Re: A few question about the E MW victor head
[Re: fast68plymouth]
#2727647
12/28/19 12:11 PM
12/28/19 12:11 PM
Posts: 1,991 Apollo, PA.
B1MAXX
Apollo, PA.
Hit the 45 with a stone to widen it up a bit, hit the 30 to bring the outer edge in......probably only sink it .010-.015 or so.
Must be no one believes I know what I did with that head. I believe that there was a head with this done to it. . With a 60* below the 45* and a seat width of .059 to bring the 30* back up to the chamber would make it noticeably wide, like a quarter inch, which would be noticeable even with valve in. I have Serdi cutters used in a Bridgeport. I have made errors where I have made the seat to great of a diameter, much less than .050 and it takes a considerable cut to reduce the Dia. I believe and follow your knowledge but for that head to have been brought back to 2.200 I would think would stick out like a sore thumb. I'm out on this as well.
[Re: B1MAXX]
#2727652
12/28/19 12:35 PM
12/28/19 12:35 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
[quote=fast68plymouth]
I have Serdi cutters used in a Bridgeport. Can you post a picture of that setup? When I started looking for a mill my first requirement was that it be big enough to bolt a head to. I haven't invested in the hardware to cut seats.
[Re: B1MAXX]
#2727725
12/28/19 02:42 PM
12/28/19 02:42 PM
Posts: 14,502 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The one intake seat I cut would have had a .040 wide 45, with an OD of about 2.240. Without a doubt one seat was cut that way. What was done to facilitate the use of a 2.20 valve on that seat I have no idea. But after doing this as my job for 30 years, I can tell you it would not require excessive valve sinking to make that work. A few minutes with a couple of seat wheels and it would be good to go. for that head to have been brought back to 2.200 I would think would stick out like a sore thumb.
I have no doubt that had we seen pictures of all 8 intake seats with the heads all apart after cleaning and media blasting, it would have been no trouble pointing out which seat had at one point been cut for the 2.25 valve. There are options to get around the sunk valve if it were too objectionable....... one of which is to just replace the seat ring and start over.
[Re: @#$%&*!]
#2728013
12/29/19 02:34 PM
12/29/19 02:34 PM
B1MAXX
Apollo, PA.
I have Serdi cutters used in a Bridgeport. Can you post a picture of that setup? When I started looking for a mill my first requirement was that it be big enough to bolt a head to. I haven't invested in the hardware to cut seats. You'll need a 42" or 48" inch table...the 48 can tip when pushed to its outer limits though if not secured well to the floor. 2nd pic is some of the tooling
[Re: mopar dave]
#2728571
12/31/19 03:12 PM
12/31/19 03:12 PM
Posts: 8,041 Mt Morris Michigan
mopar dave
Mt Morris Michigan
One other thing I failed to mention was that the valley tray rail on the inside of the heads did not require machining after having .045" removed from deck side of heads. I have about .015'-.020" each side of tray. Billet tray fits just fine. What would be best way to seal this edge?
[Re: mopar dave]
#2728590
12/31/19 03:45 PM
12/31/19 03:45 PM
Posts: 1,030 ohio
67mprfan
ohio
After I had my Indy heads milled I went to local parts store and pick up a roll of gasket paper and a bead of silicone work great.
Then my buddy used a Indy valley tray with his Victor heads and filled in the gaps with just silicone after 3years now it's time to redo his
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
