speedy ring break in
#2725488
12/19/19 10:12 PM
12/19/19 10:12 PM
Posts: 13 edmonton alberta canada
500dart
what do you use to prelude cylinders for break in? Some use wd-40, dino based motor oil , transmission fluid, total seal quick seat, ect.
Re: speedy ring break in
[Re: dvw]
#2725587
12/20/19 11:10 AM
12/20/19 11:10 AM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
Not sure if you have time to get the Total Seal Quick Seat stuff but if so, I'd check into it. So easy a caveman like me could do it. Clean cylinder walls, then WD40. Put some of the powder on a finger and burnish in, turns a goldish/green color, little bit goes a long way. Install pistons/rings. Turn the crank over a few times and the rings are seated.
'71 Duster '17 Ram 1500
[Re: 500dart]
#2725605
12/20/19 12:04 PM
12/20/19 12:04 PM
Posts: 3,510 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
This is what Bill Miller Engineering thinks about the subject:
WARNING EXTREME DANGER Do not use WD40,automatic trans fluid,kerosene, or any other lightweight rust preventatives for engine assembly. These are not lubricants. These products will ruin the cylinder walls, they will ruin the face of the piston rings, and they will ruin the skirts on the pistons.
USE ONLY HIGH QUALITY PETROLEUM BASED ENGINE OIL(NO SYNTHETICS).Apply engine oil to the piston skirts, cylinder walls. pin holes and pins, and a light film on both sides of the piston rings
I have this actual notice that came with some pistons around somewhere but I found this from a post Moparts member mafo had posted earlier.
[Re: 500dart]
#2725634
12/20/19 01:22 PM
12/20/19 01:22 PM
Posts: 235 Central Mississippi
mopar97
Central Mississippi
After I am satisfied the engine and parts are clean I dunk the piston ring assembly into an empty coffee canister full of oil. I then install the pistons. That is all I do. No failures yet in 40 years of building engines. Yes, it is messy. As far as a break-in procedure? Follow the ring manufacturers' instructions. I have built an engine today and raced it tonite and had no issues either. IS a break-in on a race engine necessary?
Mopar born, Mopar breed, when I die, call me Mopar dead!
[Re: 340Cuda]
#2725638
12/20/19 01:45 PM
12/20/19 01:45 PM
Posts: 9,835 MI, usa
dvw
MI, usa
I have this actual notice that came with some pistons around somewhere but I found this from a post Moparts member mafo had posted earlier. It's amazing my engines even run. You'll notice WD 40 is applied on the cylinder wall only. No where else. This info came from Roush. Current race motor has 330+ passes. Doug
[Re: 340Cuda]
#2725642
12/20/19 01:59 PM
12/20/19 01:59 PM
RMCHRGR
Spahn Ranch
Do not use WD40,These are not lubricants. WD40 is not a lubricant? I was skeptical of the Quick Seat stuff too so I called Total Seal about it. They were the ones who told me to use WD40 with it.The powder is actually the lubricant, the WD40 just helps to distribute it in a sort of paste form which basically keeps it from flaking off.They also told me specifically not to dunk the rings in oil. Maybe the BM warning is them just saying don't use it as the only method of lubrication? That would make sense.
[Re: RMCHRGR]
#2725644
12/20/19 02:14 PM
12/20/19 02:14 PM
Posts: 4,457 Washington
madscientist
Washington
Regardless of what Bill Miller says (I agree with most of it) you never ever put oil on a pistton ring.
This has been hashed out many times. You'll always have those who dunk the entire piston ion oil, those who squirt oil on the rings and those who load the cylinder walls with oil before assembly.
Clean the bores until a lint free white cloth comes out clean. Find a QUALITY assembly lube. Put a small amount of that lube (it will NEVER be a paste) on the skirts until there is a thin coat on both sides of the skirts. It doesn't need to be running off on the floor. Just a thin coat.
Then assemble.
By the time you are done, you'll notice a light film of assembly lube on the bores. The rings will be so close to being seated the job is done.
No reason to oil a piston ring let alone drown them in oil. Just a waste and it makes getting the rings seated much more difficult.
[Re: SportF]
#2726003
12/22/19 01:26 AM
12/22/19 01:26 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Transmission fluid only for me. Start it, load it in the trailer, and a full bore pass down the track, and race it.
[Re: B1MAXX]
#2726104
12/22/19 01:39 PM
12/22/19 01:39 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I think a good take away from this if you put something mildly slippery on the rings and start the engine the rings will seat in short time.
68 Barracuda Formula S 340
[Re: B1MAXX]
#2726122
12/22/19 02:17 PM
12/22/19 02:17 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
Correct finish and moly rings require no break in , per the ring mfg's. Lube as you like. I use to dip the piston into a 3 lb. coffee can full of oil and ATF mix, I now squirt the same mix onto the rings in the ring lands and spin the rings around to make sure their lube well and wipe the excess off onto the piston skirts. I do wipe the cylinder walls off with white paper towels multiple times while assembling the motor and when degreeing the cam I do use the same lube on the wrist pins and piston pin bores to lube them also
[Re: Cab_Burge]
#2726157
12/22/19 04:24 PM
12/22/19 04:24 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Correct finish and moly rings require no break in , per the ring mfg's. Lube as you like. I use to dip the piston into a 3 lb. coffee can full of oil and ATF mix, I now squirt the same mix onto the rings in the ring lands and spin the rings around to make sure their lube well and wipe the excess off onto the piston skirts. I do wipe the cylinder walls off with white paper towels multiple times while assembling the motor and when degreeing the cam I do use the same lube on the wrist pins and piston pin bores to lube them also This is my method as well. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#2726180
12/22/19 05:13 PM
12/22/19 05:13 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I used to dip the pistons on oil to lube up the rist pins and to make sure the pistons had oil when they went into the cylinders upon assembly. Then maybe 20 some years ago someone stated to use WD40 for quick ring break in , I never had a problem with ring break in with the oil bath but I have used the WD40 from then on as it was not as messy with no problems. I even spray some in the cylinders before the heads go on . My thinking is to keep the cylinders somewhat wet as most will not be fired right away.
