Any insulation pros out there #2749017
03/04/20 06:48 PM
03/04/20 06:48 PM
South Carolina
carhunter Offline OP
South Carolina
I want to insulate my 2 1/2 car garage attic,the only thing is the ceiling drywall is nailed to 2x4's.I want to put a r-38 up there.I know it will be above the 2x4's but I won't be putting any thing up there to compact the insulation.Would that be ok,if not any suggestions.I do live in the south so winters are very mild.
Re: Any insulation pros out there [Re: carhunter] #2749027
03/04/20 07:40 PM
03/04/20 07:40 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
why nit put in r11 paperback toward the interior and then overlay with r19 unbacked laid perpendicular to the joists/trusses?
Re: Any insulation pros out there [Re: srt] #2749032
03/04/20 07:52 PM
03/04/20 07:52 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
If you have a completed ceiling already that has an access blow the Owens Corning product in it.
The above mentioned R-11 with R-19 on top works but is a major PITA to install...
When your done you've done twice the labor and still only have an R-30...
Using the blown in you can install as much or as little as you want without all of the crawling around on top of the truss's... twocents
https://www.lowes.com/pd/Owens-Corning-AttiCat-R-19-Blown-In-Insulation-Sound-Barrier/50370322
...FAFO...
Re: Any insulation pros out there [Re: skicker] #2749043
03/04/20 08:29 PM
03/04/20 08:29 PM
Superfreak
Superfreak
We use R40 in attics around here.
Re: Any insulation pros out there [Re: skicker] #2749104
03/04/20 11:09 PM
03/04/20 11:09 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I'd think in the south with the mentioned mild winters R 30 would be fine. Also believe that with the humid summers it'd be nice to have a more compact blanket. Surely shy away from cellulose products. I've had both in my homes and actually talked with an insulation contractor (40+ yrs exp). He prefers batts. He claims over time the blown in stuff compacts and only more can be added. Once crushed down the insulating factor goes down and difficult to add vapor barrier on bottom unless new const.
fwiw, use roll r11, and use the stud cavity (cut segments) for the transverse lays to cut down installation time.
Lastly I priced out buying insulation and for just a little more than my price he provides and installs. Benefit of buying truckloads of the stuff.
Re: Any insulation pros out there [Re: srt] #2749120
03/04/20 11:59 PM
03/04/20 11:59 PM
Superfreak
Superfreak
The higher R value is also better for keeping heat out during the summer. Insulation is one area you don't want to skimp out on. Also, don't buy
from the big box stores as the price is way higher.
Re: Any insulation pros out there [Re: carhunter] #2749185
03/05/20 09:38 AM
03/05/20 09:38 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Yes, that would be absolutely OK. The R-38 will insulate the space below the sheetrock ceiling. You won't be compacting your insulation, which is important to retain the R-38 rating. How is the air above the insulation ventilated? Are there soffit and eave or ridge vents? If not, you might want to put some ventilation (fans or vents) to circulate the air and reduce moisture in the air above the insulation.
Cheers,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Any insulation pros out there [Re: 67SATisfaction] #2749296
03/05/20 03:06 PM
03/05/20 03:06 PM
South Carolina
South Carolina
Thanks for all the advice.I'm still deciding which way to go now.
