Re: 74 Power Wagon hazard flasher question [Re: Guitar Jones] #2728675
12/31/19 09:03 PM
12/31/19 09:03 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Originally Posted by Guitar Jones
Originally Posted by larrymopar360
I did finally get home and check my '79. Flashes with key off, continues flashing when I turn key on, stops flash when brakes applied. My ammeter is bypassed.
Thanks Larry, my 92 is the same way.
You're welcome. Wish I could help more.
Facts are stubborn things.
Re: 74 Power Wagon hazard flasher question [Re: larrymopar360] #2728780
01/01/20 12:11 AM
01/01/20 12:11 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Don't you just love our old self healing Mopars. laugh2
Re: 74 Power Wagon hazard flasher question [Re: stumpy] #2728781
01/01/20 12:23 AM
01/01/20 12:23 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Son of Christine?
Re: 74 Power Wagon hazard flasher question [Re: stumpy] #2728804
01/01/20 02:53 AM
01/01/20 02:53 AM
Guitar Jones Online laugh2 OP
Well there has certainly been times when I seem to have had the "touch". laugh2
"Come get your wife"
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion.
Re: 74 Power Wagon hazard flasher question [Re: slantzilla] #2728805
01/01/20 02:53 AM
01/01/20 02:53 AM
Originally Posted by slantzilla
Son of Christine?
panic
Re: 74 Power Wagon hazard flasher question [Re: Guitar Jones] #2729011
01/01/20 03:10 PM
01/01/20 03:10 PM
N
NITROUSN Offline
NITROUSN  Offline
N
So I drove the truck a little the day I replaced the switch and repaired the dome light as well. Today I take it to the store and the hazards are working correctly key on and engine running also. I didn't do anything to repair this, it's just all working now. shruggy
Most likely the switch was not working correctly. The switch is sharing two separate flasher inputs. The contacts that separate the inputs must of been not able to fully separate the inputs. Thats why you were getting the flashers to work with the key. It was getting the turn signal power input and applying the 4 ways. If you removed the turn signal flasher the 4 ways would not of worked as the contacts were preventing the 4 ways battery supplied power from going through the switch.
