Re: How many miles per oil change on your Cummin trucks? [Re: RTSrunner] #2729990
01/04/20 02:11 PM
01/04/20 02:11 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
A noise filter on your Apps wire works wonders on those also , Available thru BD diesel or ebay, Dodge cummins diesel noise filter,
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: How many miles per oil change on your Cummin trucks? [Re: jwilson 61] #2730085
01/04/20 07:04 PM
01/04/20 07:04 PM
Guitar Jones Online laugh2
I change mine at 6K but it is an old VE pumped 12 valve. It is my daily driver though getting at let 80 miles a day.
Re: How many miles per oil change on your Cummin trucks? [Re: Guitar Jones] #2730137
01/04/20 11:17 PM
01/04/20 11:17 PM
Cab_Burge Offline OP
I was told by the dealer fleet sales rep to change it at 7500 miles, I haven't done that ever. I was trying to change the oil and filter around 3500 miles.
I've heard the oil will quit getting dirty right away after changing once the motor gets broken, between 35,000 to 60,000 miles, mine hasn't done that yet at 151,000+ miles shruggy
I'm going to try changing it around 5,000 miles now for a while and see if I like that or not luck
Thanks for the help to all of you bow up
Re: How many miles per oil change on your Cummin trucks? [Re: RTSrunner] #2730162
01/05/20 01:29 AM
01/05/20 01:29 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Originally Posted by RTSrunner
Originally Posted by J_BODY
Originally Posted by mopardude318
I have an ‘02 2500 Cummins 4x4. I change every 10,000 miles I use Valvoline Premium Blue and Fleetguard Stratapore filters. Bought the truck a couple years ago at 130k, I’m at 250k now.
If I can just get the damned thing to STOP going in and out of lockup it’d be a good truck. I might switch to an NV5600 6 speed.
Other than that, no performance mods. No chip, no tuner no injectors, stock transmission. I’d really like to turn up the heat on it, what am I missing? More go power would be nice.
You need to relocate and sheild that large blk/tan ground wire that runs over the top of your alternator. Made a lot of $$ doing that back in the day.
More info on this please:) and thanks
Passenger side near the battery..... large blk/tan wire. You’ll see it goes to two gray connectors mounted on the batt tray. I eliminate those connectors by removing the terminals and solder them. Next I remove the wire from the harness past the alternator and cover the blk/tan with foil tape and some black convoluting cover. I then route the wire over the black metal top alternator mount. I’d post picts if photobucket didn’t go to L! If you want picts pm me your phone # and I’ll text them.
Re: How many miles per oil change on your Cummin trucks? [Re: J_BODY] #2730451
01/06/20 03:35 AM
01/06/20 03:35 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
PM sent,Thanks J-Body for the reply,RT
Re: How many miles per oil change on your Cummin trucks? [Re: RTSrunner] #2740723
02/07/20 05:10 PM
02/07/20 05:10 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I go between 10,000 and 12,000 miles on mine. I have used Amsoil since around 80,000. I send a sample in to be tested every time. 254,000 miles and going strong.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: How many miles per oil change on your Cummin trucks? [Re: Prodart440] #2740745
02/07/20 06:20 PM
02/07/20 06:20 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Bought my 07 2500 from Dave Smith over 13 years ago. I’m now pushing 300k. Most of which was up in Yakima. Now in Phoenix. Started running Amsoil 15/40 starting at 15k. Doesn’t use a drop of oil. I change at every 7500 miles. Using WIX filters.
Abe Lincoln
Re: How many miles per oil change on your Cummin trucks? [Re: Cab_Burge] #2741103
02/08/20 11:27 PM
02/08/20 11:27 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Nature of the beast Cab. Some are worse than others. My Cat stays fairly clean looking right up to 12,000 miles. My N14 Cummins was black by the end of the driveway. I think ring design and better filtering on the Cat account for most of the difference.
Cummins filter specs are considerably more lax than Cat. A Cummins N14 fuel filter is 10 micron. A Cat is 3.
Kevin
