Re: Rear axle shim install?
[Re: GoodysGotaCuda]
#2737566
01/28/20 11:43 PM
01/28/20 11:43 PM
RapidRobert
What angles are you showing? full or part time vibration?
[Re: RapidRobert]
#2737601
01/29/20 06:51 AM
01/29/20 06:51 AM
Posts: 4,759 Florida
BDW
Seems to be part time, hard to tell, but it gets really bad above 65mph. I’ve had the the tires and driveshaft balanced twice, with no difference. Here’s where I started, but have since shimmed tranny up so it’s now 2 degrees down. Again no change, so next step is to shim rear end down 3 degrees. ![[Linked Image]](https://i.postimg.cc/rpxnsW9y/2564-B411-C21-C-4-ECA-A5-B5-4-DA17-F97326-C.jpg)
#2737637
01/29/20 10:24 AM
01/29/20 10:24 AM
Posts: 18,160 Mass
DAYCLONA
Mass
I've slept since this, but wouldn't you want to nose the diff up 2° so that each yoke is in a parallel plane? You want the driveline angle and the pinion angle on parallel planes ON ACCELERATION, a lot of variables determine how much the pinion rotates upward on acceleration, can be upwards of 5 degrees
[Re: BDW]
#2737660
01/29/20 11:59 AM
01/29/20 11:59 AM
RapidRobert
& you want the angles to be minimal. Yes the pinion will rise & how much depends if it is a DD or driven hard. I had a part time vibration & it turned out the yoke was not far enough into the trans. A slightly longer shaft fixed it.
[Re: moparx]
#2737691
01/29/20 12:44 PM
01/29/20 12:44 PM
Posts: 3,102 Michigan
A727Tflite
Overdrive transmissions have no impact on the prop shaft speed.
In third or overdrive at any given vehicle speed the prop shaft turns at the same speed in either gear. Engine speed is lower in overdrive than in third, that’s the benefit. Not shaft speed.
[Re: A727Tflite]
#2737717
01/29/20 01:42 PM
01/29/20 01:42 PM
Posts: 18,160 Mass
DAYCLONA
Mass
In a way they do... most production driveshafts are generally balanced for 3000-3500 rpm, when you add an overdrive transmission along with let's say a 4:10 rear gear, .... a .64 overdrive is now capable of moving the vehicle to a speed of 140-150 mph with engine rpm being the limiting factor, prop speed is now extremely high, one of the reasons most aftermarket overdrive suppliers balance the shaft to 10,000 rpm
[Re: A727Tflite]
#2737928
01/29/20 11:41 PM
01/29/20 11:41 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Please read my post again - “at a given vehicle speed”.
No arguement that going faster makes the prop turn faster. Agreed, I was making a case for the possible need to look at the driveshaft balance, to rule out possible harmonics Mike
#2737943
01/30/20 01:03 AM
01/30/20 01:03 AM
Posts: 1,908 Nebraska
4406bbl
Nebraska
I've slept since this, but wouldn't you want to nose the diff up 2° so that each yoke is in a parallel plane? This is what works for me, every time light load at highway speeds. It would not be the best for a drag car. I am suprised that with the rear at zero and trans 2 down you have an issue, it should be fine, like almost perfect under light load. Is the dana offset left or right, and is engine/trans straight in the car? Just wondering if you may be getting an offset induced vibration.
[Re: DAYCLONA]
#2738052
01/30/20 12:11 PM
01/30/20 12:11 PM
Posts: 19,629 north of coder
moparx
No arguement that going faster makes the prop turn faster. Agreed, I was making a case for the possible need to look at the driveshaft balance, to rule out possible harmonics Mike agreed, no matter what speed, the tire/rear gear combo will be turning xxxxrpm. however, more than once, i have found deep gears and a short tire has caused driveshaft vibrations because the shaft was only balanced at a somewhat low speed. balancing the shaft at a high speed cured the vibration issue. just putting this out there as something else to look at if the vibration continues after fixing the driveline angle[s]. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
