Re: 1978 Dodge W150 windshield seal
[Re: cudagee]
#2734597
01/19/20 06:36 PM
01/19/20 06:36 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
I have bought them from Precision and Steele Rubber Products. Both are too small, check Precisions website for an installation video. Either way the buffoon I had install it couldn't figure it out and kept trying to tell me the opening was too big, What a freekin' idiot for someone that has been doing auto glass work for 30 years. Anyway he ended up cutting the seal at the bottom center and filling the 1.5" gap with urethane. I still have two Steele seals I'm going to use for my 74 and my 93 I just need to call the guy that actually knows what the hell he is doing. Bottom line is they are all too small and it takes special care and sealer around the lip and glass to get them to seal correctly. They still don't look original in the corners, especially at the bottom. So if anyone knows of a better fitting seal I am all ears.
EDIT Find a good glass guy, not a Safelite kid but someone that does hot rods and custom cars as well as exotics, Those are the guys you need.
[Re: Guitar Jones]
#2734602
01/19/20 06:56 PM
01/19/20 06:56 PM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
EDIT Find a good glass guy, not a Safelite kid but someone that does hot rods and custom cars as well as exotics, Those are the guys you need. So true. The glass guy that did mine was here 4 hours and got it done but told me never again on an old vehicle. Did the windshield, quarter glass, and rear window. He was pissed when he he left. Hard to find glass guys that know the old stuff.
[Re: dvw]
#2736225
01/24/20 05:39 PM
01/24/20 05:39 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
With the windshield out the welded pinch seam needs some prep work. It should be fixed if rusted out. then a few coats of sandable primer and sanded down so its smooth. Then the 3M paint on Butal rubber sealant painted on and dried, before the new gasket is slid on. I then slowly lift the gaskets edging and smeer some of the sealer under.
Now getting the glass back into the channel you will be able to use some of the language skills you leaned as a teenage kid. I used Rylube rubber lubricant in the past. A dull putty knife with the corners rounded over helps lift the gasket around the glass. Lots of fiddly work going back and forth to seat it all around.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Danny]
#2736562
01/25/20 04:46 PM
01/25/20 04:46 PM
Dave_J
Auburn WA
precision windshield seal worked in my 78, it is too small but if you get it good and warm and stretch it out a good bit it will work, not an easy task for sure This^^^ When I am mounting my own tires for my 650cc scooter I put the 155/65 14 Car tire in a oven I made to cure power coating. I set it at 100 Deg'sF for 25 minuets and it slides on the motorcycle rim so much easier.
