Re: my turn what will it run
[Re: Mr.Yuck]
#273583
04/01/09 04:35 PM
04/01/09 04:35 PM
13.20's...
yeah if it was a 340 car.
Your right a STOCK 340 with a good tune!!
#273584
04/01/09 04:41 PM
04/01/09 04:41 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
13.20's...
14.0's in an A-body..been there.
[Re: Mr.Yuck]
#273585
04/01/09 05:13 PM
04/01/09 05:13 PM
13.20's...
Like i said before its time for you to get a better engine builder/tuner
[Re: dustergirl340]
#273587
04/01/09 05:30 PM
04/01/09 05:30 PM
My stock stroke 340 with unported X heads, a 274 hydraulic cam and a little 650 Holley runs high 12's in a 3,600 pound A-body.
Thats what i'm talking about
#273588
04/01/09 05:43 PM
04/01/09 05:43 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
A buddy had a stock compression 440 with mild ported 452's, Comp 292 cam, SD intake, 750 DP, 2800 flash, 3.23 gear in a 3700ish lb b body. Ran 13.30s-13.40's.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: dustergirl340]
#273589
04/01/09 05:45 PM
04/01/09 05:45 PM
Quicktree
what did you do add 600#s to it never seen a 3600 pound duster
[Re: Quicktree]
#273591
04/01/09 06:13 PM
04/01/09 06:13 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
That's with me in it and a half tank of gas, and I don't weigh 600 pounds. It was weighed on a certified scale at the scrapyard too. It has a full interior, all metal body with the big chrome bumpers since it's a 1973. A/C car, sound deadening. It's a fat pig for an A-body.
[Re: Mr.Yuck]
#273592
04/01/09 06:51 PM
04/01/09 06:51 PM
Posts: 2,511 Tampa , Fl
MoparJoe
super gas
super gas
Tampa , Fl
Perfect conditions with an RPM and 850DP on it 12.0 @111, Six pack and average conditions- 13.40, maybe a 15.40 depending on how bad it bogs or spins.
There's some great running 6 packs out there but you can probably count them on both hands, I usually consider that car show stuff.
[Re: MoparJoe]
#273593
04/01/09 07:10 PM
04/01/09 07:10 PM
Mr.Yuck
Brookeville, Md
You must have some bad tuners there... I have friends that have run 11.80 and 11.75 in full street trim b-bodys w/ 440-6's and 509 cams...one swaped out the 509 for a 557 solid and dropped it to 11.70 spinning @ 119 in a 4 speed car.
the dart in question was a stock 340 "J" headed car w/ 3.55's and a 625...when I added a 750DP I got it to run 13.80. Ran out of cam around 5k.
[Re: 11secondC]
#273594
04/01/09 07:12 PM
04/01/09 07:12 PM
Mr.Yuck
Brookeville, Md
Fwiw...fresh zero deck 440 with the 528, 830DP, 452's cut for compression mild clean up, RPM, 4.10s and a 3800 stall, 3750 lb car went 12.50's. I'd say your close or better than that imo...
That's about what I'm hoping/thinking. I had a torker w/ a 750HP but hey the 6bbl looked nice..
[Re: Mr.Yuck]
#273595
04/01/09 08:24 PM
04/01/09 08:24 PM
Posts: 1,443 Maryland
Dads426
Maryland
Jeff,
I think you are close. Our combo was the similar; gear, convertor, motor had less cam (509; I know you hate them...), 10.0-1 compression, ported steel open chamber heads, 850DP, weight was 3350 w/o driver. 12.0's in hot sticky weather; 11.70's in good air. 70 Chargers are a sled (I think the front bumper weighs as much as the rear), so weight will be a big factor.
The squish heads will help prevent detonation, but I think you are on the edge without running a little race gas when you flog it.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#273596
04/01/09 08:50 PM
04/01/09 08:50 PM
Mr.Yuck
Brookeville, Md
Jeff,
actually I like the 509 with the right combo. They make good HP. It will have 110 in it at the track. The car should weigh around 3800 w/ me and gas. Remember it is missing some pieces
[Re: Kevins493]
#273599
04/01/09 09:36 PM
04/01/09 09:36 PM
Mr.Yuck
Brookeville, Md
12.30s in the 1/8th should be no problem...
what for your Challenger?
