Re: Motor flooding when not running
[Re: 6PAX]
#2729732
01/03/20 05:15 PM
01/03/20 05:15 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Needle & seat gummed up & sticking, time for a carb rebuild
[Re: @#$%&*!]
#2729831
01/03/20 09:47 PM
01/03/20 09:47 PM
Posts: 2,123 Byron, NY
W.I.N. Racing
Byron, NY
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Stanton]
#2729857
01/03/20 11:29 PM
01/03/20 11:29 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
The guy lives in Detroit, it hasn't been hot enough in 3 months to cause gas in the tank to swell that much !!
The liquid won't expand much either way, it's the air/vapor in the tank that tries to expand, pushing out whatever is in the way.
[Re: @#$%&*!]
#2729889
01/04/20 06:41 AM
01/04/20 06:41 AM
Posts: 8,916 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The liquid won't expand much either way, it's the air/vapor in the tank that tries to expand, pushing out whatever is in the way. Whatever, you missed the point ... it hasn't been that hot !!
[Re: @#$%&*!]
#2729924
01/04/20 11:27 AM
01/04/20 11:27 AM
Thumperdart
State of confusion
An unvented fuel tank can push gas past the needle/seat when the temperature goes up. Plugged bleeds can lead to a siphon effect in the carburetor but would affect how it runs. Is it rich? The AFB/AVS carbs aren't supposed to do this (leak below float level). THIS; Had an issue w/a billet 850ish carb I built for Shane Studly and his stocker Mopar wagon. Ran great till he topped off the tank then the pressure in the tank literally crushed the ft. brass float(which I no longer use in builds) sticking the needle n seat flooding the car to the point of filling the crankcase w/gallons of gas. Solution, He added a vent to the filler neck and problem solved.....Especially important w/an elec. fuel pump....
[Re: 6PAX]
#2732980
01/14/20 02:47 PM
01/14/20 02:47 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
[Re: 6PAX]
#2733335
01/15/20 12:50 PM
01/15/20 12:50 PM
Posts: 5,167 CT
GTX MATT
CT
Does it do it if the car isn't heat soaked? Sometimes the fuel will percolate after you shut it down as it has more time to absorb the heat, it can actually start to dribble out of the boosters, especially if the float is set on the high side.
