Someone is putting together a 'tour' of all 50 states. This isn't a Power Tour deal, just 'normal' travel. A lot of expectations are being set, I wonder how well it will really pan out?
The leg through Idaho they're showing misses the most beautiful parts of the State, which is the upper half. Likely the same can be said about other States, but I guess the trip can't take a year...
Same with Michigan. It goes through Detroit, then the capital Lansing (Detroit lite) then south to get the heck outta Dodge!
Same with WI. Into Milwaukee and then fly out to the Twin Cities. The most beautiful parts of the state are north.......and then not even touching the U.P. Absolutely gorgeous up there. For 30k you could put together your own tour of the states and hit some beautiful spots.
