Re: R3 50mm can tunnel
[Re: tuff440]
#2745143
02/21/20 10:37 AM
02/21/20 10:37 AM
fast68plymouth
So. Burlington, Vt.
Just measure one of the cam bores...... that’ll tell you which cam bearings it takes.
Seems like there were a lot of different cam bearing options for those blocks.
[Re: tuff440]
#2745297
02/21/20 08:01 PM
02/21/20 08:01 PM
fast68plymouth
So. Burlington, Vt.
I seem to think there are 50mm babbit and roller options. As well as 55 and 60, if theres enough meat in the cam tunnel.
There cam be issues with lifter oiling when the cam cores get bigger.
[Re: fast68plymouth]
#2745877
02/23/20 09:04 PM
02/23/20 09:04 PM
Posts: 6,149 Melbourne , Australia
LA360
All 50mm cam tunnel R3 blocks were for roller bearings, from memory there is a durabond babbit bearing for a 55mm camshaft that fits the tunnel. There was an odd babbit size (largest cam journal on a factory camshaft, 1.998" I think), but I think they were the earlier R1 or R2 stuff
Alan Jones
