Page 3 of 4 1 2 3 4
Re: Roller vs solid [Re: roadrunner2] #2726176
12/22/19 05:04 PM
12/22/19 05:04 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Originally Posted by roadrunner2
[Linked Image]Untitled by cudadude2, on Flickr
This is the intake that I'm currently using on my 451. I have a much improved one that I'm building now with an even better one planned after that if I continue to try to compete with an iron 4 Bbl. That one will require professional help and I prefer to keep my stuff my stuff.
My rockers are HS 1.6's.
Bill
Did you do any back to back testing with the dimpling; if so, what did you find?
Re: Roller vs solid [Re: parksr5] #2726194
12/22/19 06:04 PM
12/22/19 06:04 PM
CT
roadrunner2 Offline OP
CT
Bill
I didn’t. I doubt there’s anything in it. But I figured what the hell.
Bill
1968 Road Runner 383 727 3.91 8 3/4 3520 with driver 11.04 @ 124.26 with 1.67 60’
Done on G70-14 redlines thru factory manifolds New quickest ever 383 build in FAST.
10:1 451” replaced with 14:1 499”.
Re: Roller vs solid [Re: roadrunner2] #2726304
12/23/19 04:06 AM
12/23/19 04:06 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I recall when the OEM's went roller the commonly quoted number was 15 to 20 hp gain.
Those numbers are feasible for mass production but, for the $800 to $1000 investment to convert, I've always thought more power could be found else where and still be F.A.S.T. legal. twocents
For $1000 and just going off your signature, I'd ditch the 14's and go with 15's to increase your contact patch and you might still have money left over for fiberglass fenders.
Mo' Farts
Moderated by "tbagger".
Re: Roller vs solid [Re: Grizzly] #2726326
12/23/19 08:50 AM
12/23/19 08:50 AM
CT
CT
15" rims are not legal with a 383 build. Only available with Hemi in 68. Fiberglass is definitely not legal.
I have maybe 100 lbs left that I can pull off the car, and a better ignition system wouldn't hurt, but generally I think I have a good package.
Bill
Re: Roller vs solid [Re: roadrunner2] #2726336
12/23/19 09:32 AM
12/23/19 09:32 AM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Are you allowed to use the MSD Grid ignition? If so, you could probably gain some ET by slewing the timing and rpm to help get it going with skinny polyglass tires.
Re: Roller vs solid [Re: nss guy] #2726346
12/23/19 10:24 AM
12/23/19 10:24 AM
CT
CT
Yes there are a number of cars running a grid. At the moment my setup doesn't have the torque where I can't drive it off the line. My 60's are in the mid 1.7's which is pretty competitive.
It may be something I could look into for the future, but I'm more driver than tuner and like to keep my junk simple. I also want to win tho, so. ?
Bill
Re: Roller vs solid [Re: roadrunner2] #2726486
12/23/19 10:33 PM
12/23/19 10:33 PM
Bill
Time to stroke that puppy with a 4.25 stroke crankshaft devil scope up Take timing out on the starting line to improve your 60 ft. times ( with a grid system) and reaction times and then add it back in to make power scope up
Re: Roller vs solid [Re: Cab_Burge] #2726550
12/24/19 11:14 AM
12/24/19 11:14 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
I prefer the 4.25 over the 4.15 as well.
Re: Roller vs solid [Re: fast68plymouth] #2726559
12/24/19 11:25 AM
12/24/19 11:25 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
While you are at it break out the money bucket and do an LS firing order. I'm still having sticker shock over that one!
Re: Roller vs solid [Re: Jeremiah] #2726565
12/24/19 11:40 AM
12/24/19 11:40 AM
So. Burlington, Vt.
So. Burlington, Vt.
If it’s not a commonly available core, it has to be made out of a piece of bar stock as a one-off.
Re: Roller vs solid [Re: Jeremiah] #2726577
12/24/19 11:59 AM
12/24/19 11:59 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Benefits (other than a lighter wallet)?
Re: Roller vs solid [Re: BradH] #2726622
12/24/19 01:39 PM
12/24/19 01:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
Imo, in that combo........without testing it back to back........ I’m not sure it would be worth anything.
For sure........ it would be way way down the list of things I would prioritize money being spent on for that application....... unless I could see decent test data where it was worth enough power to justify the expense.
“The test”........ to see just how bad the intake manifold is hurting the power is to try a Performer RPM against the modded stock piece.
I think it would show you where one might need to concentrate the time and $$$.
Of course, if the difference was only 10-15hp........ then I’d be more willing to spend the resources somewhere else.
On my lowly 383 with stock heads, the RPM was about 25hp over a stock 301 intake.
I’m thinking on a 499/511 with ported heads, the difference could be more.
Tested on consecutive days, two very similar stroker combos running the same ex manifolds....... one with a ported 301, the other with a 6bbl..... the difference was over 60hp.
Re: Roller vs solid [Re: Cab_Burge] #2726634
12/24/19 02:56 PM
12/24/19 02:56 PM
CT
CT
A little before and after of my current project intake.
Bill
Re: Roller vs solid [Re: BradH] #2726635
12/24/19 03:01 PM
12/24/19 03:01 PM
AndyF Offline
AndyF  Offline
It will sound like a SB Ford!
(I tested firing orders on my race engine and never saw any difference. My take on the subject is that firing order might matter for NASCAR, F1 and Indy cars. Not sure it matters to anyone else.)
Re: Roller vs solid [Re: roadrunner2] #2726641
12/24/19 03:16 PM
12/24/19 03:16 PM
So. Burlington, Vt.
So. Burlington, Vt.
Bill, how were what I assume are flow numbers taken on the orange intake?
Re: Roller vs solid [Re: fast68plymouth] #2726662
12/24/19 04:29 PM
12/24/19 04:29 PM
CT
CT
I don’t know. Pic from the Internet.
Re: Roller vs solid [Re: roadrunner2] #2726858
12/25/19 05:19 PM
12/25/19 05:19 PM
Oh
P
parksr5 Offline
parksr5  Offline
P
Oh
Bill
Did you sub-contract this one out or, are you doing to work on this one too?
Re: Roller vs solid [Re: parksr5] #2727009
12/26/19 10:39 AM
12/26/19 10:39 AM
CT
CT
Bill
I'm doing it all myself.
Bill
Re: Roller vs solid [Re: AndyF] #2727031
12/26/19 11:37 AM
12/26/19 11:37 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I thought a big plus was that it made the crank happier?
Re: Roller vs solid [Re: jcc] #2727064
12/26/19 01:51 PM
12/26/19 01:51 PM
I've heard that also, I haven't built a motor with that option yet either yet so confused
I have laid out all the firing orders possible with stock Mopar V8 crankshafts and I couldn't find one that didn't end up having two cylinders side by side firing order more than 90 degrees apart by changing the cam shaft lobes confused work
Ford and Pontiac V8 motors don't use the same crankshaft rod throw arrangements like Mopar and Chevy do shruggy
Page 3 of 4 1 2 3 4
