Re: Clutch choice [Re: madscientist] #2727731
12/28/19 03:02 PM
12/28/19 03:02 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Actually the gentlemen that built the clutch said it would squeal a bit on the street and it was nothing to worry about. And it did it well before I ever put power to it. And it is like stepping on oatmeal, if you serve your oatmeal frozen. up
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Clutch choice [Re: 71TA] #2727854
12/28/19 09:36 PM
12/28/19 09:36 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Originally Posted by 71TA
I have a McLeod Street Twin in my 71 Challenger, 470", 600HP, aluminum Hemi 4 speed, Dana 3.54
Its the only clutch that would hold up. I went through 3 other setups. Only thing is it's, how do I say, grabby. If I'm not careful leaving a stoplight my car will launch 1/2 way through the intersection. Luckily the BB has enough torque to not stall if I release the clutch with very little throttle cause you can't really slip this clutch.
I'm very satisfied with it but I wouldn't throw the keys to just anyone to drive it smile
Are you using organic or miba lining?
I ran an organic street twin in a 9 second car years back and it was really smooth on the street. Would slip it at the track at 5k rpm no problem.
Re: Clutch choice [Re: INTMD8] #2728064
12/29/19 05:39 PM
12/29/19 05:39 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What about 4-10 gears, all other specs the same other than being a Hemi? Going down this road soon.
Sorry to hijack.
Re: Clutch choice [Re: cudaman1969] #2728262
12/30/19 11:15 AM
12/30/19 11:15 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Sorry to hijack.
Same here, I am leaning towards the RST.
Re: Clutch choice [Re: cudaman1969] #2728264
12/30/19 11:22 AM
12/30/19 11:22 AM
usa,pa
jkwedge540 Offline
jkwedge540  Offline
usa,pa
I am kinda in the same boat. Not sure what flywheel to run or clutch. I have a 500 inch making about 600 hp. 3700 pound car with 3.54 gears and a 18 spline trans. Mostly street driving with a few trips to the track. It has drag radials on it and cal tracks springs and bars.
Re: Clutch choice [Re: jkwedge540] #2728597
12/31/19 04:03 PM
12/31/19 04:03 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I am using the Mcleod Borg and Beck 3 finger. Mcleod doesn't make the pressure plate anymore(360153). I have a used pressure plate that Mcleod rebuilt and will be installing it next month. Passon Perf and Brewers sells Ram clutch kits. Both of them have had no issues with them so far.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Clutch choice [Re: 70sixpkrt] #2728619
12/31/19 05:16 PM
12/31/19 05:16 PM
Washington
madscientist Offline
Washington
Is that the Borg & Beck plate and cover with the Ford Lever? If so, that's a good set up if you make it adjustable.
