Re: Enclosed trailer advice?
[Re: 70runner]
#2740684
02/07/20 03:04 PM
02/07/20 03:04 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
If you are buying a new trailer, ask the manufacturer about a roadside escape door.
Those are a popular option for allowing easy access into and out of the loaded car.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: gtx6970]
#2740714
02/07/20 04:47 PM
02/07/20 04:47 PM
Posts: 849 Avondale AZ
Prodart440
Avondale AZ
I have a 24ft to haul my road runner. I wouldn't want to use anything smaller than that. I do have the "fat man" door. It makes it way easier to get out of the trailer.
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: Prodart440]
#2740732
02/07/20 05:41 PM
02/07/20 05:41 PM
Posts: 1,178 People's Republic of Kali
70runner
I have a 24ft to haul my road runner. I wouldn't want to use anything smaller than that. I do have the "fat man" door. It makes it way easier to get out of the trailer. Pls elaborate. Is the extra 4ft necessary for just the car, or for additional storage or ? Does the escape door line up with the car door so you open car door enough to exit? Pic?
[Re: 70runner]
#2740738
02/07/20 05:52 PM
02/07/20 05:52 PM
Posts: 1,612 westerly, ri. usa
440lebaron
westerly, ri. usa
at least 24ft, if you want to get in front of car to tie it down, we tow 69 charger in 24 and 28ft, think of coolers tool box etc
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 70runner]
#2740751
02/07/20 06:40 PM
02/07/20 06:40 PM
Prodart440
Avondale AZ
I have a 24ft to haul my road runner. I wouldn't want to use anything smaller than that. I do have the "fat man" door. It makes it way easier to get out of the trailer. Pls elaborate. Is the extra 4ft necessary for just the car, or for additional storage or ? Does the escape door line up with the car door so you open car door enough to exit? Pic? The 4ft isn't necessary, but very nice to have. With the car in it I have about 4.5 feet of space in front. Yes, the door lines up (its almost too far forward) and I can open the car door, and get out of the trailer side door. I don't have the car in it to get pictures right now.
Aaron
[Re: 70runner]
#2740763
02/07/20 07:40 PM
02/07/20 07:40 PM
Posts: 21,500 It's a dry heat
gtx6970
It's a dry heat
I have a 24ft to haul my road runner. I wouldn't want to use anything smaller than that. I do have the "fat man" door. It makes it way easier to get out of the trailer. Pls elaborate. Is the extra 4ft necessary for just the car, or for additional storage or ? Both. Ive used both a 20 and 22' trailers. the 20 footer makes it really tight to get in front of the car to get it tied down the 22 footer had boxes in the front, again makes it tight to get in lay down and tie it down. So as long as you plan to put NOTHING on the floor in front of the car. You may be ok. But IMO going any less than 24; leaves no room for tools, floor jack, a winch. Nothing. Not to mention used values are much better at 24' and above for all the same reasons
[Re: 70runner]
#2740774
02/07/20 08:24 PM
02/07/20 08:24 PM
Posts: 20,665 in a cattle trailer down by th...
Guitar Jones
Researching enclosed trailers, used primarily to trailer a 69 Charger RT. From what I've read, if used to simply trailer the car, 8.5 x 20 would be about the minimum size. Most of the trailers I've seen have a side door on the right. With an 8.5ft width is it possible to drive a B body onto the trailer and exit the driver door side? Do you have to exit through the door glass opening? Realize I can install a winch, but trying to keep cost down. Suggestions? Understand trying to keep costs down but how often are you going to be towing the car? Personally a winch is cheaper than the side door option and you don't have to worry about firing your car up in a potential fuel vapor filled box. I've seen the result of that after a backfire and flooding carb, just a molten mass of metal when it was over. Spend the money on the extra length too, 24 would be a minimum I would consider. 26 or 28 would be better and you will be glad you got it later. The other thing is get the heavy duty axles and tires, don't cheap out on them.
[Re: gtx6970]
#2740775
02/07/20 08:26 PM
02/07/20 08:26 PM
Posts: 20,910 A collage of whims
topside
A collage of whims
Hauled all over the Country with a guy that had an 8 x 20 enclosed. He was obsessed with weight, so no left door, only the curbside and an electric winch. Kinda difficult to tie down the front of a B-body sized car. Getting in & out involved an open window and brushing up against the car walking in/out. Being the skinny guy, that was my deal, and often a challenge to not touch the car. So for the nice stuff, it was winch only, with the car aimed dead straight. Nowadays (retired), he has a 24 & a 28 for his own stuff.
He'd get over a million miles on his trailers, and specified 16" centers on side framing and nothing mounted above the car. Used to buy them out of Kentucky, IIRC, some big outfit. I ended up with one of their Duallys, but that's another story
[Re: SportF]
#2740780
02/07/20 08:49 PM
02/07/20 08:49 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
My opinion (along with a few others who've already responded) is a 24' length is the best size to go with. I had a 28 and while the extra length was nice, it proved to be too long to get around in some tight spots. I found a 24' adequate in space and easier to manipulate in limited spaces.
I've not heard of the running straps from front to back approach. Would be curious to know more.
Lead, follow or get the hell out of the way
[Re: 70runner]
#2740797
02/07/20 10:26 PM
02/07/20 10:26 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
Spend a little more money now to get a 10,000 GVW rated 24 ft. trailer with 16 inch wheels and tires, 15 inch trailer tires SUCK badly. Get one with the side door that you can open okay inside in case you decide to sleep in front of the car sometimes in the future ![work work](/ubbthreads/images/graemlins/custom/work.gif) Get and install a good brand 4500Lb rated winch that will power both in and out and make sure the trailer tie down rings are placed so you can use them on your car ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I bought my current used 24 Ft. Pace Shadow 10,000 GVW after having Pace custom build me a 22 Ft 7,000 GVW trailer that the salesman told me would weigh right at 2900 Lb. empty, he lied ![rant rant](/ubbthreads/images/graemlins/custom/rant.gif) It weighed 4360 Lbs. when I picked it up at the factory ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) Most of my cars that I haul all weigh over 3,000 Lbs. so there was no room to add weight into it for spare parts, tires, winch, battery and so on ![down down](/ubbthreads/images/graemlins/custom/down.gif) The 7000 LB rated trailers come with 3500 Lb. rated axles, five lug 15 inch wheels and C rated tires ![down down](/ubbthreads/images/graemlins/custom/down.gif) Another thing on the tie downs, my trailer was used to haul a 1970 Challenger and a 1968 B body before I bought it from a friend. He had to redo, added another pair of the front tie down rings, to use it on both cars ![work work](/ubbthreads/images/graemlins/custom/work.gif) I used it mainly to haul my old pump gas 1971 Duster with using new the front rings he added ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I've owned 3 enclosed car trailers, five car hauler trucks and put a lot of miles under my butt towing and going to races and other places hauling cars for friends, relatives and myself. You don't want to be broke down in the middle of the night a long ways away from anywhere due to using cheap parts, do you ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) One other thing is don't use a 1/2 ton truck to tow with unless it is rated to haul your car in the trailer and be over the gross combine rated weight of the car and trailer ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I made that mistake on the first race car, 1969 Hemi GTX, I was hauling for a friend with a borrow home made open two axle car trailer with no brakes , a large stray dog ran out in front of us in my 1960 Ford 1/2 ton long bed pickup, I couldn't stop quick enough to avoid hitting it and it got wedge up between the right front tire and wheel well jerking the steering wheel out of my hands and jack knifing the trailer into my truck making the race car come off the trailer and roll over, not good enough tie downs, totaling the car ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) I had my D500 flat bed truck converted into a car hauler after that ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) No more hauling cars unsafely after that ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) Be safe ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: peabodyracing]
#2740889
02/08/20 09:01 AM
02/08/20 09:01 AM
Posts: 1,213 Minn
SportF
Minn
I've not heard of the running straps from front to back approach. Would be curious to know more. Hook up the front straps to tie downs, run them to the back ramp. Pull the car in, put in park. Put the ratchets on the front straps and pull the car forward tight against the park pawl ( I put the hooks on the rear subframe by bumper bracket, race car). Put the axle straps on the rear and pull the car back a little to release tension at park (watch the tire move). Don't cross them, as the pro's advise as well. Your done, working with plenty of room on the beaver tail and ramp. Go under the car once, not twice. Of course unstrapping saves the same amount of trouble as well. Best of luck.
[Re: Cab_Burge]
#2740922
02/08/20 12:12 PM
02/08/20 12:12 PM
Posts: 2,119 Byron, NY
W.I.N. Racing
Byron, NY
Spend a little more money now to get a 10,000 GVW rated 24 ft. trailer with 16 inch wheels and tires, 15 inch trailer tires SUCK badly. Get one with the side door that you can open okay inside in case you decide to sleep in front of the car sometimes in the future ![work work](/ubbthreads/images/graemlins/custom/work.gif) Get and install a good brand 4500Lb rated winch that will power both in and out and make sure the trailer tie down rings are placed so you can use them on your car ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) : ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif)
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Rhinodart]
#2740938
02/08/20 01:07 PM
02/08/20 01:07 PM
Posts: 6,433 Abilene, Texas
fastmark
Abilene, Texas
Listen to Cab. Get a 24’. A 20 is hard to get enough tongue weight with a heavy car. I’d show you a picture of what it looks like when a 20’ is not quite loaded right and it hits a wet spot on a hill and a gust of wind hits you just right, but this is a hard sire to post pictures on. Not to mention cheap axles and the 15” wheels just don’t cut it for trailer tires. Ok. Added a picture. Bty, I think this one can be bought cheap!
