Thanks for the input
A friend of mine bought a set due to him needing more piston to head clearances on 440 towing truck motor with a belt driven centrifugal blower on it, those gaskets came with instruction to block off the two 1/8 steam holes in the block below the head alignment dowels and machine the deck square after putting in the dowels due to those gaskets not having those holes in them. I recommended getting a good hole punch kit and punch the holes in them and use them that way.
Those gaskets are for a 4.500 bore and .051 thick according to the info he found on the Fel Pro web site. His reverse domed pistons where .012 above the deck on the highest side and he wanted it to be safe at .035+ piston to head clearances.
He is building the motor now in SO CA and needs to tow his 24 ft. enclosed trailer with his wife Charger in it to their home in Georgia where he and his wife moved to earlier this year, They love living where they are now compared to living in congested SO CA for over 30 yrs, they both drag race and love working on their race cars together. I'm sure they will have a lot more choices on tracks to race at now
