Vac-u-pan effectiveness #2745638
02/22/20 10:36 PM
02/22/20 10:36 PM
A727Tflite Offline OP
Anyone have any data on what crankcase vacuum they get with a vac-u-pan at 7000-7500 ?
Any data on loss of power by disconnecting the system?
1/16” ring line up with low tension oil ring.
Re: Vac-u-pan effectiveness [Re: A727Tflite] #2745668
02/23/20 03:15 AM
02/23/20 03:15 AM
I've heard some say they are good and some say no good confused
I tried a Moroso set up one summer, the only thing I saw was more moisture in the valve covers when I removed them to check the lash down
Vacuum in the crank case can help stop tiny leaks and make power above 6000 RPM on a several good engine dyno tests that I know of up
The more crankcase vacuum the better the power gains above 6000 RPM work
Re: Vac-u-pan effectiveness [Re: Cab_Burge] #2745684
02/23/20 09:34 AM
02/23/20 09:34 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I've never got those to work but other people have. All I ever got was exhaust pressure in the crankcase. (I know that doesn't make sense but that's my experience.)
2011 Drag Pak Challenger
Re: Vac-u-pan effectiveness [Re: rickseeman] #2745685
02/23/20 09:40 AM
02/23/20 09:40 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Are you sure your entry into the exhaust is correctly shaped?
Boffin Emeritus
Re: Vac-u-pan effectiveness [Re: A727Tflite] #2745721
02/23/20 11:35 AM
02/23/20 11:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
They do work but the vac is low(about 3" to 5" vac).. if running a full exhaust you have to check the back
pressure
wave
Re: Vac-u-pan effectiveness [Re: rickseeman] #2745767
02/23/20 02:21 PM
02/23/20 02:21 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Boffin Emeritus
Re: Vac-u-pan effectiveness [Re: MR_P_BODY] #2745769
02/23/20 02:26 PM
02/23/20 02:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd agree the pan-evac effect is weak at lower RPM based on my own experience, but an exhaust past the collectors could be a factor.
Briefly, installed a fresh engine that included a low-tension setup, otherwise very similar to the previous unit (cam, heads, intake, + 1.0 CR).
Has a huge, deep pan, mesh tray, 10-W30 oil well away from crank.
Had previously added 3.5" X-pipe & Race Bullets, ending @ rear axle. Had pan-evac with proper 1-way valves & angled suction @ collectors.
New motor would smoke a bit through the exhaust in the lanes & such, 1500-2000-ish RPM range. Would clear up downtrack. Shift points 7500.
Changed to an electric GM vac pump & puke tank, no smoke. Checked vacuum via fitting in opposite VC, 5" vacuum.
Re: Vac-u-pan effectiveness [Re: A727Tflite] #2745807
02/23/20 04:50 PM
02/23/20 04:50 PM
New York
polyspheric Offline
polyspheric  Offline
New York
What I showed is the easiest to construct and install. If you have a detachable section of collector, a better method (higher vacuum, some vacuum at lower RPM) is to make the insert a cone parallel to the exhaust flow, with the wide open end facing downstream. It's going to get really hot, so choose your material carefully.
Boffin Emeritus
Re: Vac-u-pan effectiveness [Re: polyspheric] #2745818
02/23/20 05:40 PM
02/23/20 05:40 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by polyspheric
I always used nipples with the whistle cut - as supplied from Moroso - and installed them with the end cut parallel to exhaust flow - i.e. turned 180 degrees from your illustration - and deep enough to get the whistle cut well into the flow.
Never checked vacuum but they worked well I thought. Could free rev the engine and feel the pull on the hose. Cleaned up the moisture in the valve covers after the engine warmed up. Had to keep an eye on the check valves. They would fail fairly regularly and need to be replaced.
The addition of mufflers - even just the collector style - substantially reduced the effectiveness of the system.
Re: Vac-u-pan effectiveness [Re: A727Tflite] #2745839
02/23/20 06:51 PM
02/23/20 06:51 PM
AndyF Online content
AndyF  Online Content
Data logger and a pressure sensor will tell you for sure. I don't think that old school setup is very effective but it is probably better than nothing. You don't see any high dollar guys running that setup anymore. Even bracket racers run vacuum pumps these days.
Re: Vac-u-pan effectiveness [Re: AndyF] #2745855
02/23/20 07:55 PM
02/23/20 07:55 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Vacuum pump is the better (more expensive) option. Vac-u-pan is better than nothing with rags wrapped around the breathers.
Re: Vac-u-pan effectiveness [Re: CMcAllister] #2746053
02/24/20 11:46 AM
02/24/20 11:46 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
ON MY SONS MAGNUM, HE SEING ABOUT .5 TO A HAIR UNDER 1" AT IDLE. SEES 5-6" ON THE HIGHWAY OR GOING THRU THE FINISH LINE
THE KEY IS HE WELDED BUNGS ON HIS VAVLE COVERS AND EVERTHIS IS AN LINE. NO RUBBER GROMMETS ETC THAT CAN LEAK. WORKS BETTER THAN I THOUGHT IT WOULD
....BAD A$$ STREET CAR.....
Re: Vac-u-pan effectiveness [Re: n20mstr] #2746098
02/24/20 02:25 PM
02/24/20 02:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Sealing the engine helps. Including removing the dipstick, tapping and plugging the hole. No vents.
Re: Vac-u-pan effectiveness [Re: CMcAllister] #2746742
02/26/20 03:05 PM
02/26/20 03:05 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I put one on my e/sa 340 Duster years ago. My car was scienced out completely so I know if something I tried worked. It was worth ZERO.
Re: Vac-u-pan effectiveness [Re: A727Tflite] #2746865
02/26/20 08:52 PM
02/26/20 08:52 PM
New York
polyspheric Offline
polyspheric  Offline
New York
There are 2 variables not considered which make the conditions you want to fix: high crankcase pressure producing blowby.
1. what is the original crankcase volume in inches?
the empty space in the oil pan, but above the oil level
the empty space surrounding the crankshaft
the empty space inside the bores below the pistons (including the pistons’ interiors)
The engine’s total internal volume also includes the empty space inside the valve covers and under the valley cover
2. how much larger displacement is the actual engine than the smallest original version (for a 340: 273", for a 400 B: 350", etc.)?
This is why a stroker 400 has more problems than the same size 440: higher pressure and higher pressure cycling due to a smaller container.
This is another advantage to a deep pan: the extra air volume buffers the pressure cycles.
Boffin Emeritus
Re: Vac-u-pan effectiveness [Re: polyspheric] #2747108
02/27/20 02:51 PM
02/27/20 02:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Sometimes we just do what is helpful and/or cost effective. Maybe not the optimum solution or technique, but helpful.
Is a vac-u-pan system helpful in relieving pressure in the crankcase and maybe even pulling a negative pressure? Yes. Is it better than a simple pair of breathers in the valve covers? Yes. Is it the best solution? No. Is it a fix for leaking rings? No. Is it much cheaper and easier than a vacuum pump system? Yes. Does it have any negative side effects if properly installed and maintained? No. Easy decision.
Re: Vac-u-pan effectiveness [Re: CMcAllister] #2747172
02/27/20 06:48 PM
02/27/20 06:48 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Especially since it does not compromise future mods or limit engine strategy.
Boffin Emeritus
Re: Vac-u-pan effectiveness [Re: polyspheric] #2747297
02/28/20 09:19 AM
02/28/20 09:19 AM
Johnstown
69dart Offline
69dart  Offline
Johnstown
My car blows the one way valves out in the headers at least once a year. I always carry 2 spares. Engine braking in the shutdown just blows the plastic out.
Its annoying - I'm thinking of switching to the gm air pump For Chevy Express 1500 00-02 GM Original Equipment Secondary Air Injection Pump.
I dont think I have room for a dry sump and just need a little vacuum on my little 383.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Vac-u-pan effectiveness [Re: 69dart] #2747341
02/28/20 11:49 AM
02/28/20 11:49 AM
Washington
madscientist Offline
Washington
Do you have the pan evac before or after the muffler?
Re: Vac-u-pan effectiveness [Re: 69dart] #2747397
02/28/20 02:36 PM
02/28/20 02:36 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Will an electric do the trick ? Anybody have any real life experience. I don’t have space for mechanical .
