Page 2 of 3 1 2 3
Re: Holley Sniper 440 timing question [Re: Twostick] #2736290
01/24/20 08:45 PM
01/24/20 08:45 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Originally Posted by Twostick
Originally Posted by Cab_Burge
How many inches of vacuum or pounds of manifold pressure is 64.1 KPA?
Just shy of 19.
http://www.kylesconverter.com/pressure/kilopascals-to-inches-of-mercury
Kevin
That conversion is not correct
This is what a automotive Vacuum gauge would read
Default MAP kPa to inHg (vacuum gauge) to PSIG
105 kPa = +1.48 inHg = +0.72 psig
104 kPa = +1.18 inHg = +0.58 psig
103 kPa = +0.89 inHg = +0.43 psig
102 kPa = +0.59 inHg = +0.29 psig
101 kPa = +0.30 inHg = +0.14 psig
100 kPa = -0.0 inHg = -0.00 psig
99 kPa = -0.30 inHg = -0.14 psig
98 kPa = -0.59 inHg = -0.29 psig
97 kPa = -0.89 inHg = -0.43 psig
96 kPa = -1.18 inHg = -0.58 psig
95 kPa = -1.48 inHg = -0.72 psig
94 kPa = -1.78 inHg = -0.87 psig
93 kPa = -2.07 inHg = -1.01 psig
92 kPa = -2.37 inHg = -1.16 psig
91 kPa = -2.66 inHg = -1.30 psig
90 kPa = -2.96 inHg = -1.45 psig
89 kPa = -3.26 inHg = -1.59 psig
88 kPa = -3.55 inHg = -1.74 psig
87 kPa = -3.85 inHg = -1.88 psig
86 kPa = -4.14 inHg = -2.03 psig
85 kPa = -4.44 inHg = -2.17 psig
84 kPa = -4.73 inHg = -2.32 psig
83 kPa = -5.03 inHg = -2.46 psig
82 kPa = -5.33 inHg = -2.61 psig
81 kPa = -5.62 inHg = -2.75 psig
80 kPa = -5.92 inHg = -2.90 psig
79 kPa = -6.22 inHg = -3.04 psig
78 kPa = -6.51 inHg = -3.19 psig
77 kPa = -6.81 inHg = -3.33 psig
76 kPa = -7.11 inHg = -3.48 psig
75 kPa = -7.40 inHg = -3.62 psig
74 kPa = -7.70 inHg = -3.77 psig
73 kPa = -7.99 inHg = -3.91 psig
72 kPa = -8.29 inHg = -4.06 psig
71 kPa = -8.59 inHg = -4.20 psig
70 kPa = -8.88 inHg = -4.35 psig
69 kPa = -9.18 inHg = -4.49 psig
68 kPa = -9.47 inHg = -4.64 psig
67 kPa = -9.77 inHg = -4.78 psig
66 kPa = -10.07 inHg = -4.93 psig
65 kPa = -10.36 inHg = -5.07 psig
64 kPa = -10.66 inHg = -5.22 psig
63 kPa = -10.96 inHg = -5.36 psig
62 kPa = -11.25 inHg = -5.51 psig
61 kPa = -11.55 inHg = -5.65 psig
60 kPa = -11.84 inHg = -5.80 psig
59 kPa = -12.14 inHg = -5.94 psig
58 kPa = -12.44 inHg = -6.09 psig
57 kPa = -12.73 inHg = -6.23 psig
56 kPa = -13.03 inHg = -6.38 psig
55 kPa = -13.32 inHg = -6.52 psig
54 kPa = -13.62 inHg = -6.67 psig
53 kPa = -13.92 inHg = -6.81 psig
52 kPa = -14.21 inHg = -6.96 psig
51 kPa = -14.51 inHg = -7.10 psig
50 kPa = -14.80 inHg = -7.25 psig
49 kPa = -15.10 inHg = -7.39 psig
48 kPa = -15.40 inHg = -7.54 psig
47 kPa = -15.70 inHg = -7.68 psig
46 kPa = -15.99 inHg = -7.83 psig
45 kPa = -16.28 inHg = -7.97 psig
44 kPa = -16.58 inHg = -8.12 psig
43 kPa = -16.88 inHg = -8.26 psig
42 kPa = -17.17 inHg = -8.41 psig
41 kPa = -17.47 inHg = -8.55 psig
40 kPa = -17.77 inHg = -8.70 psig
39 kPa = -18.06 inHg = -8.84 psig
38 kPa = -18.36 inHg = -8.99 psig
37 kPa = -18.65 inHg = -9.13 psig
36 kPa = -18.95 inHg = -9.28 psig
35 kPa = -19.25 inHg = -9.42 psig
34 kPa = -19.54 inHg = -9.57 psig
33 kPa = -19.84 inHg = -9.71 psig
32 kPa = -20.13 inHg = -9.86 psig
31 kPa = -20.43 inHg = -10.00 psig
30 kPa = -20.73 inHg = -10.15 psig
29 kPa = -21.02 inHg = -10.29 psig
28 kPa = -21.32 inHg = -10.44 psig
27 kPa = -21.61 inHg = -10.58 psig
26 kPa = -21.91 inHg = -10.73 psig
25 kPa = -22.21 inHg = -10.87 psig
24 kPa = -22.50 inHg = -11.02 psig
23 kPa = -22.80 inHg = -11.16 psig
22 kPa = -23.09 inHg = -11.31 psig
21 kPa = -23.39 inHg = -11.45 psig
20 kPa = -23.69 inHg = -11.60 psig
19 kPa = -23.98 inHg = -11.74 psig
18 kPa = -24.28 inHg = -11.89 psig
17 kPa = -24.58 inHg = -12.03 psig
16 kPa = -24.87 inHg = -12.18 psig
15 kPa = -25.17 inHg = -12.32 psig
14 kPa = -25.46 inHg = -12.47 psig
13 kPa = -25.76 inHg = -12.61 psig
12 kPa = -26.06 inHg = -12.76 psig
11 kPa = -26.35 inHg = -12.90 psig
10 kPa = -26.65 inHg = -13.05 psig
9 kPa = -26.94 inHg = -13.19 psig
8 kPa = -27.24 inHg = -13.34 psig
7 kPa = -27.54 inHg = -13.48 psig
6 kPa = -27.83 inHg = -13.63 psig
5 kPa = -28.13 inHg = -13.77 psig
4 kPa = -28.42 inHg = -13.92 psig
3 kPa = -28.72 inHg = -14.06 psig
2 kPa = -29.02 inHg = -14.21 psig
1 kPa = -29.31 inHg = -14.35 psig
0 kPa = -29.61 inHg = -14.50 psig
Re: Holley Sniper 440 timing question [Re: CSK] #2736331
01/24/20 10:43 PM
01/24/20 10:43 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
So I have got a lot of info from this thread. Do I need a Holley special cable to hook to the computer or a regular USB. Thanks
CALMED THE QUAKE!!!(AGAIN!)
Re: Holley Sniper 440 timing question [Re: CSK] #2736356
01/25/20 01:31 AM
01/25/20 01:31 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Just shy of 19.
Kevin
Where does the calculator go wrong? I have an app on my phone that comes up with the same answer.
18.92871914879627 inches of mercury.
Re: Holley Sniper 440 timing question [Re: Twostick] #2736357
01/25/20 01:37 AM
01/25/20 01:37 AM
Pattison Texas
Pattison Texas
Just shy of 19.
Kevin
Not sure, what I posted is off the Holley forum, it also matches my vacuum gauge.
Re: Holley Sniper 440 timing question [Re: Twostick] #2736358
01/25/20 01:52 AM
01/25/20 01:52 AM
AndyF Offline
AndyF  Offline
Just shy of 19.
Kevin
That is the conversion to pressure. Cab asked about vacuum. 64 kPa is 18 inches of pressure or 12 inches of vacuum.
Re: Holley Sniper 440 timing question [Re: Spyphish] #2736359
01/25/20 01:54 AM
01/25/20 01:54 AM
AndyF Offline
AndyF  Offline
The Holley cable is CAN on one end and USB on the other end. I don't think you can buy that cable from anyone other than Holley but I might be wrong. CAN to USB is an odd duck, you aren't going to find it in a local Radio Shack but you might be able to order one online. I wouldn't risk it myself, just order the Holley cable even though it is expensive.
Re: Holley Sniper 440 timing question [Re: AndyF] #2736426
01/25/20 10:18 AM
01/25/20 10:18 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
So I have the car running 10 start, 15 idle, 42 cruise and 35 WOT. Holley cable on the way and free software is on this laptop. When cable gets here hook it all up and start driving. NOW how do I "know" what it likes. For instance cruise as we adjust timing what do we look for,max Kpa reading? Thanks
These are dumb questions but all I know is SS/AH holley 600 vac secondary wide open for 8 seconds. Phish
Re: Holley Sniper 440 timing question [Re: AndyF] #2736444
01/25/20 11:24 AM
01/25/20 11:24 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Just shy of 19.
Kevin
A large detail I missed... confused laugh2
Thanks.
Kevin
Re: Holley Sniper 440 timing question [Re: Twostick] #2736468
01/25/20 12:20 PM
01/25/20 12:20 PM
Pattison Texas
Pattison Texas
Just shy of 19.
Kevin
Thanks.
Kevin
Originally Posted by Danny Cabral
Use conversion factor of .2953/29.53 @ 32°F or .2961/29.61 @ 60°F air temperature.
Convert MAP kPa to inHg (vacuum gauge): MAP kPa x .2961 − 29.61 = inHg Vacuum Gauge
Convert MAP kPa to psig (gauge): MAP kPa x .145 − 14.5 (slightly above sea level) = PSIG
Convert MAP kPa to psia (absolute with atmosphere): MAP kPa x .145 = PSIA
With PSIG, negative numbers are vacuum, and positive numbers are pressure.
With PSIA, all numbers are positive. The Holley EFI software uses kPa & PSIG.
The Holley EFI software uses kPa or PSIG (not PSIA). Here's an excellent pressure conversion calculator:
Re: Holley Sniper 440 timing question [Re: CSK] #2736482
01/25/20 01:05 PM
01/25/20 01:05 PM
AndyF Offline
AndyF  Offline
I skip all the math and just do it in my head. kPa is roughly a 0 to 100 scale. So 50 kPa is in the middle of the scale. Vacuum is 0 to 30 inches of hg. Middle of the scale is 15 inches of vacuum. So 50 kPa is 15 inches of vacuum. Once you know that you can figure out the rest.
Re: Holley Sniper 440 timing question [Re: Spyphish] #2736485
01/25/20 01:13 PM
01/25/20 01:13 PM
AndyF Offline
AndyF  Offline
First thing to do is to get the car running and warm up the engine so you can work on the hot idle. Once you have the engine warm you adjust the idle settings just like you would a carb. Slowly drop the idle speed and see how it does. Play with the ignition timing to see what it likes. Adjust the AFR to see what it likes. Adjust the throttle position to get the IAC into the correct location. It is exactly how you tune a carb engine except you don't have to change jets and mess with the distributor springs. You can do it all on the laptop by changing the values in the tables.
There are a bunch of Holley tuning videos on youtube so I'd suggest starting there if this is all new to you. It is like anything else. Once you know how to do it it is very simple but when you don't know how to do it it is intimidating. Watching a few videos will get you comfortable with the process of paging thru the menu and opening up the tables and stuff like that.
Re: Holley Sniper 440 timing question [Re: Spyphish] #2736489
01/25/20 01:20 PM
01/25/20 01:20 PM
AndyF Offline
AndyF  Offline
You aim for minimum kPa when tuning. kPa is pressure. You want to aim for maximum vacuum which is the opposite of pressure. Your idle pressure should be around 50 kPa on a well tuned engine with a modest performance cam in it. That is 15 inches of vacuum. A race car might idle at 70 kPa while a car with a stock cam will idle at 40 kPa. When you adjust the timing and/or the idle AFR you shoot for lower kPa. The other way to do it is to watch the IAC position. The IAC controls the idle air flow so what you want to do observe what is happening to the IAC position as you adjust the timing and the AFR.
Re: Holley Sniper 440 timing question [Re: AndyF] #2736695
01/26/20 02:09 AM
01/26/20 02:09 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On the IAC setting I like to get it at about 5 to 15 steps at idle with a warmed up eng in park. The steps will pick up a little in gear with an auto. You can adjust the throttle to set the IAC but you have to have timing at idle and all other settings set. If the IAC is at say 45 steps at warm idle you can turn the throttle blade open a bit more and watch the IAC steps come down. You don't want the IAC steps at 0 with a warm eng in park because then it may not catch the idle fast enough when you let off the gas since it can go to 0 steps. Once you set the throttle and the IAC then when you shut the eng off and restart it the controller will see the new TBS volts as idle since the TBS volts will change if you change throttle blade opening. Ron
Re: Holley Sniper 440 timing question [Re: 383man] #2736717
01/26/20 09:58 AM
01/26/20 09:58 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
My cable gets here Tuesday. Great info guys...
Re: Holley Sniper 440 timing question [Re: AndyF] #2736889
01/26/20 08:31 PM
01/26/20 08:31 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
BINGO
Re: Holley Sniper 440 timing question [Re: Mopar_Rich] #2737170
01/27/20 06:06 PM
01/27/20 06:06 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
I saved the ECU file to the SD card and it shows 4150_4_ZAA.sniper. The laptop sees it but not the V5 software, it will not recognize that file type. Guess I need to download the instructions. Phish
Re: Holley Sniper 440 timing question [Re: Spyphish] #2737207
01/27/20 07:22 PM
01/27/20 07:22 PM
AndyF Offline
AndyF  Offline
Your statement about V5 software leads me to believe that you loaded the wrong software on your computer. Delete the V5 software and load the Sniper software. You do not want to mix and match those two. Bad things will happen. I destroyed a $2000 Holley Dominator ECU by accidentally loading the wrong software on to it.
Re: Holley Sniper 440 timing question [Re: AndyF] #2737250
01/27/20 09:10 PM
01/27/20 09:10 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
This is a brand new engine so 1. I think your right on software, I am clueless. 2. I will (use the Wizard) and take it somewhere that has done this, probably not local. Stephen
Re: Holley Sniper 440 timing question [Re: Spyphish] #2737331
01/28/20 05:11 AM
01/28/20 05:11 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
I downloaded the Sniper software from Holley and was able to view the file I saved from the SD card out of the car. The spark graph was very "boxy" so I hit the smooth key about 3 times and saved it. Is that it? Stick it back in the car and run it? Thanks
Re: Holley Sniper 440 timing question [Re: Spyphish] #2737414
01/28/20 12:59 PM
01/28/20 12:59 PM
AndyF Offline
AndyF  Offline
Now you're rolling. Yes, you can smooth the timing map by hitting the smooth button a few times and then drive it. Maybe snap a picture of what the timing map looks like and post it on here. There is also a graph function on that table so you can view it graphically. There is a little rotation bar at the bottom of the picture so you can rotate the graph to look at it. What you want is a nice smooth graph without any sharp peaks or ledges or cliffs.
Page 2 of 3 1 2 3
