2011 5.7 Recurrent cam code-P0344 #2734558
01/19/20 05:11 PM
01/19/20 05:11 PM
MI
68shifter Offline OP
MI
Wife’s 2001 Jeep GC Overland is driving me nuts. 130k on it. Valvoline synthetic since we owned it last 50k miles or so.
About Thanksgiving threw the p0344 cam code. Put a new standard motor sensor in it. I wasn’t able to relearn it with my solus so Cleared code and went away for 3-4 days then came back. Drove fine, no missing or limp mode. Every great once in a while traction control light would come on. Anyway took it to dealer. They tested it, said not a Mopar sensor and that’s the issue. They put a Mopar one in it. 3 days later light back on. Took it back and they put a new cam phaser sensor in it they said, same thing. They’re stumped.
I pulled front off the motor a little before Christmas. The guide on the timing chain was broke and broke a bolt off in the block. The cam reluctor appeared fine. I put a new cloyes chain on it, guides, sprockets, new oil pump and the cam reluctor.
Started perfect, runs fine. But 3-4 days later light back on. I put a different Mopar sensor in it thinking maybe a broken piece of the guide maybe hit the previous sensor. No change.
I’ve got 5V on one of the three wires to the sensor, a good ground and I’ve traced wiring back to pcm. Shook wiring etc and voltage and ground don’t fluctuate. I’m to the point I think it has to be a pcm? I can’t see it being a cam issue. I’ve tried to learn the cam/crank multiple times and still won’t do it. Tried a different scanner from my snap on guy and still nothing. I asked dealer if they attempted either time it was there and keep getting vague answers so I’m guessing no.
Any one with other thoughts? Thank you.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: 2011 5.7 Recurrent cam code-P0344 [Re: 68shifter] #2735254
01/21/20 12:41 PM
01/21/20 12:41 PM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
Re: 2011 5.7 Recurrent cam code-P0344 [Re: 68shifter] #2735462
01/21/20 11:56 PM
01/21/20 11:56 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
Not sure if you have checked it or not but low engine oil level will cause that code in that vehicle.
Re: 2011 5.7 Recurrent cam code-P0344 [Re: mod381] #2735485
01/22/20 02:39 AM
01/22/20 02:39 AM
MI
MI
Yeah levels good. It threw the code initially about 1500mi after an oil change but was still right to the top.
After I did all the timing work I changed it again as I had the pan off to get all the pieces. I changed to Mobil 1 now for the heck of it. We’re still driving. I’ll clear the code once a week or whatever. Hoping whatever it is just pukes totally and makes itself known.
Thanks for the video link. He had a misfire code though, I haven’t had one of them yet. Just the cam code. The LS motors do that crap all the time.
Re: 2011 5.7 Recurrent cam code-P0344 [Re: 68shifter] #2735686
01/22/20 09:10 PM
01/22/20 09:10 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
How is the code worded ? At the dealer we always used the DRBIII or the newer lab top but it would also read out the code and many times by what it said told me if it was an electrical of mechanical problem setting the code. I figure you mean its a cam sensor code. I don't know if your scanner reads it out but many times how the code reads out can guide you to electrical or mechanical problem. Good luck , Ron
Re: 2011 5.7 Recurrent cam code-P0344 [Re: 383man] #2736172
01/24/20 02:59 PM
01/24/20 02:59 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Check out the other sensors on that common 5 volt feed if memory serves me correct the oil pressure sensor shares the feed. If one of the other sensors pulls the 5 volt low it may trigger the fault. Fixed this fault on an early 5.7 by replacing the oil pressure sensor which was shorted.
Doug
Re: 2011 5.7 Recurrent cam code-P0344 [Re: dvw] #2736698
01/26/20 02:13 AM
01/26/20 02:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Doug
Doug is right as on many cars the AC pressure transducer also shares the 5 volt feed. I had an Intrepid once that would not start because that AC press transducer was shorting the 5 volt feed to ground. Ron
Re: 2011 5.7 Recurrent cam code-P0344 [Re: 383man] #2737086
01/27/20 02:26 PM
01/27/20 02:26 PM
montana
BANDIT Offline
BANDIT  Offline
montana
If I remember correctly, some scan tools can’t differentiate the cam and crank sensors. Might look at the one down on crank, I usually have a spare one laying around of both sensors just to pop in and try. They are real simple to change on pickups, GC could be harder to get to. Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: 2011 5.7 Recurrent cam code-P0344 [Re: BANDIT] #2737586
01/29/20 01:35 AM
01/29/20 01:35 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You are right as I remember in Chrysler training the teacher said sometimes even the PCM cant tell for sure and could set a cam sensor code when the crank sensor may be the problem and vice versa. At the Dealer we would recommend to replace both to be sure it was fixed. Ron
