Re: Best ET with stamped rockers and hyd cam?
[Re: AndyF]
#2736877
01/26/20 07:45 PM
01/26/20 07:45 PM
Posts: 429 Washington
skrews
Washington
If that is the only rule then no reason you couldn't go 8's in a rail. Indeed, but I'm assuming that most people here are running production based cars.
[Re: skrews]
#2736981
01/27/20 08:23 AM
01/27/20 08:23 AM
Posts: 4,696 On the parachute mount
n20mstr
Like the title says, whats your best time with stamped rocker arms and hyd cam ? I'm sure plenty have been in the 12s and 11s, but anybody in the 10s or better? stock 440 (1968) home ported 906 heads. .509 cam with all stock valvetrain. 3600lb dart. went 10.70 of course it had a plate on it lol
....BAD A$$ STREET CAR.....
[Re: A39Coronet]
#2737112
01/27/20 03:28 PM
01/27/20 03:28 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A freinds roadrunnuer, full weight (3800?) 451 with a 268@ .050 race hydraulic went 11.47 through full 2 1/2 inch exhaust. I don't see why a bigger motor with a race hydraulic with as much as 276 @ .050 duration couldn't make 600 hp. I went 10.20s with iron 440-c bowl ported heads, 475 cubes, the same cam as my buddys 268@ .050 .540 lift but had indy dove rockers on it. 750 holley methanol carb. 3180 race weight. Take away a tenth or two for going to stock rockers and you have 10.40s?
[Re: A727Tflite]
#2737169
01/27/20 06:04 PM
01/27/20 06:04 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The rocker rule in Stock changed in 2012 iirc.
My friends Pontiacs had been well into the 10’s for several years by that time. That’s with a net lift at the valve of .410” The rule is .421”, but the stock rockers were never quite “1.5”.
He had the best longevity out of used factory rockers. He’d tested piles of them from used motors to get 16 with the closest to 1.5 ratio as possible.
[Re: fast68plymouth]
#2737248
01/27/20 09:09 PM
01/27/20 09:09 PM
Posts: 3,089 Michigan
A727Tflite
Gainesville 1978 actually. Then a week later at Darlington for the IHRA race. Great track and great air. Always wanted to run at Suffolk but never got the chance.
Now, 42 years later the fastest car in C/SA - Jason Line in his Buick went 10.0’s at Indy two years in a row.
Smokin’
[Re: A727Tflite]
#2737350
01/28/20 09:18 AM
01/28/20 09:18 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I went 10.60s in the 1/4 and 6.70s in the 1/8 with stock stamped rockers on a 440, 509 cam, in a 3700 lb car 18 years ago.
[Re: an8sec70cuda]
#2737433
01/28/20 02:25 PM
01/28/20 02:25 PM
Posts: 1,269 Denver, CO
BigBlockGTS
Denver, CO
I went 10.60s in the 1/4 and 6.70s in the 1/8 with stock stamped rockers on a 440, 509 cam, in a 3700 lb car 18 years ago. I believe you but would love to hear more about that combo and how you got there. That seems pretty quick for that cam and weight. Probably had a really good converter??
[Re: BigBlockGTS]
#2737675
01/29/20 12:21 PM
01/29/20 12:21 PM
Posts: 5,166 CT
GTX MATT
CT
I went 10.60s in the 1/4 and 6.70s in the 1/8 with stock stamped rockers on a 440, 509 cam, in a 3700 lb car 18 years ago. I believe you but would love to hear more about that combo and how you got there. That seems pretty quick for that cam and weight. Probably had a really good converter?? I want to hear about this one too!
[Re: GTX MATT]
#2737700
01/29/20 01:04 PM
01/29/20 01:04 PM
Posts: 16,523 On the run…
BloFish
On the run…
I went 10.60s in the 1/4 and 6.70s in the 1/8 with stock stamped rockers on a 440, 509 cam, in a 3700 lb car 18 years ago. I believe you but would love to hear more about that combo and how you got there. That seems pretty quick for that cam and weight. Probably had a really good converter?? I want to hear about this one too! Me three
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: A727Tflite]
#2737777
01/29/20 03:40 PM
01/29/20 03:40 PM
Posts: 8,337 fredericksburg,va
cudaman1969
fredericksburg,va
Smokin’
Can’t remember the name but a Duster in D went 9.96 awhile back, 340s are flying, hope to get mine going soon.
[Re: BloFish]
#2737782
01/29/20 03:49 PM
01/29/20 03:49 PM
an8sec70cuda
I went 10.60s in the 1/4 and 6.70s in the 1/8 with stock stamped rockers on a 440, 509 cam, in a 3700 lb car 18 years ago. I believe you but would love to hear more about that combo and how you got there. That seems pretty quick for that cam and weight. Probably had a really good converter?? I want to hear about this one too! Me three A 150 shot worked good on it, lol. It ran 11.40s at 117 mph on motor only. Had a 10" TCI streetfighter converter in it.
