Page 6 of 11 1 2 4 5 6 7 8 10 11
Re: Hilborn EFI 512 Charger [Re: CSK] #2719237
11/25/19 05:20 PM
11/25/19 05:20 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Something to remember is that if you have a misfire it will read lean on the 02 sensor. So if you have a misfire it is possible the "auto tune" will add fuel and make it overly rich(smoke).
68 Barracuda Formula S 340
Re: Hilborn EFI 512 Charger [Re: CSK] #2719238
11/25/19 05:23 PM
11/25/19 05:23 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
You can see in this log the fuel goes a little rich, then goes off the scale lean, then goes off the chart rich, the color of the fuel lines are yellow & light blue, the color codes are at the top of the graph area.
Re: Hilborn EFI 512 Charger [Re: CSK] #2719239
11/25/19 05:23 PM
11/25/19 05:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I thought I’d heard some popping in high gear.......but I guess it’s not.
Pretty late on those shifts though smoke
Re: Hilborn EFI 512 Charger [Re: fast68plymouth] #2719244
11/25/19 05:35 PM
11/25/19 05:35 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
LOL, VERY late, it has to do with my medical issues, no snap smile
Re: Hilborn EFI 512 Charger [Re: CSK] #2719247
11/25/19 05:40 PM
11/25/19 05:40 PM
So. Burlington, Vt.
So. Burlington, Vt.
Set the shift lite for 5800!!
Re: Hilborn EFI 512 Charger [Re: fast68plymouth] #2719250
11/25/19 05:52 PM
11/25/19 05:52 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
That is where it is now, if that dont work I'll try 5000 LOL
Re: Hilborn EFI 512 Charger [Re: Bad340fish] #2719251
11/25/19 05:54 PM
11/25/19 05:54 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
thumbs
Re: Hilborn EFI 512 Charger [Re: CSK] #2741035
02/08/20 07:03 PM
02/08/20 07:03 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
People refer to , "Off the trailer pass",, Mine is "OFF the FREEWAY pass", LOL,170 miles round trip due to LOTS of road closures GRRRRR 1st pass was the best.
11.04 @ 123.07 4100lb race weight, Did some tuning & learned what it does NOT like, I forgot to raise the rev limit & still bumped it, even in high gear. I added & pulled timing & fuel, it likes 37 total timing & so far 12.6 AFR, still no 10.99 pass, I am sure with some more tuning it could get there, BUT thinking about my combination here are some points, it is only a 9.7-1 compression, Max Wedge ports,, HEAVY pig with a 28" tall tire & 3.54 gear, I truly believe that my car needs a 4.10 or there about gear, to do much better on the ET, this is a drive it anywhere true street car DA was in the 400ish
Re: Hilborn EFI 512 Charger [Re: CSK] #2741044
02/08/20 07:28 PM
02/08/20 07:28 PM
So. Burlington, Vt.
So. Burlington, Vt.
You have 10 second speed....... but not enough speed to get it done with that 60’.
Have you tried removing those blue “socks” from the air filters?
And the “crowd” went wild!!!! smoke
Did you ever get to make a good pass with carb and the fuel system sorted out?
At 4100lbs...... 123mph shows 585hp.
Pretty good for a true street car.
Re: Hilborn EFI 512 Charger [Re: fast68plymouth] #2741046
02/08/20 07:35 PM
02/08/20 07:35 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
No on the pre filters, I should have, I thought about it but I ran out of energy & started getting shaky, I was done. I brought some extra stacks that have no filters, but like I said, I ran out of steam.
Re: Hilborn EFI 512 Charger [Re: CSK] #2741055
02/08/20 08:11 PM
02/08/20 08:11 PM
So. Burlington, Vt.
So. Burlington, Vt.
Longer stacks might help the 60’.
No telling what would happen down track though.
Re: Hilborn EFI 512 Charger [Re: fast68plymouth] #2741114
02/09/20 12:24 AM
02/09/20 12:24 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Never made another carbed pass, the best MPH carbed was 121.1 & it was not laying down like it did later on.
I will try a total runner length of 23" , it is at 17" now
Re: Hilborn EFI 512 Charger [Re: CSK] #2741185
02/09/20 12:24 PM
02/09/20 12:24 PM
moparx Offline
moparx  Offline
great run indeed ! up
beer
Re: Hilborn EFI 512 Charger [Re: moparx] #2741270
02/09/20 04:24 PM
02/09/20 04:24 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
What converter are you running? Our combos are actually fairly similar.
Re: Hilborn EFI 512 Charger [Re: MarkZ] #2741271
02/09/20 04:26 PM
02/09/20 04:26 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Its a PATC, custom built lock up, with my new Hilborn EFI on the data log it was flashing to 4800 when I let off the brake
Re: Hilborn EFI 512 Charger [Re: CSK] #2741274
02/09/20 04:33 PM
02/09/20 04:33 PM
So. Burlington, Vt.
So. Burlington, Vt.
What’s the best 60’ ever with it?
Re: Hilborn EFI 512 Charger [Re: fast68plymouth] #2741295
02/09/20 05:17 PM
02/09/20 05:17 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
The 1.559 in the current slip, the track prep was spot on, it seemed to dead hook.
Re: Hilborn EFI 512 Charger [Re: CSK] #2741462
02/10/20 01:46 AM
02/10/20 01:46 AM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
A VERY rare picture of me & my Charger
Re: Hilborn EFI 512 Charger [Re: CSK] #2741549
02/10/20 01:09 PM
02/10/20 01:09 PM
moparx Offline
moparx  Offline
up bow boogie
beer
Re: Hilborn EFI 512 Charger [Re: fast68plymouth] #2742005
02/11/20 04:18 PM
02/11/20 04:18 PM
Pattison Texas
CSK Offline OP
CSK  Offline OP
Pattison Texas
Hey Dwayne
This program APP I use is very close to what I have found on the dyno with IR intake set ups, not every engine reacts the same [ CID, CSA of port,cam,, ect ] but my engine is close to the ones I have dynoed, that said, the runner length helps at a given RPM & hurts power at other RPMS that is not in the usable range of said length, right now my set up is 17" runner.
Input length is 17 inches
For 2nd harmonic, RPM range is from 6911 to 8386 with a pulse strength of 10 percent
For 3rd harmonic, RPM range is from 5192 to 5934 with a pulse strength of 7 percent
For 4th harmonic, RPM range is from 4048 to 4527 with a pulse strength of 4 percent
I am using the 3rd harmonic pulse right now , the 2nd pulse is above my RPM range
the 4th is bellow my converter stall.
Looking at my coverter stall on the data log, I am at 4800 rpm at the leave,,,so that means that my engine is in the bad part of the good harmonic pulse range 5192 to 5934 with a pulse strength of 7 percent.
Input length is 24 inches
For 2nd harmonic, RPM range is from 4895 to 5940 with a pulse strength of 10 percent
For 3rd harmonic, RPM range is from 3678 to 4203 with a pulse strength of 7 percent
For 4th harmonic, RPM range is from 2867 to 3207 with a pulse strength of 4 percent
Now going to a Total runner length of 24" will move the power making benefit of the runner to the 2nd harmonic pulse of 4895 to 5940 with a pulse strength of 10 percent, so by doing that should put my engine in the power range on the leave at 4800 rpm & my trap rpm of about 6k fits with the 17" AND 24" runner, also the pulse is stronger on the 2nd harmonic.
So the longer runner should not hurt the big end at all.
I had cut my runners to 17" so I could see over the air filters to drive on the street,.
