Re: 1977 D100 heater core
[Re: scannman70]
#2731331
01/09/20 08:47 AM
01/09/20 08:47 AM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
I am told that one from a 1994 Chevy Silverado 1500 is dam close and can be made to work if you open up one hole, Have not tried it yet, But I read it on one of the truck forums I saw that on the Facebook Dodge Tin Grill forum. He just made one new hole, and everything fit great.
1981 Dodge D150 360 auto
[Re: basketcase]
#2731703
01/10/20 11:46 AM
01/10/20 11:46 AM
Posts: 8,504 Candler,NC / Myrtle Beach, SC
JDMopar
I used to have a 70 D200 with AC, and the heater core went bad in it. I tried to find one for it, with the same results as the OP. I took it out and took it to the place that did radiator work for me, and they ordered a new core,,,and just soldered my ends and pipes to it. Fit perfect and worked great.
[Re: JDMopar]
#2731972
01/10/20 09:32 PM
01/10/20 09:32 PM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
Had mine rodded and resealed.
Abe Lincoln
[Re: JDMopar]
#2732061
01/11/20 09:13 AM
01/11/20 09:13 AM
RWG75
RWG75
I used to have a 70 D200 with AC, and the heater core went bad in it. I tried to find one for it, with the same results as the OP. I took it out and took it to the place that did radiator work for me, and they ordered a new core,,,and just soldered my ends and pipes to it. Fit perfect and worked great. The answer of take it to a radiator shop has been out there for a while. The part that surprises me is nobody ever says "where am I supposed to find one of those"? I mean, it's not like there's a lot of them left. Any way, this post made the DIY light go on: I know how to solder copper pipe in the context of doing minor residential repairs. How hard could it be to transfer those skills to this problem and leave the shop fees out of it?
[Re: ]
#2732129
01/11/20 12:52 PM
01/11/20 12:52 PM
Posts: 15,938 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
^ That's why I wrote local rad shop, and if you don't have a good one send it off to Glen-ray. Who wants to do the job with some crappy chinese made one that you had to cut things up to make fit? And, it'll probably be leaking in a year!
Facts are stubborn things.
[Re: ]
#2732168
01/11/20 04:12 PM
01/11/20 04:12 PM
Posts: 10,644 Freeport IL USA
poorboy
Freeport IL USA
I used to have a 70 D200 with AC, and the heater core went bad in it. I tried to find one for it, with the same results as the OP. I took it out and took it to the place that did radiator work for me, and they ordered a new core,,,and just soldered my ends and pipes to it. Fit perfect and worked great. The answer of take it to a radiator shop has been out there for a while. The part that surprises me is nobody ever says "where am I supposed to find one of those"? I mean, it's not like there's a lot of them left. Any way, this post made the DIY light go on: I know how to solder copper pipe in the context of doing minor residential repairs. How hard could it be to transfer those skills to this problem and leave the shop fees out of it? Most of the heater core leaks I've seen were either on the core itself, or where the tubes connect to the core. If you have never soldered actual used heater cores or radiators before, I strongly suggest you practice on something that isn't very important. Fixing used heater cores and radiators that have had antifreeze run through them, and have been exposed to the elements for years is a different experience then soldering a copper pipe that you can easily clean. Then you need to devise a way to be able to leak test your work before, you have to assemble it into the box and reinstall it on the truck. Years ago, the last time I took a heater core to a radiator shop, all they wanted to do was order a new one. According to them, their success rate at repairing old heater cores wasn't very high. This was an experienced radiator shop. There is no longer any radiator shop withing 40 miles of here, that I know of. I would be interested to know how much the suggested radiator shop charges for repairing a heater core, and I would like to know where they are getting a copper replacement core. Any new heater core I've seen in the last 3-4 years have all been aluminum. Gene
[Re: JDMopar]
#2732180
01/11/20 04:46 PM
01/11/20 04:46 PM
JDMopar
I used to have a 70 D200 with AC, and the heater core went bad in it. I tried to find one for it, with the same results as the OP. I took it out and took it to the place that did radiator work for me, and they ordered a new core,,,and just soldered my ends and pipes to it. Fit perfect and worked great. Yeah.....I see that I left the part out about the above took place in 1985 or 86! DOH!! ![spank spank](/ubbthreads/images/graemlins/custom/spank.gif)
[Re: poorboy]
#2732219
01/11/20 06:52 PM
01/11/20 06:52 PM
Posts: 4,159 Canada -- Posts: 4034 -Registe...
5thAve
When I had mine done they had a couple catalogs that they ordered the core itself from. I think one was spectra premium. It was for a full size GM and even with it I couldn't find a new one. Or at least the ones you could get as replacements didn't fit and another was the universal kind that you can rotate the connections to the way you need them.. Thanks but I don't have trust in that not leaking. I've seen that black rubber dry and crack within a year. That shop is gone but at least we have one left around here that does that kind of service.
[Re: 5thAve]
#2732324
01/12/20 12:28 AM
01/12/20 12:28 AM
Posts: 954 garnett kansas
rhad
garnett kansas
i know a place that can make you a new core,you can either send them yours or tell them the size you need and solder the tanks on yourself,its different than working copper tubing big time i had a shop for 37 yrs,early on you could get complete copper cores,later on aluminum completes only
my ladder of success is missing some rungs
