Re: Mega Block Questions
[Re: sr4440]
#2745053
02/20/20 09:38 PM
02/20/20 09:38 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
here's a bulldog "B" block that was cast last month. WOW!! They do exist! Are all 5 mains cross bolted? Looks comparable to mega blocks and world blocks. How long did it take to get it and approx price range? Thanks for sharing, Brian
[Re: sr4440]
#2745083
02/20/20 11:25 PM
02/20/20 11:25 PM
Posts: 1,229 In The Hills
jughed
In The Hills
It's nice to know that low deck blocks are available. thanks for the pics!!
[Re: sr4440]
#2745286
02/21/20 06:42 PM
02/21/20 06:42 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
What’s with the raised area on the upper timing gear thrust surface on the BD block?
[Re: fast68plymouth]
#2745306
02/21/20 08:42 PM
02/21/20 08:42 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
What’s with the raised area on the upper timing gear thrust surface on the BD block? it's not raised, it is flush with the timing chain cover, same as a stock block. But it is a little narrower, i believe that is because it's been drilled for a 60/55 MM cam. I sure if you ran a stock cam size it would look "normal". Joe
Without Data, you’re just another guy with an opinion.
[Re: '72CudaRacer]
#2745376
02/22/20 03:43 AM
02/22/20 03:43 AM
Posts: 170 Sticky South
Rodenteliminator
Sticky South
8 weeks from the time Bulldog got my deposit to delivery about $4200 shipped on a good crate, beefy yes 278 lbs my 71 non 230 block is 219 lbs
Sorry honey I spent the rent
[Re: Cab_Burge]
#2745595
02/22/20 08:34 PM
02/22/20 08:34 PM
Posts: 143 North America
kwikblownhemi
North America
I have one Koleno high nickel 4.90 rough bore wedge block and a KB aluminum wedge block that is suppose to be delivered to me at the end of March or the first week of April That is interesting. I have had a KB Hemi block on order since December 2018.
[Re: kwikblownhemi]
#2745661
02/23/20 12:48 AM
02/23/20 12:48 AM
Posts: 1,103 Massillon, Ohio
cudatom
Massillon, Ohio
It took 16 months for my wedge block to come in ordered Oct 2018. Communication with my dealer was great. Not so much between KB and my dealer. Took a lot of calls, emails and complaining by my dealer to KB to make this happen.
Ok
#2745695
02/23/20 10:39 AM
02/23/20 10:39 AM
Posts: 27 Fl
Superlead
Fl
What’s with the raised area on the upper timing gear thrust surface on the BD block? That area has been machined so that the mounting cover of a Jesel belt drive system will fit.
[Re: ]
#2745730
02/23/20 11:59 AM
02/23/20 11:59 AM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Superfreak,
I just picked up a Hemi block with the same part number as the one in your pics yesterday. It has never been built, and was curious about it. So I guess it is a World block. Any idea when these were produced? Do you have spec sheet on it?
The pad near the fuel pump is stamped: 0811060A445 P5153861
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: GTSDave]
#2745936
02/24/20 12:34 AM
02/24/20 12:34 AM
Superfreak
Superfreak
Superfreak,
-Dave No idea when these were produced. Bought mine from Dave Dudeck and it was new untouched but how long he had it for, I am not sure. P5153862 is on the fuel pump pad and on the side of the block it P5153843 so not sure what is up with that.
[Re: KD800X]
#2745940
02/24/20 12:53 AM
02/24/20 12:53 AM
Superfreak
Superfreak
Question.... I have a Hemi Block with the 2468330-M casting number. What is an acceptable cylinder wall thickness? I know the final bore after hone is 4.503. I'm going to contact my machinist and have him sonic test it.
My block finished out at 4.502.
[Re: KD800X]
#2745962
02/24/20 01:51 AM
02/24/20 01:51 AM
Posts: 43,232 Bend,OR USA
Cab_Burge
You want it as thick as possible, many of the Mega blocks have failed, cracked, at 4.500 As far as cylinder wall thickness if it is less than .160 finished on either thrust side I won't use them for a serious N/A race motor I would love to have one that is .250 or thicker Maybe my Koleno block will do that at 4.560
[Re: Cab_Burge]
#2746181
02/24/20 06:53 PM
02/24/20 06:53 PM
'72CudaRacer
Mooresburg, Tn
: I would love to have one that is .250 or thicker Maybe my Koleno block will do that at 4.560 I repaired/freshened up a 622 ci Koleno block that was 4.600 bore. It was already a running engine so I didn't have it sonic checked. I do know that it was one of, if not the first, Koleno block that was built into a running engine, block #11. Don't know if that will matter to yours. Brian
