70-2 A Body V8 K Frame ID #2750227
03/08/20 06:42 PM
03/08/20 06:42 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Can someone tell me if this is a correct V8 (340) K frame for a 70-2 A Body? I don't see any holes for the sway bar mounts.Thanks for any info
Re: 70-2 A Body V8 K Frame ID [Re: 44D6PAKCUDA] #2750233
03/08/20 07:09 PM
03/08/20 07:09 PM
FL
moparwizard Offline
moparwizard  Offline
FL
340 A body k frames have a washer welded on the front for Identification and should have holes drilled for sway bar mounts.
Re: 70-2 A Body V8 K Frame ID [Re: moparwizard] #2750234
03/08/20 07:13 PM
03/08/20 07:13 PM
I knew about the washer ID,but being this is a NOS frame,I thought maybe they didn't put it on.But then the missing sway bar bracket holes.Wasn't the one motor mount or steering box mount reinforced on a 340 frames also? Just wondering if this frame could be "completed" to make it a 340 frame
Re: 70-2 A Body V8 K Frame ID [Re: 44D6PAKCUDA] #2750241
03/08/20 07:27 PM
03/08/20 07:27 PM
FL
moparwizard Offline
moparwizard  Offline
FL
If you want I can get some better pics of the mount and steering box area tomorrow. I'm not seeing a steering box mount on your K frame?
Re: 70-2 A Body V8 K Frame ID [Re: moparwizard] #2750272
03/08/20 09:19 PM
03/08/20 09:19 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is one strange looking k-frame, did you get a part number with it?
JB Rhinehart, Realist
A-Body's RULE!
Re: 70-2 A Body V8 K Frame ID [Re: Rhinodart] #2750333
03/09/20 06:08 AM
03/09/20 06:08 AM
I did not Jim.But after not seeing the reinforcements and the washer ID,I will be passing
