
#27514
04/30/07 10:11 PM
04/30/07 10:11 PM
Posts: 891 wisconsin
1BAD68
wisconsin
Thanks to 1Bad68, I'm rockin a new SATIN black roller paint job.
![](http://i150.photobucket.com/albums/s97/gfeighny/P1010050.jpg)
That looks ![](/ubbthreads/images/graemlins/thumbs.gif) Flat Black is where its at!
#27515
04/30/07 10:36 PM
04/30/07 10:36 PM
Great Job.
What paint, what method?
Rustoleum, Brightside, ...Venezuelan Beaver Cheese?
Enquiring minds want to know...
#27516
04/30/07 11:24 PM
04/30/07 11:24 PM
sanded my white primer with 220, then 400. Then rolled 2 coats of satin black rustoleum, thinned about 20% with low-odor mineral spirits. I experimented with Acetone (flashes too fast), and gloss black (doesnt get hard very fast).
The Satin has gotten VERY hard in just 2 days, and the roller marks are not very visible at all. If you have ever bought a Repo part, like a fender, the paint looks alot like that satin black primer that comes on repo parts.
The Satin covers very well, I actually think it looks better in person then in the photo. Saving my money for all new chrome. When I hit the lotto I'll get a shiny paint job.
Roll on!
