Rocker Arms Unlimited #2743234
02/15/20 04:11 PM
02/15/20 04:11 PM
Minnesota
TrackPack Offline OP
Minnesota
Is Rocker Arms Unlimited making roller rockers for the B/RB heads again? I think that they used to call them 440 MAX.
Re: Rocker Arms Unlimited [Re: TrackPack] #2743237
02/15/20 04:39 PM
02/15/20 04:39 PM
Cab_Burge Online work
Cab_Burge  Online Work
Call them and ask them at 530-242-1316 scope
Re: Rocker Arms Unlimited [Re: TrackPack] #2743296
02/15/20 07:32 PM
02/15/20 07:32 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Yes just bought a set. They didn't have any shafts back from the hard chromers. So I bought the rocker arms and used Hughes shafts. They only make them in 1.6 ratio.
Re: Rocker Arms Unlimited [Re: HDNMOPERS] #2743341
02/15/20 09:31 PM
02/15/20 09:31 PM
Minnesota
Minnesota
Good to hear. Very interested in what you think about the quality.
Re: Rocker Arms Unlimited [Re: TrackPack] #2743518
02/16/20 12:02 PM
02/16/20 12:02 PM
It's Complicated
HDNMOPERS Offline
HDNMOPERS  Offline
It's Complicated
Very high quality. Little on the heavy side. But very good rocker.
Re: Rocker Arms Unlimited [Re: HDNMOPERS] #2743527
02/16/20 12:24 PM
02/16/20 12:24 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The RAS shafts I purchased in the past are much beefier than the multiple sets of Hughes shafts I own(ed). But they're priced accordingly to go with the extra strength and additional oiling mods.
Depending upon the application, the Hughes shafts are perfectly usable. And, if I was still using heads that worked with standard-offset intake rockers, I'd be kicking myself for having solid my set of rockers & shafts years ago.
The only drawback, as pointed out, is they are very nose heavy as a result of their "built like a bridge support" design.
Re: Rocker Arms Unlimited [Re: BradH] #2743682
02/16/20 06:23 PM
02/16/20 06:23 PM
Minnesota
Minnesota
Thanks for the replies. Hughes rockers are high on my list too.
Re: Rocker Arms Unlimited [Re: TrackPack] #2743738
02/16/20 08:42 PM
02/16/20 08:42 PM
Do you remember the old adage about talking about people or business that goes, if you can't say something good don't say anything at all? If not I do so I won't say anything about Hughes or RAS rockers now based on my experiences with both tsk work
Re: Rocker Arms Unlimited [Re: Cab_Burge] #2743801
02/17/20 12:02 AM
02/17/20 12:02 AM
Minnesota
Minnesota
I can understand your philosophy. On that note, I'd be very interested in a rocker arm company that you do have something good to say about.
Re: Rocker Arms Unlimited [Re: TrackPack] #2743829
02/17/20 03:19 AM
02/17/20 03:19 AM
Isky, Crane (both ductile iron and aluminum up) Harland Sharp, T&D, Jesel are all companies that I have had good products from with none or very minor issues up
PM if you want more info about my comment on not saying bad things about products I've used that had issues with up
