Hemi head gaskets Cometic vs Felpro #2750271
03/08/20 09:19 PM
03/08/20 09:19 PM
WNY
Moparrob68 Offline OP
WNY
I have a 572 World 4.50 bore aluminum Hemi with Edelbrock Victor heads and Cometic head gaskets that has a coolant leak into the valley after 2 summers of street/strip use.Tried retorqueing the head studs and it got worse.When I removed the heads the gaskets had coolant between the layers. I called Barton and he said he has seen the sleeves "settle"in aluminum blocks and allow coolant to weep up from the lower steam holes around the fire ring and down the exhaust pushrod reliefs.I measured the sleeves and they are 0.0005-0.001 below the deck. I was thinking of trying the Felpro 1104 or Edelbrock gaskets but i noticed in the picture they don't have the 2 steam holes in the outer corners.Has anyone had success using the Felpro"s
Re: Hemi head gaskets Cometic vs Felpro [Re: Moparrob68] #2750297
03/08/20 10:14 PM
03/08/20 10:14 PM
I'm thinking the sleeves on all aluminum blocks should be above(.002 to .0050 max ) the deck surfaces due to the increase height of those blocks when they get warmed up.
I would call World and ask them scope
Re: Hemi head gaskets Cometic vs Felpro [Re: Cab_Burge] #2750705
03/10/20 10:40 AM
03/10/20 10:40 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The sleeves dropping is a common problem with the world, and other aluminum blocks. Fixing that is a bunch of work, but given how little they've dropped, I'd likely just work on the gasket. Take your cometics apart by removing the rivets. Clean all three parts, then spray them all, both sides with copper coat. Let the sheets dry for a couple hours, then stack them back together on the dowels, reassemble and see if that stops it.
Re: Hemi head gaskets Cometic vs Felpro [Re: dthemi] #2750711
03/10/20 10:49 AM
03/10/20 10:49 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
In case you want to fix it. Make, or borrow a draw bar that pulls the sleeve down from the mains. While under pressure from the bar, beat the draw plate with a really heavy dead blow hammer until it would move a tenth. Measure all the sleeves to the deck, and use the lowest as your standard. Heat the block up ( I use a big kerosene torpedo heater) pull the sleeves, then deck the bare block to what you want for sleeve height.Then heat it up again, replace sleeves, let it cool, then use the draw bar and hammer again to positively seat them.
I've seen new blocks drop sleeves .01
Re: Hemi head gaskets Cometic vs Felpro [Re: Moparrob68] #2750761
03/10/20 02:21 PM
03/10/20 02:21 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I had a coolant leak on my World aluminum block as well , when using the Cometic gaskets. I found out that the World block with the three coolant holes on the bottom uses a different Cometic gasket. I switched to the correct Cometic gaskets and ended the problem. Does your block have the three holes on the bottom ? Also a smear of Hylomar around the coolant passages was applied. You can see in the picture where the standard coolant holes in the original gasket were below the bores . those are not present on the new gaskets. Also has better coverage at the main coolant passages IIRC.
The part # is H2807SP3051S for gaskets that are .051 thick and have the three large coolant holes across the bottom.
The last 3 digits determine the thickness, so 040S would be .040 thick.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Hemi head gaskets Cometic vs Felpro [Re: Hemi Allstate] #2751410
03/12/20 09:23 PM
03/12/20 09:23 PM
WNY
WNY
It looks like your World block doesn't have steam holes and my 2014 vintage one does. The C5447-040 Cometic's I was using had the 3 steam holes around the bottom of the cylinder. I am leaning toward using the Felpro 1104's with Blue Hylomar this time but they are missing the 2 outer steam holes. Was thinking of drilling the outer holes in the gaskets.Any opinions on why they left them out and if they are required.
Re: Hemi head gaskets Cometic vs Felpro [Re: Moparrob68] #2751455
03/13/20 06:59 AM
03/13/20 06:59 AM
VA
dragon slayer Offline
VA
So your gasket blocks the main water holes and only uses the small holes around the cylinders? What do the ports look like on the heads?
Re: Hemi head gaskets Cometic vs Felpro [Re: dragon slayer] #2751855
03/14/20 01:55 PM
03/14/20 01:55 PM
WNY
WNY
Edelbrock Victor Jr. heads
Re: Hemi head gaskets Cometic vs Felpro [Re: Moparrob68] #2752060
03/15/20 09:27 AM
03/15/20 09:27 AM
VA
VA
Thanks, I have a cast iron set of stock heads and they do not have those larger water holes on the bottom of the chamber. But they have the smaller holes that do not go anywhere on a stock block. Makes me wonder what the cooling strategy is on these heads. Seems like you would short circuit the coolant flow across the top of the head depending on the design of the block/head and what gasket you use.
Re: Hemi head gaskets Cometic vs Felpro [Re: Moparrob68] #2865636
12/28/20 11:48 AM
12/28/20 11:48 AM
Farnham, Quebec Canada
Erick Char Offline
Erick Char  Offline
Hi all, I am Eric and I am a new member,
I have the same leaks using the C5447-40 Cometic gaskets. I am building a 528" Hemi with the 088515 4.500" bore World aluminum block and the Edelbrock Victor heads.
It is a 2018 block and has 2 steam holes per bank, near the sleeve at cylinders 1, 2, 7 and 8. I also have the FelPro 1104 gaskets and would drill them for the steam holes.
I think they will cure the leaks but they are 0.051" thick.
Anybody has infos about the Cometic C15620-040," Chrysler Gen-2 426 Hemi .040" MLS Cylinder Head Gasket, 4.500" Bore, World Products Block" ?
Regards,
Re: Hemi head gaskets Cometic vs Felpro [Re: Erick Char] #2865715
12/28/20 02:44 PM
12/28/20 02:44 PM
moparx Offline
moparx  Offline
welcome to the board Eric ! up
my name is Eric as well. laugh2 [not sure if that is good or not ! whistling]
i can't help you with your question, but glad you are here.
beer
Re: Hemi head gaskets Cometic vs Felpro [Re: moparx] #2865741
12/28/20 03:17 PM
12/28/20 03:17 PM
Erick Char Offline
Erick Char  Offline
Yes my name is Eric too, many thanks to welcoming me! I will try to post some pictures of the engine build in a new thread.
Re: Hemi head gaskets Cometic vs Felpro [Re: Moparrob68] #2868547
01/03/21 04:49 PM
01/03/21 04:49 PM
Erick Char Offline
Erick Char  Offline
Hi again, i finally found the reason of the leak. The sleeves are supposed to be dry, not exposed to coolant.
Coolant leak from exhaust pushrod holes #4 and #8
The front steam hole of bank 2 is drilled too close to the sleeve, no more block material between them. So the pressurized coolant follow the empty spaces between the upper parts of the sleeves and block deck up to the exhaust pushrod holes where there is no aluminum wall left (cylinders 4 and 8 in my case).
So my idea is to plug these steam holes with a threaded plug or a some sort of a metal bonding. I am thinking of drilling the 2 lower steam holes of each cylinder on the block. I will update my post about my findings... Any help is welcome!
Exhaust pushrod hole #8.jpgCoolant path.jpgSteam Hole drilled next to the sleeve.jpg
Re: Hemi head gaskets Cometic vs Felpro [Re: Erick Char] #2868589
01/03/21 06:40 PM
01/03/21 06:40 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
With that hole touching the sleeve, I'd be reluctant to thread it. I'd make a press fit aluminum plug, put some locktite on it, and press it in.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi head gaskets Cometic vs Felpro [Re: Hemi_Joel] #2868760
01/04/21 08:11 AM
01/04/21 08:11 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Did you have anyone pressure check the block. If you have coolant in the valley its usually from over tightening the intake bolts on a Hemi. The bolts pull the intake straight down so it starts to lift the heads in the corners if over tightened.
Re: Hemi head gaskets Cometic vs Felpro [Re: fbs63] #2868766
01/04/21 09:26 AM
01/04/21 09:26 AM
Erick Char Offline
Erick Char  Offline
Hi and thanks for the replies.
There is no intake manifold installed, just a Torque Plate and a 1104 FelPro gasket. The block was pressurized with the AR engineering tool, no leaks on Bank 1 with 20 psi with the head. On Bank 2, there is a leak with less than 10 psi applied,
with the cylinder head or torque plate on, Felpro or Cometic Gasket and sealant around the coolant holes.
Re: Hemi head gaskets Cometic vs Felpro [Re: dthemi] #2868802
01/04/21 11:36 AM
01/04/21 11:36 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Maybe I'm misunderstanding the procedure but what prevents the sleeves from moving downward again?
Re: Hemi head gaskets Cometic vs Felpro [Re: 6PakBee] #2868901
01/04/21 03:25 PM
01/04/21 03:25 PM
The bottom of the sleeve should be seated against the machine lip in the block for the sleeve to sit and seal against scope
Re: Hemi head gaskets Cometic vs Felpro [Re: Moparrob68] #3018479
02/24/22 02:13 PM
02/24/22 02:13 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Enjoyed this older thread just for education purposes.
Never know, might get one of those blocks someday.
Hasn't really been any closure, though.
So I'm going to ask...how have you guys repaired this?
I'm thinking maybe lightly press in a plug with a smaller steam hole drilled off center to get it away from the sleeve, or thread the hole and install a homemade "jet" with a similar hole, or something like that.
Rich H.
Esse Quam Videri
Re: Hemi head gaskets Cometic vs Felpro [Re: ZIPPY] #3018564
02/24/22 05:08 PM
02/24/22 05:08 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Maybe he will chime in, but its still sitting in his garage in pieces last I saw it around the holidays.
