73 Power Wagon floor pan question #2734442
01/19/20 12:33 PM
01/19/20 12:33 PM
Cleveland, Ohio
northcoastmopar Offline OP
Cleveland, Ohio
Not able to find a definitive answer in the parts book...Is the cover panel on the trans hump a factory arrangement? It looks like it is because there is a flange in the floor pan that the cover panel sits in.
If indeed it is factory are these the correct mounting bolts? I can’t imagine these are OEM style because they would stick up through the carpet?
Thanks in advance!
Re: 73 Power Wagon floor pan question [Re: northcoastmopar] #2734443
01/19/20 12:34 PM
01/19/20 12:34 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Definitely not on my '79 Power Wagon but I guess things changed
Facts are stubborn things.
Re: 73 Power Wagon floor pan question [Re: larrymopar360] #2734456
01/19/20 12:54 PM
01/19/20 12:54 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
My 78 has Phillip head screws. They are painted body color so I am assuming original.
Re: 73 Power Wagon floor pan question [Re: T2R9] #2734480
01/19/20 01:25 PM
01/19/20 01:25 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree...just wrong hardware
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 73 Power Wagon floor pan question [Re: T2R9] #2734481
01/19/20 01:29 PM
01/19/20 01:29 PM
Cleveland, Ohio
Cleveland, Ohio
Cool!
Do you know if there are u-nuts underneath that those Phillip screws go into?
Re: 73 Power Wagon floor pan question [Re: northcoastmopar] #2734487
01/19/20 01:43 PM
01/19/20 01:43 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Cool!
Square captive nuts as pictured.
Re: 73 Power Wagon floor pan question [Re: T2R9] #2734490
01/19/20 01:44 PM
01/19/20 01:44 PM
Cleveland, Ohio
Cleveland, Ohio
Cool!
Hmmmm, not sure what happened to mine. Thanks
Re: 73 Power Wagon floor pan question [Re: northcoastmopar] #2734507
01/19/20 03:03 PM
01/19/20 03:03 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
My 73 W200 also has large screws holding the hump down.
-Jon
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: 73 Power Wagon floor pan question [Re: blown340] #2734527
01/19/20 03:55 PM
01/19/20 03:55 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
So I guess '79 was a change over. I wish mine had removable tunnel.
Re: 73 Power Wagon floor pan question [Re: larrymopar360] #2734549
01/19/20 04:55 PM
01/19/20 04:55 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
if i remember right from my garbage motors days(chevy truck), the bigger truck had that removable tunnel and they used a "j" nut underneath and a foam seal to keep air and dirt out.
Re: 73 Power Wagon floor pan question [Re: larrymopar360] #2734706
01/20/20 12:31 AM
01/20/20 12:31 AM
Alberta
440_Offroader Offline
Alberta
Ya, my '79 doesn't have the removable tunnel piece either. Every other 70's 4x4 I've had, we're removable. I guess when they changed the hoods, they changed the tunnels too!
Re: 73 Power Wagon floor pan question [Re: 440_Offroader] #2747078
02/27/20 01:54 PM
02/27/20 01:54 PM
Washington, MI
Ashsdad Offline
Whatever you call me, my wife has called me worse.
Ashsdad  Offline
Washington, MI
I had both a '78 and '79 at one time thinking one would end as parts for the other. Oh, how wrong I was! For as similar as they looked, they were considerably different.
Re: 73 Power Wagon floor pan question [Re: Ashsdad] #2747098
02/27/20 02:22 PM
02/27/20 02:22 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I think when the big truck building ceased they decided to go with the one piece floor pan. All the big trucks had a different floor covers depending on drive line options. Old 2wd cabs had the lower flat one piece floor but also had an outline for the tunnel. I converted many 2wd cabs to 4wd with a doner tunnel.
Re: 73 Power Wagon floor pan question [Re: NITROUSN] #2747101
02/27/20 02:28 PM
02/27/20 02:28 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
My '72 W200 had the removable hump. IIRC, it had Phillips head screws that I had to drill out. Replaced them with button head hex screws.
Re: 73 Power Wagon floor pan question [Re: T2R9] #2747295
02/28/20 09:12 AM
02/28/20 09:12 AM
E
earlymopar Offline
earlymopar  Offline
E
When the captive nuts (called "cage nuts") are rusted or coated with undercoating, etc, they often require more torque to turn than what the cage will hold so they break free and are no longer usable. I have a 65' and replaced several of mine for the same reason. If the previous owner didn't know where to get them or had a better idea, they got replaced by what was available.
- EM
