Re: Opinions lifter choice [Re: nss guy] #2731393
01/09/20 12:21 PM
01/09/20 12:21 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I street alot in the summer season with 3 or 4 track weekends.I did get over 10k miles out of comp 848's that have been superceeded. My last rebuild I had 4 lifters go away rather quickly. So no more rebuilds for me,just buy new ones.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Opinions lifter choice [Re: hemi-itis] #2731556
01/09/20 07:56 PM
01/09/20 07:56 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks for the heads up . Much appreciated!
Re: Opinions lifter choice [Re: nss guy] #2731879
01/10/20 05:38 PM
01/10/20 05:38 PM
PA
moparacer Offline
moparacer  Offline
PA
Originally Posted by nss guy
I've been running the 829's in my 499 for the last 12 years. I've had a set rebuilt and replaced that set with new over that time period. No problems or failures in that time. My car runs low 10's and never sees 7000 rpm. Mild cam only .620 lift. fwiw
I had good luck with the 829s when I was running 10s with a smaller cam too. The whole going faster thing with bigger everything is where the problems started.
Quote
I should have included that info. It is an older cast iron RB World block . It is unbushed and yes I would like to but am on the fence about it . It’s another part of the budget I am balancing. It does currently use solid body solid rollers now. Oil pressure has been pretty good .
You will probably be a lot better off than I am. My block has huge holes in the lifter bores where the galley is drilled through.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Opinions lifter choice [Re: hemi-itis] #2732264
01/11/20 09:21 PM
01/11/20 09:21 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
What will you replace them with?
Re: Opinions lifter choice [Re: Wirenut] #2732268
01/11/20 09:26 PM
01/11/20 09:26 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Meant to call comp on Friday to see what the story is with their rebuild program as its all over their sales and instructional literature , and I, learning from folks that it’s no longer. My day ran out before I had a moment to.
Re: Opinions lifter choice [Re: Wirenut] #2732269
01/11/20 09:30 PM
01/11/20 09:30 PM
I put a set of Crower ultra full body lifters in my last pump gas street and strip motor after breaking several wheels on the Mopar brand lifters puke,
250+ Lbs. on the seats and 730 lbs. over the nose, shifted at 7000+ RPM for a lot of passes and 3000+ street miles in 8 yrs with no issues up I'm not sure if they still offer them but if they do I would buy another set in heart beat with no hesitations scope
Re: Opinions lifter choice [Re: Wirenut] #2732270
01/11/20 09:31 PM
01/11/20 09:31 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
At the PRI show the Comp guy told me that the vendor that they buy the parts from will no longer sell replacement parts. Comp will rebuild them till they run out of parts.
Re: Opinions lifter choice [Re: markz528] #2732378
01/12/20 09:02 AM
01/12/20 09:02 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks Mark. That’s too bad. Would seem like a good selling point.
Re: Opinions lifter choice [Re: markz528] #2732413
01/12/20 11:55 AM
01/12/20 11:55 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
At the PRI show the Comp guy told me that the vendor that they buy the parts from will no longer sell replacement parts. Comp will rebuild them till they run out of parts. [/quote]
Where do the parts come from to build their new lifters?
Doug
Re: Opinions lifter choice [Re: dvw] #2732421
01/12/20 12:24 PM
01/12/20 12:24 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Doug [/quote]
Right??? Thats I was thinking . And Im assuming the service wasnt free ??
Re: Opinions lifter choice [Re: Wirenut] #2732464
01/12/20 02:26 PM
01/12/20 02:26 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Maybe something else to consider, this is what I went with. Made by Morel
Re: Opinions lifter choice [Re: dvw] #2732469
01/12/20 02:48 PM
01/12/20 02:48 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Doug [/quote]
I asked that question. So best I can tell the vendor also makes the lifters. Just won't sell the parts separately anymore. They said they would continue to inspect them just won't be able to repair.
Re: Opinions lifter choice [Re: Wirenut] #2732484
01/12/20 03:40 PM
01/12/20 03:40 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Remember: as lift goes up, the spring rate needed to get the open pressure goes down (counter-intuitive).
Boffin Emeritus
