Re: Vac-u-pan effectiveness
[Re: A727Tflite]
#2745668
02/23/20 03:15 AM
02/23/20 03:15 AM
Posts: 43,251 Bend,OR USA
Cab_Burge
I've heard some say they are good and some say no good I tried a Moroso set up one summer, the only thing I saw was more moisture in the valve covers when I removed them to check the lash Vacuum in the crank case can help stop tiny leaks and make power above 6000 RPM on a several good engine dyno tests that I know of The more crankcase vacuum the better the power gains above 6000 RPM
[Re: Cab_Burge]
#2745684
02/23/20 09:34 AM
02/23/20 09:34 AM
Posts: 2,666 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I've never got those to work but other people have. All I ever got was exhaust pressure in the crankcase. (I know that doesn't make sense but that's my experience.)
2011 Drag Pak Challenger
[Re: rickseeman]
#2745685
02/23/20 09:40 AM
02/23/20 09:40 AM
Posts: 4,209 New York
polyspheric
New York
Are you sure your entry into the exhaust is correctly shaped?
Boffin Emeritus
[Re: MR_P_BODY]
#2745769
02/23/20 02:26 PM
02/23/20 02:26 PM
Posts: 20,841 A collage of whims
topside
A collage of whims
I'd agree the pan-evac effect is weak at lower RPM based on my own experience, but an exhaust past the collectors could be a factor. Briefly, installed a fresh engine that included a low-tension setup, otherwise very similar to the previous unit (cam, heads, intake, + 1.0 CR). Has a huge, deep pan, mesh tray, 10-W30 oil well away from crank. Had previously added 3.5" X-pipe & Race Bullets, ending @ rear axle. Had pan-evac with proper 1-way valves & angled suction @ collectors. New motor would smoke a bit through the exhaust in the lanes & such, 1500-2000-ish RPM range. Would clear up downtrack. Shift points 7500. Changed to an electric GM vac pump & puke tank, no smoke. Checked vacuum via fitting in opposite VC, 5" vacuum.
[Re: A727Tflite]
#2745807
02/23/20 04:50 PM
02/23/20 04:50 PM
polyspheric
New York
What I showed is the easiest to construct and install. If you have a detachable section of collector, a better method (higher vacuum, some vacuum at lower RPM) is to make the insert a cone parallel to the exhaust flow, with the wide open end facing downstream. It's going to get really hot, so choose your material carefully.
Boffin Emeritus
[Re: polyspheric]
#2745818
02/23/20 05:40 PM
02/23/20 05:40 PM
Posts: 11,638 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I always used nipples with the whistle cut - as supplied from Moroso - and installed them with the end cut parallel to exhaust flow - i.e. turned 180 degrees from your illustration - and deep enough to get the whistle cut well into the flow. Never checked vacuum but they worked well I thought. Could free rev the engine and feel the pull on the hose. Cleaned up the moisture in the valve covers after the engine warmed up. Had to keep an eye on the check valves. They would fail fairly regularly and need to be replaced. The addition of mufflers - even just the collector style - substantially reduced the effectiveness of the system.
[Re: AndyF]
#2745855
02/23/20 07:55 PM
02/23/20 07:55 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Vacuum pump is the better (more expensive) option. Vac-u-pan is better than nothing with rags wrapped around the breathers.
[Re: CMcAllister]
#2746053
02/24/20 11:46 AM
02/24/20 11:46 AM
Posts: 4,689 On the parachute mount
n20mstr
ON MY SONS MAGNUM, HE SEING ABOUT .5 TO A HAIR UNDER 1" AT IDLE. SEES 5-6" ON THE HIGHWAY OR GOING THRU THE FINISH LINE
THE KEY IS HE WELDED BUNGS ON HIS VAVLE COVERS AND EVERTHIS IS AN LINE. NO RUBBER GROMMETS ETC THAT CAN LEAK. WORKS BETTER THAN I THOUGHT IT WOULD
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2746098
02/24/20 02:25 PM
02/24/20 02:25 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Sealing the engine helps. Including removing the dipstick, tapping and plugging the hole. No vents.
[Re: A727Tflite]
#2746865
02/26/20 08:52 PM
02/26/20 08:52 PM
polyspheric
New York
There are 2 variables not considered which make the conditions you want to fix: high crankcase pressure producing blowby. 1. what is the original crankcase volume in inches? the empty space in the oil pan, but above the oil level the empty space surrounding the crankshaft the empty space inside the bores below the pistons (including the pistons’ interiors) The engine’s total internal volume also includes the empty space inside the valve covers and under the valley cover 2. how much larger displacement is the actual engine than the smallest original version (for a 340: 273", for a 400 B: 350", etc.)?
This is why a stroker 400 has more problems than the same size 440: higher pressure and higher pressure cycling due to a smaller container.
This is another advantage to a deep pan: the extra air volume buffers the pressure cycles.
Boffin Emeritus
[Re: polyspheric]
#2747108
02/27/20 02:51 PM
02/27/20 02:51 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Sometimes we just do what is helpful and/or cost effective. Maybe not the optimum solution or technique, but helpful.
Is a vac-u-pan system helpful in relieving pressure in the crankcase and maybe even pulling a negative pressure? Yes. Is it better than a simple pair of breathers in the valve covers? Yes. Is it the best solution? No. Is it a fix for leaking rings? No. Is it much cheaper and easier than a vacuum pump system? Yes. Does it have any negative side effects if properly installed and maintained? No. Easy decision.
[Re: CMcAllister]
#2747172
02/27/20 06:48 PM
02/27/20 06:48 PM
polyspheric
New York
Especially since it does not compromise future mods or limit engine strategy.
Boffin Emeritus
[Re: 69dart]
#2747341
02/28/20 11:49 AM
02/28/20 11:49 AM
Posts: 4,457 Washington
madscientist
Washington
Do you have the pan evac before or after the muffler?
[Re: 69dart]
#2747397
02/28/20 02:36 PM
02/28/20 02:36 PM
Posts: 630 Ct
Wirenut
Ct
My car blows the one way valves out in the headers at least once a year. I always carry 2 spares. Engine braking in the shutdown just blows the plastic out.
Its annoying - I'm thinking of switching to the gm air pump For Chevy Express 1500 00-02 GM Original Equipment Secondary Air Injection Pump.
I dont think I have room for a dry sump and just need a little vacuum on my little 383. Will an electric do the trick ? Anybody have any real life experience. I don’t have space for mechanical . G
