Motor sealing tricks for making vacuum in the crankcase?
#2747413
02/28/20 03:22 PM
02/28/20 03:22 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I'm having issues on my bracket motors (Two) getting above 5.0 inches of vacuum with a big GZ vacuum pump ![help help](/ubbthreads/images/graemlins/custom/smilie_help.gif) The current motor is better than the one before it but not any where near 10+ inches, any things I should look for? I bought the pump used several years ago and sent it back to GZ for repair or rebuilding as needed, they called yesterday and said it tested good ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) The current motor has a early Hamburger SS oil pan with the lower kick out in it with the drag link hole removed and covered up for more volume at a lower level. I put 11 quarts in it to get it on the tip of dip stick. I'm sure it has a tiny pin hole in it some where as it will weep, seep, some oil onto the pan when it sits all winter, no weeping or seeping during the race season though ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
Re: Motor sealing tricks for making vacuum in the crankcase?
[Re: HardcoreB]
#2747423
02/28/20 03:42 PM
02/28/20 03:42 PM
Posts: 4,291 Morrow, OH
markz528
Morrow, OH
So the way that I found my leak points was with a UE2000 ultrasonic leak detector. I borrowed it from work.
What I ultimately found was that I had a bad seal in the Indy valley tray. The vacuum pump had sucked in a portion of the RTV sealing the valley tray. Actually happened twice and I missed it with a visual inspection.
[Re: Cab_Burge]
#2747506
02/28/20 07:44 PM
02/28/20 07:44 PM
Posts: 716 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
before i had a large electric vacuum pump, I had a old 1/4hp electric motor that used a long belt to drive the vacuum pump. I prefer to pull a vacuum to find a vacuum leak because i once had a relief valve that sealed great under pressure but would open up at 4in of vacuum. The owner said it was all sealed up because he had pressurized it and it didn't leak. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Joe
Without Data, you’re just another guy with an opinion.
[Re: dvw]
#2747537
02/28/20 08:56 PM
02/28/20 08:56 PM
Posts: 2,685 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Ray Barton told me to silicone the harmonic balancer keyway.
2011 Drag Pak Challenger
[Re: Cab_Burge]
#2747547
02/28/20 09:18 PM
02/28/20 09:18 PM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
Make sure the valve covers and any oil fillers are sealed with an o ring.
Mike
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
[Re: rickseeman]
#2747548
02/28/20 09:18 PM
02/28/20 09:18 PM
hustlin hoosier
If you look at some of the old pictures of our engines built by best , you will see toe clamps from the head to the valley cover along each side. We had no luck until then . We even built 1/2 inch thick billet valley covers with no success. Pressurizing is a waste of time as the forces are reversed.
[Re: hustlin hoosier]
#2747568
02/28/20 10:08 PM
02/28/20 10:08 PM
Posts: 2,527 PA
moparacer
PA
I do nothing special to my engines at all and pull 12 inches with the Star Standard pump. Mine Idles at 5 on alky.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#2747573
02/28/20 10:30 PM
02/28/20 10:30 PM
Posts: 11,738 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Leak test? Anyone use a smoke machine?
[Re: CMcAllister]
#2747648
02/29/20 07:35 AM
02/29/20 07:35 AM
Posts: 9,883 MI, usa
dvw
MI, usa
Smoke machine will work. The air test with soapy water works excellent. The only thing it may miss is if a shaft seal is being pulled back away under vacuum. Doug
[Re: fbs63]
#2748629
03/03/20 03:31 PM
03/03/20 03:31 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
I smoked mine a couple of years ago and the smoke was pouring out of the rear main seal area. I took it apart and attempted to reseal it. It is better but I can still not make any vacuum. I have the star set up. I eventually removed it and put the pan evacs back on. I was sick of it blowing oil out of their fancy $400.00 catch can!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
