Re: Help with Ignition Timing- Prestolite Dual Point Distributor [Re: NITROUSN] #2746378
02/25/20 12:05 PM
02/25/20 12:05 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
I'm using Sunoco 93 which is the highest octane available where I live. Compression is 10.25 to 1. I'll try backing off initial timing and see what happens. I'll also try to locate a dwell meter and verify settings.
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Help with Ignition Timing- Prestolite Dual Point Distributor [Re: RSI700VIPER] #2746398
02/25/20 12:55 PM
02/25/20 12:55 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
it's fairly easy to measure how many degrees are in the distributor by measuring the length of the cam slot, minus the pin diameter and dividing by .015.
Re: Help with Ignition Timing- Prestolite Dual Point Distributor [Re: RSI700VIPER] #2746416
02/25/20 01:40 PM
02/25/20 01:40 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Start with the intial at 5* at whatever rpm the FSM says.
If you plot out the timing specs that DragonSlayer has kindly provided, you'll see how sensitive the timing curve is to the initial setting.
It's a very rise in the advance off of idle.
Also an older distributor its more likely the primary spring has a stretched a little. If you find the advance is starting at a lower rpm than is acceptable, put a little more tension on the primary spring. Test and measure first.
If you don't have the service manual, this will at least get you most of it.
http://www.mymopar.com/index.php?pid=109
Should cover setting for dual points. There also may be a Tech tip on it.
Re: Help with Ignition Timing- Prestolite Dual Point Distributor [Re: Mattax] #2746448
02/25/20 02:49 PM
02/25/20 02:49 PM
VA
dragon slayer Offline
VA
you can probably score a basic dwell meter pretty cheap. It is important because it tells you how long contacts are closed for charging coil. Point gap can be correct, but if the cam is worn or even the point block your dwell will be off.
Re: Help with Ignition Timing- Prestolite Dual Point Distributor [Re: dragon slayer] #2746912
02/26/20 10:54 PM
02/26/20 10:54 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I suspect a worn cam (the one in the distributor) like I said above. On my buddy's 340 we swapped a cam from a different distributor and the problem went away. That's why you need a dwell meter or swap the cam with one another distributor.
