Re: building a billet motor plate
[Re: Jerry]
#2802224
07/28/20 05:29 PM
07/28/20 05:29 PM
Posts: 16,546 On the run…
BloFish
On the run…
Incredible! What is the weight of that piece?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: RobR]
#2808583
08/13/20 06:41 PM
08/13/20 06:41 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Well, it fits. Jesel back plate retained with locating pins (Cerakote on the locating pin portion was a bad idea!): Then the motor plate: This is the belt cover/water pump back plate/cam sensor mount:
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: CJD AUTOMOTIVE]
#2808769
08/14/20 09:48 AM
08/14/20 09:48 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
That looks bad-donkey! Superb work.
[Re: TRENDZ]
#2808795
08/14/20 10:41 AM
08/14/20 10:41 AM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
Looks awesome. I can only imagine the time and money out into that deal.
[Re: Al_Alguire]
#2808801
08/14/20 10:52 AM
08/14/20 10:52 AM
Posts: 656 Florida
CJD AUTOMOTIVE
Thanks guys, yes lots of time and money.
They are stainless fasteners.
#2808854
08/14/20 01:23 PM
08/14/20 01:23 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
They are stainless fasteners. I say that because you will have bad galvanic corrosion from the dissimilar metals, You may want to stick with a chrome-moly, I would hate to see such nice work go to [censored] on account of the fasteners. It will be serious issue and it will not take long, Also consider a Sacrificial Anode to save parts also. Nice work for sure!
[Re: RATTRAP]
#2808875
08/14/20 02:28 PM
08/14/20 02:28 PM
Posts: 19,641 north of coder
moparx
They are stainless fasteners. I say that because you will have bad galvanic corrosion from the dissimilar metals, You may want to stick with a chrome-moly, I would hate to see such nice work go to [censored] on account of the fasteners. It will be serious issue and it will not take long, Also consider a Sacrificial Anode to save parts also. Nice work for sure! my thoughts as well. even using hi-temp anti-seize, galvanic corrosion will still be somewhat of an issue. as stated above, a sacrificial anode is a MUST. EXCELLENT machine work, to be proud of !
