Re: Color Coded Lock Nuts Tie Rod Sleeve Clamps
[Re: Morty426]
#2730758
01/07/20 11:35 AM
01/07/20 11:35 AM
Posts: 19,654 north of coder
moparx
if you look real close at the internal threads, are there traces of the color[s] there ? if so, that is a type of lock nut that uses nylon "pins" to ensure the nuts do not loosen up after tightening. i have seen those type of nuts used in many applications over the years. the "pins" come in any number of colors. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: gtx6970]
#2730932
01/07/20 10:00 PM
01/07/20 10:00 PM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
This fastener attribute is designated "P" type for nylon pellet. My car had P-nuts for gas tank straps and carrier to axle housing. There are also P-bolts: water pump, fuel pump, timing cover, and A/C compressor clutch to crankshaft.
[Re: Paul Jacobs]
#2731401
01/09/20 12:36 PM
01/09/20 12:36 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I am not one to assume, I know what that does...... I have three other cars here that have not been apart yet, 1970 models from other plants, including an A, C & another B body. I want to check them also just for fun. For the people here with original cars of other years / types that have not been apart before, it would also be cool to see what they find. ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: Alaskan_TA]
#2731456
01/09/20 02:49 PM
01/09/20 02:49 PM
Posts: 1,039 INDIANA
Paul Jacobs
INDIANA
Barry, Would you mind looking and let us know which end is what color? Thanks!!
[Re: Alaskan_TA]
#2731531
01/09/20 07:04 PM
01/09/20 07:04 PM
Paul Jacobs
INDIANA
I did that in my first post in this thread. ;-) Omg im stupid today-been running part numbers through the book all day and feel numb!
[Re: 44D6PAKCUDA]
#2773674
05/11/20 08:50 PM
05/11/20 08:50 PM
Posts: 1,453 N.W. INDIANA
moparjohn
N.W. INDIANA
The tie rod on the left is NOT an aftermarket part! First off it came in a original Mopar box with the hardware kit and has the assembly line grease fitting. I have added another picture here that shows the Mopar 207 2434 casting number. So if any one has more information on the boot or the tie rod end itself please come forward! Thanks! MJ
[Re: moparjohn]
#2773845
05/12/20 11:47 AM
05/12/20 11:47 AM
moparx
over the years, i have found ma mopar had many suppliers for items, so just because a tie rod end [this example] appears different than another while coming from identical boxes, does not mean the parts are not genuine mopar parts. and while i was not "on the line back then", i'm almost positive assembly line parts were at times, from different suppliers as well. two parts could be visually different from each other grabbed from the same bin at the same time, and installed on the vehicle in question. i base this on my machinist/supervisory career of 42+ years, as i saw this daily, depending upon the vendor. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
