Re: race distributor advance springs
[Re: Cab_Burge]
#2736690
01/26/20 12:30 AM
01/26/20 12:30 AM
Posts: 11,686 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Race deal with a big cam? I just lock it out so I don't have to make it idle 13-1500. 800 in gear.
[Re: johnzgarage]
#2736704
01/26/20 05:55 AM
01/26/20 05:55 AM
Posts: 4,457 Washington
madscientist
Washington
o.k. , anyone know what springs were used in a New chrysler Aluminium race distributor ? 1970's era IIRC, they were Mallory. You can find them at Summit but they ain't cheap.
[Re: cudaman1969]
#2737016
01/27/20 11:01 AM
01/27/20 11:01 AM
madscientist
Washington
those look exactly like the Mr. Gasket 925B springs Same springs hanging on the peg board at the speed shop, ONE company makes them all Do you happen to know which company that is? I've tried to find out who was making them but never could figure out who is making them. TIA
[Re: johnzgarage]
#2737044
01/27/20 12:32 PM
01/27/20 12:32 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Anyone know how to i.d. the correct advance springs , that came in the old m.p. race distributor 4120942 ? looks like i have one thats pink and one that has no color/paint marking on it. What springs came in that dissy for full/quick advance ? There may have been changes in springs used for the tach drive race distributors over the years, but if so, they would be small changes. Break out your calipers and magnifying glass. Measure the wire, the coil od. and the over length inside the loops. Spring______ Wire Dia. Coil O.D. Coils Spring Rate Length.Light Spring 1: 0.018", 0.230", 12.5, __1.26 #/in, 0.72" HeavySpring 2: 0.053", 0.293", _5.0, 174.41 #/in, 1.086" MP P2932675 Super Light pr: 0.015", 0.225", 11.5, __0.68 #/in, 0.7" The original combination was designed to: a. compensate for delays that made the effective timing retard in the higher rpms. b. provide easy restarting with high compression engine. I suspect the super light springs were originally for racing with dual point distributors.
[Re: Mattax]
#2737074
01/27/20 02:03 PM
01/27/20 02:03 PM
Posts: 427 saint paul mn.
johnzgarage
saint paul mn.
Anyone know how to i.d. the correct advance springs , that came in the old m.p. race distributor 4120942 ? looks like i have one thats pink and one that has no color/paint marking on it. What springs came in that dissy for full/quick advance ? There may have been changes in springs used for the tach drive race distributors over the years, but if so, they would be small changes. Break out your calipers and magnifying glass. Measure the wire, the coil od. and the over length inside the loops. Spring______ Wire Dia. Coil O.D. Coils Spring Rate Length.Light Spring 1: 0.018", 0.230", 12.5, __1.26 #/in, 0.72" HeavySpring 2: 0.053", 0.293", _5.0, 174.41 #/in, 1.086" MP P2932675 Super Light pr: 0.015", 0.225", 11.5, __0.68 #/in, 0.7" The original combination was designed to: a. compensate for delays that made the effective timing retard in the higher rpms. b. provide easy restarting with high compression engine. I suspect the super light springs were originally for racing with dual point distributors. Wow, VERY GOOD INFO !!!!!
[Re: johnzgarage]
#2737116
01/27/20 03:32 PM
01/27/20 03:32 PM
Mattax
Phila. Pa.
If you haven't seen the first before, its from the DC Engine Book. The second is a small block version of that distributor I ran on Sun 404. The heavy spring loop is part of the secret sauce that keeps timing steady or slightly rising depending on how quick the pulse amplifier is.
[Re: dragon slayer]
#2737373
01/28/20 10:53 AM
01/28/20 10:53 AM
Mattax
Phila. Pa.
Are you sure the value you give for the heavy spring lbf/in is correct? Yes. As a calculation anyway. Feel free to run the numbers. I subtracted 1/2 coil for active coils and used 11,000 K for elastic shear modulus. Measurements make a big difference when there are few coils. But as a comparison, it should be ballpark correct. When looking at the effect on the advance, its the rate multimplied by the distance moved. Because of the long loop, it doesn't extend much. And when used with light primary spring, it gets little assistance.
