ceramic coat headers clean up #2726221
12/22/19 07:30 PM
12/22/19 07:30 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Anyone know best way to renew the finish on my coated headers? The ceramic looks dark and dull. Was thinking about painting with high heat silver vht.
Re: ceramic coat headers clean up [Re: mopar dave] #2726235
12/22/19 08:10 PM
12/22/19 08:10 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Myself, I prefer the VHT aluminum and have had very good luck with it for years. Do be aware that surface prep is the key, But that is true with paint in general.
The only ceramic coating I've had good luck with was done by Jet Hot twocents beer
Re: ceramic coat headers clean up [Re: TJP] #2726240
12/22/19 08:20 PM
12/22/19 08:20 PM
Mt Morris Michigan
Mt Morris Michigan
So it is ok to paint over the ceramic coating?
Re: ceramic coat headers clean up [Re: mopar dave] #2726242
12/22/19 08:24 PM
12/22/19 08:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I wouldn't recommend it. unless your able to sand the surface(s). Having them media or sand blasted would be the way to go IMO beer
Re: ceramic coat headers clean up [Re: TJP] #2726245
12/22/19 08:31 PM
12/22/19 08:31 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
The ones on my race car were done maybe 25 years ago; a month or so ago, I cleaned them up with some light polishing compound (3M Finesse-It).
Re: ceramic coat headers clean up [Re: topside] #2726249
12/22/19 08:41 PM
12/22/19 08:41 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
If the ceramic coating is rough where it was burned off they will need recoated. But if just dirty or burned oil on them, use ZEP citrus cleaner and a brillo pad. Then Mothers aluminum polish. They will clean up quick.
Re: ceramic coat headers clean up [Re: nss guy] #2726320
12/23/19 08:19 AM
12/23/19 08:19 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
I've never been able to restore the "cooked" ceramic. I just take them off and re-coat them.
Re: ceramic coat headers clean up [Re: nss guy] #2726333
12/23/19 09:25 AM
12/23/19 09:25 AM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks for the info guys. I will try the zep clean up first with a scotchbrite pad.
Re: ceramic coat headers clean up [Re: mopar dave] #2726370
12/23/19 12:32 PM
12/23/19 12:32 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
chrome polish works good too. It will even clean up those ruff spots at the close to the head bends for the most part. I'm pretty sure I got this straight from my jet hot instructions that came with my headers.
Re: ceramic coat headers clean up [Re: B1MAXX] #2726372
12/23/19 12:49 PM
12/23/19 12:49 PM
A collage of whims
A collage of whims
Careful with the Scotchbrite, green is less aggressive than red.
You can try 0000 steel wool too, but blow off the debris.
Basically you don't want to be more aggressive than necessary.
Re: ceramic coat headers clean up [Re: mopar dave] #2726378
12/23/19 01:08 PM
12/23/19 01:08 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I was told by the vendor I use that it can be wet sanded and polished for maintenance/stain removal.I'm sure just a polishing compound for paint would work without sanding for maintenance. He also said the coating is dull when applied and is put in an abrasive tumbler to bring out the surface sheen.
RT
Re: ceramic coat headers clean up [Re: RTSrunner] #2726386
12/23/19 01:26 PM
12/23/19 01:26 PM
Mt Morris Michigan
Mt Morris Michigan
Mine has darkened in color as well.
Re: ceramic coat headers clean up [Re: mopar dave] #2726388
12/23/19 01:38 PM
12/23/19 01:38 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if you guys are going to try the steel wool thing then get the stainless steel stuff.
Re: ceramic coat headers clean up [Re: lewtot184] #2726405
12/23/19 03:12 PM
12/23/19 03:12 PM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
I recently read that the Lysol heavy duty toilet bowl cleaner works really good.
I believe it's the one with Lime and Rust cleaners then use a very fine scotchbrite pad.
Wally.
Re: ceramic coat headers clean up [Re: topside] #2726481
12/23/19 10:18 PM
12/23/19 10:18 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
I would try mothers polish first before using anything else. It always takes burnt oil off my headers and brings back the shine.
Re: ceramic coat headers clean up [Re: evenflow] #2726488
12/23/19 10:40 PM
12/23/19 10:40 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
i also seen on facebook using tolit bowl cleaner
Re: ceramic coat headers clean up [Re: dart games] #2726520
12/24/19 04:00 AM
12/24/19 04:00 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Fast Orange Hand cleaner. You already have some and it smells nice to. Todd
Re: ceramic coat headers clean up [Re: sasquatch] #2726566
12/24/19 11:41 AM
12/24/19 11:41 AM
Mt Morris Michigan
Mt Morris Michigan
Yes I do. I have used citrus cleaner with scotchbrite in the past and it works fairly good. Plenty of things to try here. thanks
Re: ceramic coat headers clean up [Re: mopar dave] #2727587
12/28/19 02:13 AM
12/28/19 02:13 AM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
This is what I was talking about
Re: ceramic coat headers clean up [Re: wkroncke17] #2727761
12/28/19 04:14 PM
12/28/19 04:14 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
But that's on non-ceramic coated stainless, right?
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
