Re: Constant switched 12V C Body [Re: Sniper] #2732096
01/11/20 11:34 AM
01/11/20 11:34 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Not running yet. Storm "What'cha'ma'call'it" took out the power. Trying to finish tank and install. Get back to you soon. Thanks Phish
CALMED THE QUAKE!!!(AGAIN!)
Re: Constant switched 12V C Body [Re: Spyphish] #2732099
01/11/20 11:41 AM
01/11/20 11:41 AM
Andrews,In. U.S.of A.
67_Satellite Offline
I just hooked one up on my Satellite.8 injector Xflow. I connected the pink wireto the wire feeding the voltage regulator. This point on the 67 feeds directly from the ignition switch. Yes, the voltage will drop when the engine cranks, because that's the battery voltage at that moment. It works fine.
Re: Constant switched 12V C Body [Re: 67_Satellite] #2732240
01/11/20 07:36 PM
01/11/20 07:36 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Followed the instructions and she fired right up. SWEET. Unfortunately due to a faulty filler neck grommet at the tank, no test ride. Sounds wicked. Sniper, thanks for the relay setup. Lots of wires to clean up. Here is our tank mod. Thanks again. Stephen
Re: Constant switched 12V C Body [Re: Spyphish] #2732243
01/11/20 07:57 PM
01/11/20 07:57 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Excellent
Re: Constant switched 12V C Body [Re: Sniper] #2732256
01/11/20 09:02 PM
01/11/20 09:02 PM
New York
64 Sportfury Offline
New York
Thanks for further clarity.
Re: Constant switched 12V C Body [Re: BDW] #2732263
01/11/20 09:11 PM
01/11/20 09:11 PM
New York
New York
Totally confusing to me. But I am not an electrical genius.
Re: Constant switched 12V C Body [Re: Sniper] #2732381
01/12/20 09:26 AM
01/12/20 09:26 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
You have a PM. Thanks
Re: Constant switched 12V C Body [Re: Spyphish] #2733754
01/16/20 09:03 PM
01/16/20 09:03 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Runs GREAT!!! Monaco next. But we are pulling tank again to construct a baffle for low fuel performance (surges with only 5 gals in it). Also ignore the pic date, need to get my Grand Daughter to show me how to clear that. Phish
