Drilling thrust? #2734792
01/20/20 09:58 AM
01/20/20 09:58 AM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
Anybody ever drill a small oiling hole through the saddle and bearing on the thrust to keep wear down on a heavy clutch equipped combo? Thinking of doing this, as I’ve read about thrust problems with early hemi/ clutch combos. This particular engine has (more) modern 340 main bearings.
All thoughts and opinions appreciated.
Re: Drilling thrust? [Re: TRENDZ] #2734811
01/20/20 10:28 AM
01/20/20 10:28 AM
On the parachute mount
N
n20mstr Online content
n20mstr  Online Content
N
I never did this, but recently saw it on a youtube video. A turbo car and they are low budget. SO instead of the roller bearing machined in the front of the crank, they drill through the bearing to the passage. I thought it was a great idea to direct oil the face of the thrust bearing. they didn't say what size drill but I would think if you went too large, you could always drill the hole in the bearing smaller??
interesting idea
....BAD A$$ STREET CAR.....
Re: Drilling thrust? [Re: TRENDZ] #2734855
01/20/20 12:14 PM
01/20/20 12:14 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
I have done this many times when I was building big HEMIs. I also chamfered the thrust edge where the two shells meet in order to help spread the extra oil. It always seemed to work fine.
Re: Drilling thrust? [Re: TRENDZ] #2734868
01/20/20 12:35 PM
01/20/20 12:35 PM
Washington
madscientist Offline
Washington
Why are you running a "heavy" clutch? I can't think of any reason to run something like that. Just curious.
Re: Drilling thrust? [Re: madscientist] #2734876
01/20/20 01:01 PM
01/20/20 01:01 PM
Kirkland, Washington
Pacnorthcuda Offline
I disconnect the Clutch safety starter switch and make sure I DONT depress the clutch on starts. In my mind that’s plenty of precaution to ensure little to no thrust bearing wear.
Re: Drilling thrust? [Re: madscientist] #2734894
01/20/20 01:46 PM
01/20/20 01:46 PM
Milwaukee WI
TRENDZ Offline OP
TRENDZ  Offline OP
Milwaukee WI
Im not actually. I am running a high rpm launch program though, so i would imagine this would make the thrust happier. Just extrapolating off of the things I have read about heavy (meaning release pressure) clutches.
Mine will have a MCLEOD or RAM slipper.
Re: Drilling thrust? [Re: Mopar_Rich] #2734910
01/20/20 02:14 PM
01/20/20 02:14 PM
N
N
WHAT SIZE WAS THE HOLE DRILLED? AND SAME SIZE HOLE IN THE THRUST BEARING?
Re: Drilling thrust? [Re: n20mstr] #2734952
01/20/20 03:37 PM
01/20/20 03:37 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Wrong post.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Drilling thrust? [Re: Dave_J] #2735001
01/20/20 05:19 PM
01/20/20 05:19 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
Been doing this since the 70's on NHRA Stock eliminator small blocks.
Real Men shift for themselves
Re: Drilling thrust? [Re: TRENDZ] #2735058
01/20/20 08:13 PM
01/20/20 08:13 PM
The Great White North
RAMM Offline
RAMM  Offline
I do this on most Big and Small Mopars as well as Fords or anything with the thrust bearing on the number 3 main. It really helps especially with a manual trans application. I'm a believer. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Drilling thrust? [Re: TRENDZ] #2735080
01/20/20 10:11 PM
01/20/20 10:11 PM
Washington
Washington
Ok. A sintered iron set up is not what I'd call a heavy clutch. I have never drilled one, but there is nothing wrong with it. In fact, I probably should do it but since I've never had an issue (yet...knock on wood...probably screwed myself by saying that) I have never done it.
I can say it's a very good idea.
