Re: Any insulation pros out there
[Re: skicker]
#2749043
03/04/20 08:29 PM
03/04/20 08:29 PM
Superfreak
Superfreak
We use R40 in attics around here.
[Re: srt]
#2749120
03/04/20 11:59 PM
03/04/20 11:59 PM
Superfreak
Superfreak
The higher R value is also better for keeping heat out during the summer. Insulation is one area you don't want to skimp out on. Also, don't buy from the big box stores as the price is way higher.
[Re: carhunter]
#2749185
03/05/20 09:38 AM
03/05/20 09:38 AM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I want to insulate my 2 1/2 car garage attic,the only thing is the ceiling drywall is nailed to 2x4's.I want to put a r-38 up there.I know it will be above the 2x4's but I won't be putting any thing up there to compact the insulation.Would that be ok,if not any suggestions.I do live in the south so winters are very mild. Yes, that would be absolutely OK. The R-38 will insulate the space below the sheetrock ceiling. You won't be compacting your insulation, which is important to retain the R-38 rating. How is the air above the insulation ventilated? Are there soffit and eave or ridge vents? If not, you might want to put some ventilation (fans or vents) to circulate the air and reduce moisture in the air above the insulation. Cheers, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
