A518 lock up Torque converter 3000+ stall. #2732333
01/12/20 01:18 AM
01/12/20 01:18 AM
Wi
Scat Offline OP
Scat  Offline OP
Wi
Looking to get more stall out of my current set up. Already have a 2800, who builds converters with lock up over 3000 stall. Current one is a PATC.
73 Duster 340 a518 6pack
Re: A518 lock up Torque converter 3000+ stall. [Re: Scat] #2732334
01/12/20 01:22 AM
01/12/20 01:22 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
PATC built mine, before I did some engine changes it flashed to 4200ish, with the Hilborn EFI it now flashes to 4750, it is a lock up, call them & they will build it to match your combo
Re: A518 lock up Torque converter 3000+ stall. [Re: CSK] #2735401
01/21/20 08:21 PM
01/21/20 08:21 PM
Cedar Lake IN
CRT Offline
CRT  Offline
Cedar Lake IN
my 518 lock up is about 3300 on the trans brake, I can use about 500 more.
This converter is a PTC. I have had Transmission Specialties do 9.5" lock up
converters for me.
Re: A518 lock up Torque converter 3000+ stall. [Re: Scat] #2735951
01/23/20 10:31 PM
01/23/20 10:31 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
off topic, how soon do you lock the converter in a pass?
Re: A518 lock up Torque converter 3000+ stall. [Re: mcat4321] #2735982
01/24/20 12:29 AM
01/24/20 12:29 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
These converters are for light throttle cruise,
