Re: Opinions lifter choice
[Re: Wirenut]
#2731056
01/08/20 11:53 AM
01/08/20 11:53 AM
fast68plymouth
So. Burlington, Vt.
Comp has done away with the lifter rebuild program.
Spring “rate” refers to the change in load over distance....... usually lbs/in.
So, 545 would mean a change of 545lbs in one inch. If you know the load with the valve closed, and the net max lift at the valve, you can calculate the theoretical open load.
Example, 220 closed and .685 lift. 545 x.685 = 373.3, add in the 220 = 593.3 open load.
[Re: fast68plymouth]
#2731076
01/08/20 01:28 PM
01/08/20 01:28 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
I have been very happy with Isky Red Zones over the years. They cost a bit more but IMO it is worth it in the end. I have never had a failure with them, even in my Camaro street car ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Having said that I have used the Comp solid body lifters in mild applications with decent success.
#2731086
01/08/20 01:59 PM
01/08/20 01:59 PM
Posts: 54 lansing mi.
e85mope
lansing mi.
Example, 220 closed and .685 lift. 545 x .685 = 373.3, add in the 220 = 593.3 open load. I talked to Chris Mayes @ the PRI. He told me they are going to continue the rebuild program for .904 dia. lifters. You might want to look into that.
[Re: Wirenut]
#2731097
01/08/20 02:14 PM
01/08/20 02:14 PM
Posts: 2,527 PA
moparacer
PA
What block are you using? If it is a stock unbushed block I wouldn't recommend them due to oil control. One problem I did have with them in a stock 400 block was the #2 and #4 cylinders on my engine poured oil out at max lift. Couple that with the fact that you are pressure feeding the rollers and IMO you need to have a bushed block to limit oil loss at the lifters. I got by with it last year but am having the block bushed right now.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: e85mope]
#2731104
01/08/20 02:29 PM
01/08/20 02:29 PM
fast68plymouth
So. Burlington, Vt.
Example, 220 closed and .685 lift. 545 x .685 = 373.3, add in the 220 = 593.3 open load. I talked to Chris Mayes @ the PRI. He told me they are going to continue the rebuild program for .904 dia. lifters. You might want to look into that. I had that conversation yesterday. They will continue with the Mopar lifters until the current supply of parts(axles, bearings, wheels) are depleted.
#2731113
01/08/20 02:45 PM
01/08/20 02:45 PM
Posts: 17,917 S.E. Michigan
ZIPPY
S.E. Michigan
Well, that's not exactly good news...part of my service strategy just went out the window.
Rich H.
Esse Quam Videri
[Re: moparacer]
#2731121
01/08/20 02:58 PM
01/08/20 02:58 PM
Posts: 277 MN
Willie68coronet
MN
Interesting, I was concerned I might have that issue so I primed the engine with the valley open. I have those lifters in my 440 with .650 lift and didn't have that issue.So those results vary. My oil pressure is pretty stable in the car, only drove around town a handful of times though. Sucks comp won't rebuild lifters in the future. I hope the lifters are tough, they look nice and I like the oil to the needles.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: Willie68coronet]
#2731122
01/08/20 03:01 PM
01/08/20 03:01 PM
fast68plymouth
So. Burlington, Vt.
Off the top of my head I can think of two customers running the Sportsman lifters in stock 440 blocks with no problems, in motors that see regular street duty.
#2731158
01/08/20 04:33 PM
01/08/20 04:33 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Off the top of my head I can think of two customers running the Sportsman lifters in stock 440 blocks with no problems, in motors that see regular street duty. Dwayne, That’s soon to be 3 customers in about another month or so. Steve’s 505. Only dyno time up to this time now. ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif)
#2731199
01/08/20 06:57 PM
01/08/20 06:57 PM
Posts: 2,527 PA
moparacer
PA
[/quote]
Sucks comp won't rebuild lifters in the future. I hope the lifters are tough, they look nice and I like the oil to the needles. [/quote]
.730 lift is what I have. They also dump a ton of oil out the feed holes to the rollers and that might be OK for some situations but not good in others.
#2731228
01/08/20 08:09 PM
01/08/20 08:09 PM
Posts: 630 Ct
Wirenut
Ct
Example, 220 closed and .685 lift. 545 x.685 = 373.3, add in the 220 = 593.3 open load. Thank you for the explanation and the formula. Greatly appreciated
[Re: Al_Alguire]
#2731229
01/08/20 08:14 PM
01/08/20 08:14 PM
Posts: 630 Ct
Wirenut
Ct
I have been very happy with Isky Red Zones over the years. They cost a bit more but IMO it is worth it in the end. I have never had a failure with them, even in my Camaro street car ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) Having said that I have used the Comp solid body lifters in mild applications with decent success. Al thanks for the advice and I do agree but it’s just not in my budget this year . I’m hoping it’s a solid plan to go with the comps and see if I can get them rebuilt every few years. I only put about 75 passes on it each season , G
[Re: e85mope]
#2731230
01/08/20 08:16 PM
01/08/20 08:16 PM
Posts: 630 Ct
Wirenut
Ct
Example, 220 closed and .685 lift. 545 x .685 = 373.3, add in the 220 = 593.3 open load. I talked to Chris Mayes @ the PRI. He told me they are going to continue the rebuild program for .904 dia. lifters. You might want to look into that. I will give them a call thanks for the heads up.
[Re: nss guy]
#2731240
01/08/20 08:28 PM
01/08/20 08:28 PM
Posts: 630 Ct
Wirenut
Ct
I've been running the 829's in my 499 for the last 12 years. I've had a set rebuilt and replaced that set with new over that time period. No problems or failures in that time. My car runs low 10's and never sees 7000 rpm. Mild cam only .620 lift. fwiw 75 or so at most . Track is too far and life has other demands . 20/50 in the summer , 10/40 in cooler months. Hot idle is about 40sh through the traps 60ish .
