Mopar techs, question on wire connector tool #2747231
02/27/20 10:29 PM
02/27/20 10:29 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Trying to find the correct tool to remove wires from the connectors of a 2011 Chrysler Town & Country rear lift gate power module. Working with the 12 way and 22 way connector. I have wires that have corroded off right at the back side of the plugs. Haven't been able to find any info on the tool or replacement terminals. Chrysler dealers claim they have no tool number listed.
Thanks!
Re: Mopar techs, question on wire connector tool [Re: mopar4ya] #2747241
02/27/20 10:55 PM
02/27/20 10:55 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You need a pin tool kit. There are ways to make your own but kits like this are very helpful.tool
Re: Mopar techs, question on wire connector tool [Re: NITROUSN] #2747330
02/28/20 11:21 AM
02/28/20 11:21 AM
moparx Offline
moparx  Offline
i use those pin tools like you show in the link frequently, just because of the way the door/gate wiring is designed allows for breakage and corrosion to be common place.
the connectors shown may be deutche connectors ? i can't really see the pic that good.
beer
Re: Mopar techs, question on wire connector tool [Re: NITROUSN] #2747525
02/28/20 08:22 PM
02/28/20 08:22 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Yep, looks like something I could use. Bad thing is by the time I figure out which one is the correct tool, probably have the connector body ruined ! lol !!
Re: Mopar techs, question on wire connector tool [Re: mopar4ya] #2747545
02/28/20 09:09 PM
02/28/20 09:09 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I did a fix on the Ram headlight issue on a 1998.
Did each wire separately... a pain but it worked. The factory recall fix was no better than the original
Re: Mopar techs, question on wire connector tool [Re: mopar4ya] #2747726
02/29/20 12:58 PM
02/29/20 12:58 PM
None
71rm23 Offline
71rm23  Offline
None
You need something like this. They slide into the cavity, releasing them from inside so you can pull them out. Yes, I'm pretty sure the terminals are the Deustch(?)
https://www.amazon.com/MENKEY-Termi...oval+tools&qid=1582995398&sr=8-1
https://www.amazon.com/s?k=eletrical+removal+tools&ref=nb_sb_noss
Re: Mopar techs, question on wire connector tool [Re: 71rm23] #2747908
02/29/20 11:22 PM
02/29/20 11:22 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Thanks, have a kit on the way. Would be nice if they supplied a manual on what tools work with each type of connector. I know some are pretty straight forward, but others, not so much. After you figure out the correct tool for the pin and see how it releases, it's pretty easy to take them apart. But trying to get that first one not knowing how it releases makes them a beeotch !
