Best ET with stamped rockers and hyd cam? #2736857
01/26/20 06:15 PM
01/26/20 06:15 PM
Washington
skrews Offline OP
skrews  Offline OP
Washington
Like the title says, whats your best time with stamped rocker arms and hyd cam ? I'm sure plenty have been in the 12s and 11s, but anybody in the 10s or better?
Re: Best ET with stamped rockers and hyd cam? [Re: skrews] #2736870
01/26/20 07:10 PM
01/26/20 07:10 PM
AndyF Offline
AndyF  Offline
If that is the only rule then no reason you couldn't go 8's in a rail.
Re: Best ET with stamped rockers and hyd cam? [Re: skrews] #2736874
01/26/20 07:22 PM
01/26/20 07:22 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I went low 11's (11.10-11.20's) with a .533 MP cam and factory stamped rockers arms. (440 standard bore with factory cast pistons) Car weighed 3200lbs at the time with me in it.
Re: Best ET with stamped rockers and hyd cam? [Re: AndyF] #2736877
01/26/20 07:45 PM
01/26/20 07:45 PM
Washington
skrews Offline OP
skrews  Offline OP
Washington
Indeed, but I'm assuming that most people here are running production based cars.
Re: Best ET with stamped rockers and hyd cam? [Re: skrews] #2736981
01/27/20 08:23 AM
01/27/20 08:23 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
stock 440 (1968) home ported 906 heads. .509 cam with all stock valvetrain. 3600lb dart. went 10.70
of course it had a plate on it lol
....BAD A$$ STREET CAR.....
Re: Best ET with stamped rockers and hyd cam? [Re: skrews] #2736994
01/27/20 09:09 AM
01/27/20 09:09 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
6.80s 1/8 mile in a 68 Roadrunner, stock 440 build, iron heads, 9.5 compression, Stock Eliminator flat tappet cam, and stamp steel OE rockers. Car was on alcohol.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Best ET with stamped rockers and hyd cam? [Re: A39Coronet] #2737112
01/27/20 03:28 PM
01/27/20 03:28 PM
gregsdart Offline
gregsdart  Offline
A freinds roadrunnuer, full weight (3800?) 451 with a 268@ .050 race hydraulic went 11.47 through full 2 1/2 inch exhaust. I don't see why a bigger motor with a race hydraulic with as much as 276 @ .050 duration couldn't make 600 hp. I went 10.20s with iron 440-c bowl ported heads, 475 cubes, the same cam as my buddys 268@ .050 .540 lift but had indy dove rockers on it. 750 holley methanol carb. 3180 race weight. Take away a tenth or two for going to stock rockers and you have 10.40s?
Re: Best ET with stamped rockers and hyd cam? [Re: gregsdart] #2737161
01/27/20 05:49 PM
01/27/20 05:49 PM
A727Tflite Offline
A727Tflite  Offline
Before NHRA/IHRA allowed any rocker (with standard ratio) to be used in Stock Eliminator there were plenty of cars in the tens and that’s with factory lift cheater cams.
Back when Stock Eliminator was seriously teched and rules enforcesd.
Re: Best ET with stamped rockers and hyd cam? [Re: A727Tflite] #2737169
01/27/20 06:04 PM
01/27/20 06:04 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The rocker rule in Stock changed in 2012 iirc.
My friends Pontiacs had been well into the 10’s for several years by that time.
That’s with a net lift at the valve of .410”
The rule is .421”, but the stock rockers were never quite “1.5”.
He had the best longevity out of used factory rockers.
He’d tested piles of them from used motors to get 16 with the closest to 1.5 ratio as possible.
Re: Best ET with stamped rockers and hyd cam? [Re: fast68plymouth] #2737230
01/27/20 08:31 PM
01/27/20 08:31 PM
A727Tflite Offline
A727Tflite  Offline
My 6BBL car ran 11.40’s in late 1979. Tracks and tires ligh years ahead now compared to then.
Plus now - acid ported heads, piston and rod weight specs way under factory released specs, no mechanical fuel pump or fan required, spools allowed,, on and on.
And of course data recording. Things sure have changed in the last 40 years.
Re: Best ET with stamped rockers and hyd cam? [Re: A727Tflite] #2737232
01/27/20 08:37 PM
01/27/20 08:37 PM
So. Burlington, Vt.
So. Burlington, Vt.
11.40’s sounds killer for 1979!!
Re: Best ET with stamped rockers and hyd cam? [Re: fast68plymouth] #2737248
01/27/20 09:09 PM
01/27/20 09:09 PM
A727Tflite Offline
A727Tflite  Offline
Gainesville 1978 actually. Then a week later at Darlington for the IHRA race.
Great track and great air. Always wanted to run at Suffolk but never got the chance.
Now, 42 years later the fastest car in C/SA - Jason Line in his Buick went 10.0’s at Indy two years in a row.
Smokin’
Re: Best ET with stamped rockers and hyd cam? [Re: A727Tflite] #2737350
01/28/20 09:18 AM
01/28/20 09:18 AM
an8sec70cuda Offline
I went 10.60s in the 1/4 and 6.70s in the 1/8 with stock stamped rockers on a 440, 509 cam, in a 3700 lb car 18 years ago.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best ET with stamped rockers and hyd cam? [Re: an8sec70cuda] #2737433
01/28/20 02:25 PM
01/28/20 02:25 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
I believe you but would love to hear more about that combo and how you got there. That seems pretty quick for that cam and weight. Probably had a really good converter??
Re: Best ET with stamped rockers and hyd cam? [Re: BigBlockGTS] #2737675
01/29/20 12:21 PM
01/29/20 12:21 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I want to hear about this one too!
Re: Best ET with stamped rockers and hyd cam? [Re: GTX MATT] #2737700
01/29/20 01:04 PM
01/29/20 01:04 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Me three
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Best ET with stamped rockers and hyd cam? [Re: BloFish] #2737776
01/29/20 03:38 PM
01/29/20 03:38 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
The 440 in my wife's duster went 10.97-98 at 3 different tracks last season. The car weighs 2,960 with her in it. Its a 440 with Kieth black pistons, out of the box promaxx heads, .533 lunati voodoo cam, stock stamped steel rockers, M1 single plane, 750 double pumper and a 727 with a good 91/2" converter.
Re: Best ET with stamped rockers and hyd cam? [Re: A727Tflite] #2737777
01/29/20 03:40 PM
01/29/20 03:40 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Smokin’
Can’t remember the name but a Duster in D went 9.96 awhile back, 340s are flying, hope to get mine going soon.
Re: Best ET with stamped rockers and hyd cam? [Re: BloFish] #2737782
01/29/20 03:49 PM
01/29/20 03:49 PM
Me three
A 150 shot worked good on it, lol. smoke It ran 11.40s at 117 mph on motor only. Had a 10" TCI streetfighter converter in it. up
CHIP
