Re: Vr1 racing oil
[Re: MI_Custumz]
#2750942
03/11/20 10:27 AM
03/11/20 10:27 AM
Posts: 179 California, U.S.A.
Torquemonster440
California, U.S.A.
[quote=bee1971] 3. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi zinc = 1472 ppm phos = 1544 ppm ZDDP = 1500 ppm
4. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi zinc = 1180 ppm phos = 1112 ppm ZDDP = 1100 ppm What is the source of this information and how old is it? In searching the internet for info on this oil I have seen so much conflicting data that it is no wonder people would change to Gibs. Those numbers are from 540 Rat's oil blog. It's a super long read breaking down his independent testing and evaluation of popular motor oils. I've been doing a lot of research on high ZDDP oils lately, because I'm considering installing a new solid flat tappet in my 440. I already have the cam, lifters, oil and break in lube. The oil is the Gibbs 15w-50"break in oil" but I was surprised to find it ranked pretty low on 540 Rats lubricity test. I'm considering sticking with VR1 because its ranked highy by 540 Rat as well as what I used when breaking in my current SFT cam. The new cam is a Howard's SFT .550 int/.555ex -252/260@..050 . I'll be using the "direct lube" lifters for added insurance. Still considering returning it in favor of the Trick flow HYD roller cam and lifters. But I hear horror stories about hydraulic rollers too.. ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
![Name: Screenshot_20200309-142932_Chrome.jpg
ID: 387334 Screenshot_20200309-142932_Chrome.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/387334/filename/Screenshot_20200309-142932_Chrome.jpg)
1966 Satellie.. 12.55 @107.75. 906 heads. 3780 lbs.
Re: Vr1 racing oil
[Re: BobR]
#2752243
03/15/20 05:34 PM
03/15/20 05:34 PM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
I switched from Vr1 to Lucas in my twin turbo hemi NPK car and the difference was startling. I use methanol for fuel and the Lucas resists methanol dilution a thousand times better. Of course for gasoline motors your results may vary. What was the startling difference?
Re: Vr1 racing oil
[Re: bee1971]
#2772245
05/07/20 08:48 PM
05/07/20 08:48 PM
Posts: 7,499 Minnesota
Hemi_Joel
Minnesota
I heard the synthetic costs power in big motors, so I dyno tested royal purple synthetic vs Kendall gt1 organic on a 700+/- horse Hemi. The Kendall made more horsepower. So, more power, less leaks, costs less - I'll stick with conventional. But I use Valvoline vr1 now due to availability.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Vr1 racing oil
[Re: BobR]
#2772392
05/08/20 10:25 AM
05/08/20 10:25 AM
Posts: 10,035 Frostbitefalls MN (Rocky&Bullw...
gregsdart
With VR1 I had to change the oil(actually vanilla milkshake) every 2 runs. With Lucas every 20. run that alky motor HOT and change much, much less often. I never see milky oil because by letting the temp get to 180 on launch and then 200+ on the return road all water and alky boil out of the oil.
