hellcat brass monkey wheels? #2746190
02/24/20 07:33 PM
02/24/20 07:33 PM
new berlin wisconsin
Mr T2U Offline OP
Mr T2U  Offline OP
does anybody have a paint code for the hellcat brass monkey wheels or a line on how to get one?
perception is 90% of reality
Re: hellcat brass monkey wheels? [Re: Mr T2U] #2746319
02/25/20 06:26 AM
02/25/20 06:26 AM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
Re: hellcat brass monkey wheels? [Re: moparmike1] #2746333
02/25/20 08:22 AM
02/25/20 08:22 AM
Mr T2U Offline OP
Mr T2U  Offline OP
THANK YOU. i will mix up a small batch today and see if i like it. maybe i might have a color variance chip and look at that.
from reading the thread it seems like the color is better over black so i will try different undercoats to see what that does to the color.
Re: hellcat brass monkey wheels? [Re: Mr T2U] #2746351
02/25/20 10:16 AM
02/25/20 10:16 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Brass Monkey...as in "Its colder than a well digger's brass monkey"?
Re: hellcat brass monkey wheels? [Re: TC@HP2] #2746379
02/25/20 12:07 PM
02/25/20 12:07 PM
Buckeye Lake
56_Royal_Lancer Offline
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
This is great info...*right click, save*
Thanks for posting
Re: hellcat brass monkey wheels? [Re: 56_Royal_Lancer] #2746470
02/25/20 04:29 PM
02/25/20 04:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I like that color a lot more than the done-to-death black wheels...
Re: hellcat brass monkey wheels? [Re: topside] #2746507
02/25/20 07:06 PM
02/25/20 07:06 PM
Mr T2U Offline OP
Mr T2U  Offline OP
this is why i am asking. everywhere you look their are black or some shade of gray wheels.
the wheel manufacturer that made my lightweight flow formed wheels just started selling similar colored wheels for extra $$ over the usual gray or black. i would like something a little different without breaking the bank.
i found a color variance chip of the color today. to me it seemed a little dark, maybe i will try spraying it over a white, gray, and black and see what i like best. with the PPG water based basecoat we use in our shop this makes a difference. i think it will look much better with a flattened clear over the full gloss the paint chip had..
Re: hellcat brass monkey wheels? [Re: Mr T2U] #2746520
02/25/20 08:00 PM
02/25/20 08:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You might also try silver or gold under-coat depending on what effect you want.
Look up Toyota code 4T3 - mostly seen on trucks - might be darker than you like.
Re: hellcat brass monkey wheels? [Re: TC@HP2] #2746529
02/25/20 08:33 PM
02/25/20 08:33 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
As in "it's cold enough to freeze the balls off a brass monkey."
Re: hellcat brass monkey wheels? [Re: Sunroofcuda] #2746558
02/25/20 10:15 PM
02/25/20 10:15 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Those SURE are some nice looking wheels !
Re: hellcat brass monkey wheels? [Re: dOc !] #2747033
02/27/20 12:10 PM
02/27/20 12:10 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Brass Monkey--that funky monkey!!!
As any street-wise booze connoisseur will tell you, a true Brass Monkey consists of two simple ingredients: malt liquor (the cheaper, the better!) and orange juice. So, what'cha want is a Brass Monkey? Here's how to make one:
1. Take a forty-ounce bottle of malt liquor (Olde English seems to be the preferred brand) and remove approximately one-fourth of the contents--down to the top of the Olde English label is a good point of reference. Normally, you're supposed to drink it (this may be the hardest part, as straight-up malt liquor is pretty potent and nasty stuff), but in this case we think it's certainly acceptable to pour it out, in tribute to our fallen comrade Yauch.
2. Refill the missing malt liquor with the O.J. (Sunny Delight will work as well), screw the cap back on and then tip that sucker upside-down so the brew and juice mix up all nice and good. Do this slowly -- you don't want it to foam.
3. Drink up! And you may want to do it somewhat quickly, as forty ounces of beverage is a lot to drink and it gets warm -- and more disgusting the warmer it gets. Don't worry, though -- since you are drinking in honor of Yauch, you can always tip out the end of it in tribute.
Read More: How to Make a Brass Monkey | https://diffuser.fm/how-to-make-a-brass-monkey/?utm_source=tsmclip&utm_medium=referral
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
