Re: Mega Block Questions [Re: sr4440] #2745053
02/20/20 09:38 PM
02/20/20 09:38 PM
Mooresburg, Tn
'72CudaRacer Online content OP
'72CudaRacer  Online Content OP
Mooresburg, Tn
Originally Posted by sr4440
here's a bulldog "B" block that was cast last month.
WOW!! They do exist! Are all 5 mains cross bolted? Looks comparable to mega blocks and world blocks. How long did it take to get it and approx price range? Thanks for sharing,
Brian
Re: Mega Block Questions [Re: '72CudaRacer] #2745064
02/20/20 10:01 PM
02/20/20 10:01 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
front 4 are cross bolted, price was around 4,000. from the time i called him to sitting at my house was 21 days.
( i was really lucky) http://bulldogblockhead.com/price-sheet
Without Data, you’re just another guy with an opinion.
Re: Mega Block Questions [Re: sr4440] #2745083
02/20/20 11:25 PM
02/20/20 11:25 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
It's nice to know that low deck blocks are available.
thanks for the pics!!
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Mega Block Questions [Re: sr4440] #2745233
02/21/20 02:28 PM
02/21/20 02:28 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
The B block from Bulldog has Hemi style mount provisions?
Re: Mega Block Questions [Re: Jwilli500] #2745283
02/21/20 06:33 PM
02/21/20 06:33 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
you can order it either way.
Re: Mega Block Questions [Re: sr4440] #2745286
02/21/20 06:42 PM
02/21/20 06:42 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What’s with the raised area on the upper timing gear thrust surface on the BD block?
Re: Mega Block Questions [Re: fast68plymouth] #2745306
02/21/20 08:42 PM
02/21/20 08:42 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
it's not raised, it is flush with the timing chain cover, same as a stock block. But it is a little narrower, i believe that is because it's been drilled for a 60/55 MM cam. I sure if you ran a stock cam size it would look "normal".
Joe
Re: Mega Block Questions [Re: sr4440] #2745371
02/22/20 02:00 AM
02/22/20 02:00 AM
I've owned and built three different World iron blocks, 2 hemi, one B1 wedge with good results up
I have one Koleno high nickel 4.90 rough bore wedge block and a KB aluminum wedge block that is suppose to be delivered to me at the end of March or the first week of April luck
555 CI and 572 C.I. wedge motors coming up wrench boogie luck
Re: Mega Block Questions [Re: '72CudaRacer] #2745376
02/22/20 03:43 AM
02/22/20 03:43 AM
Sticky South
Rodenteliminator Offline
Sticky South
8 weeks from the time Bulldog got my deposit to delivery about $4200 shipped on a good crate, beefy yes 278 lbs my 71 non 230 block is 219 lbs
Sorry honey I spent the rent
Re: Mega Block Questions [Re: Cab_Burge] #2745595
02/22/20 08:34 PM
02/22/20 08:34 PM
North America
K
kwikblownhemi Offline
K
North America
That is interesting. I have had a KB Hemi block on order since December 2018.
Re: Mega Block Questions [Re: kwikblownhemi] #2745627
02/22/20 10:01 PM
02/22/20 10:01 PM
I may have placed my order and sent the deposit before you placed your order shruggy CRS now :whiney, I'm thinking October of either 2017 or 2018 confused
Re: Mega Block Questions [Re: kwikblownhemi] #2745661
02/23/20 12:48 AM
02/23/20 12:48 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
It took 16 months for my wedge block to come in ordered Oct 2018. Communication with my dealer was great. Not so much between KB and my dealer. Took a lot of calls, emails and complaining by my dealer to KB to make this happen.
Ok
Re: Mega Block Questions [Re: fast68plymouth] #2745695
02/23/20 10:39 AM
02/23/20 10:39 AM
Fl
Superlead Offline
Superlead  Offline
Fl
That area has been machined so that the mounting cover of a Jesel belt drive system will fit.
Re: Mega Block Questions [Re: ] #2745730
02/23/20 11:59 AM
02/23/20 11:59 AM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
Superfreak,
I just picked up a Hemi block with the same part number as the one in your pics yesterday. It has never been built, and was curious about it. So I guess it is a World block. Any idea when these were produced? Do you have spec sheet on it?
The pad near the fuel pump is stamped:
0811060A445
P5153861
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Mega Block Questions [Re: jughed] #2745889
02/23/20 09:47 PM
02/23/20 09:47 PM
NW Pa.
KD800X Offline
KD800X  Offline
NW Pa.
Question.... I have a Hemi Block with the 2468330-M casting number. What is an acceptable cylinder wall thickness? I know the final bore after hone is 4.503. I'm going to contact my machinist and have him sonic test it.
Re: Mega Block Questions [Re: GTSDave] #2745936
02/24/20 12:34 AM
02/24/20 12:34 AM
Superfreak
Superfreak
Originally Posted by GTSDave
Superfreak,
0811060A445
P5153861
-Dave
No idea when these were produced. Bought mine from Dave Dudeck and it was new untouched but how long he had it for, I am not sure.
P5153862 is on the fuel pump pad and on the side of the block it P5153843 so not sure what is up with that.
Re: Mega Block Questions [Re: KD800X] #2745940
02/24/20 12:53 AM
02/24/20 12:53 AM
Superfreak
Superfreak
My block finished out at 4.502.
Re: Mega Block Questions [Re: KD800X] #2745962
02/24/20 01:51 AM
02/24/20 01:51 AM
You want it as thick as possible, many of the Mega blocks have failed, cracked, at 4.500 whiney
As far as cylinder wall thickness if it is less than .160 finished on either thrust side I won't use them for a serious N/A race motor twocents
I would love to have one that is .250 or thicker up
Maybe my Koleno block will do that at 4.560 luck
Re: Mega Block Questions [Re: Cab_Burge] #2746181
02/24/20 06:53 PM
02/24/20 06:53 PM
Mooresburg, Tn
Mooresburg, Tn
I repaired/freshened up a 622 ci Koleno block that was 4.600 bore. It was already a running engine so I didn't have it sonic checked. I do know that it was one of, if not the first, Koleno block that was built into a running engine, block #11. Don't know if that will matter to yours.
Brian
Re: Mega Block Questions [Re: '72CudaRacer] #2746281
02/24/20 11:20 PM
02/24/20 11:20 PM
NW Pa.
KD800X Offline
KD800X  Offline
NW Pa.
Thanks Cab and Superfreak,
I had it checked today. The worst was # 8 which was .164 on the outside which if I'm mot mistaking is the Major side. The rest were from 172-200 except #7 which had a sleeve put in back when it was new because it checked thin.
It's N/SS car, high 9's to 10.0 under 7k RPM with a 7.100 rod.
Thanks again!
