Page 3 of 3 1 2 3
Re: Fuel atomization: Carb vs. EFI [Re: Cab_Burge] #2725363
12/19/19 12:01 PM
12/19/19 12:01 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Originally Posted by Cab_Burge
Originally Posted by Gavin
There's really no debate to be had on which technology atomises better. You've had at least two people who have worked in the industry say the same thing (Mr P Body and myself). Higher pressure gives better atomisation. EFI is ALWAYS higher pressure therefore, leaving the carb or injector, better atomisation, every time, period.
Per my original reply - what you do with it after that is getting a lot of good discussion here, but there's no uncertainty about which device atomises better.
I am still in doubt about which system, EFI or a dual quad tunnel ram set up, is better for a all out drag race motor work shruggy Hence NHRA Pro Stock not going faster now with EFI than they did with dual carbs on a tunnel ram intakes work
I remember several different mechanical fuel injector companies testing the location of the injectors heights in there all out race set ups for dirt and asphalt track roundy round all out race cars work
My understanding is that the higher up you can place the injector the more power you can make, downside is they are a little harder to dial in for street driving with the injector way up the intake.
It would have been interesting to see what happened with pro stock if the EFI conversion didn't require the loss of the scoops and tunnel rams. Holley makes a 4500 bolt pattern throttle body that is 2500CFM, a pair of those on a tunnel ram would be fun.
68 Barracuda Formula S 340
Re: Fuel atomization: Carb vs. EFI [Re: Gavin] #2725372
12/19/19 12:28 PM
12/19/19 12:28 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If EFI is so much better(which I don't believe it is in every case)then why did Pro Stock slow down across the board. Plus there's some well known heads up racers I know that sold there's and went BACK to carbs and picked up LOTS of power......My opinion on the 2 places it shines, 1, on our daily drivers get to work stuff and 2, super high end high power(2000+hp)stuff but in between that carbs shine and I've been part of it personally...........
Re: Fuel atomization: Carb vs. EFI [Re: Thumperdart] #2725390
12/19/19 02:22 PM
12/19/19 02:22 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Pro stock didn't just swap to EFI, they also got a 10,500 RPM limit, lost the scoop, and run a spec throttle body and intake tube.
Not to say that the carb still wouldn't make more power but I feel it would be MUCH closer or equal had they got to keep the tunnel rams.
Re: Fuel atomization: Carb vs. EFI [Re: Gavin] #2725441
12/19/19 07:18 PM
12/19/19 07:18 PM
Aus
hysteric Offline
hysteric  Offline
Aus
But does that mean that it produces a better homogenized mixture?
Re: Fuel atomization: Carb vs. EFI [Re: hysteric] #2725443
12/19/19 07:38 PM
12/19/19 07:38 PM
AndyF Offline
AndyF  Offline
Exactly. When I look down the throttle bores of a Sniper it drools big drops of fuel into the intake manifold just like a carb does. The injectors in a Sniper do not spray fuel into the intake which is what most people seem to be assuming.
Re: Fuel atomization: Carb vs. EFI [Re: AndyF] #2725447
12/19/19 07:50 PM
12/19/19 07:50 PM
Aus
hysteric Offline
hysteric  Offline
Aus
Originally Posted by AndyF
Originally Posted by MoonshineMattK
Can anyone please explain how a carb atomizes fuel better than fuel injection.
For the sake of my question both the carb and fuel injection are tuned properly.
I don't think anyone on this thread knows the answer to that question. That is a very complicated technical question and nobody would be able to prove it one way or the other without a lab full of equipment. A carb works opposite of injection so the behavior is totally different. In a carb the low pressure area in the venturi sucks the fuel out of the bowl. The pressure differential in a carb is only 5 or 6 psi while an injector operates around 50 psi. The metering block in a carb adds air bubbles to the fuel which helps. There is no air bubble system in an injector.
If someone really wants to know the answer to this question they would need to talk to an injector engineer at Bosch. My guess is that they know how to measure it and and could explain it.
My understanding is that a 5 gas analyzer would tell you how the fractions are being converted. What happens to the flame front when the mixture isn't ideally homogenized? Just because you atomize fuel doesn't mean the mixture is ideal at the time of ignition. I'm no expert but maybe the question of atomization is just one part of the puzzle.
Maybe a thorough reading of Ricardo's work might shed some light on the matter
Re: Fuel atomization: Carb vs. EFI [Re: AndyF] #2725448
12/19/19 07:54 PM
12/19/19 07:54 PM
Aus
hysteric Offline
hysteric  Offline
Aus
Would be interesting to make a clear manifold and actually see the differences in fuel delivery between a Holley a Carter TQ/Rochestor Qjet and a Sniper.
Re: Fuel atomization: Carb vs. EFI [Re: Thumperdart] #2725452
12/19/19 08:05 PM
12/19/19 08:05 PM
Aus
hysteric Offline
hysteric  Offline
Aus
Had this discussion with a friend about the difference in performance of efi and carbs and he told me about his mate who went from a well tuned Rochester Qjet to an expensive injection system and only gained 3 foot pounds of torque in the mid range and nothing at the top all measured on the dyno. He did say the only real benefit was when starting it cold it idled better. From memory it cost him 3K to convert over so not exactly bang for buck.
Re: Fuel atomization: Carb vs. EFI [Re: AndyF] #2725453
12/19/19 08:05 PM
12/19/19 08:05 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I still have some tuning to do, because self tuning EFI is more of a selling point & not a true reality, but the EFI HILBORN 8 Stack I have on my Street Strip car is AWESOME, Individual runners, so the low vacuum, drivabilty issues from a large duration cam are gone, cam is a hyd roller 255, 258 @ .050 & it idles like a stock 440 & drives just as smooth. a carb on a common plenum intake CANNOT do what this EFI set up does, also I can change runner length to tune for power @ different RPM's, as I said earlier I can run much leaner without lean misfires, that tells me better fuel atomization & Obviously better fuel distribution than my ported Indy SP intake. Will keep Y'all updated on my progress at the track.
Re: Fuel atomization: Carb vs. EFI [Re: Bad340fish] #2725460
12/19/19 08:24 PM
12/19/19 08:24 PM
Washington
madscientist Offline
Washington
The RPM limit didn't hurt the GM architecture.
The hood scoop was on of the MOST cried about pieces of a Pro Stock car ever. WJ sniveled about them for years and claimed a huge gain in MPH if the big "mail box" was gone from the car.
EFI retarded Pro Stock in more than one way.
Re: Fuel atomization: Carb vs. EFI [Re: madscientist] #2725468
12/19/19 08:51 PM
12/19/19 08:51 PM
Washington
hemienvy Online content OP
hemienvy  Online Content OP
Washington
AndyF,
I had no idea the Sniper was a "drooler" not a "fogger" !!
To me, EFI should not only meter fuel, it should also atomize it.
Re: Fuel atomization: Carb vs. EFI [Re: hysteric] #2725530
12/20/19 02:05 AM
12/20/19 02:05 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
A buddy of mine in the R&D biz did that years ago. First thing he learned was that fuel staying in suspension in a wet manifold is basically a myth. There is a cloud of it directly under the carburetor and then 90% of it goes directly to the floor of the intake manifold.
Kevin
Re: Fuel atomization: Carb vs. EFI [Re: Twostick] #2725541
12/20/19 08:09 AM
12/20/19 08:09 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Atomization does not necessarily = more power.
Direct injection (nozzle exits directly into intake runner bowl) does not make the most power of FI configurations, for a traditional V8 engine.
Google "Darin Morgan wet flow test" and there is a link to a gearhead podcast where he's interviewed for about an hour. One of the topics is FI nozzle placement, in which he talks about why Sprint Cars ended up running both direct injection for improved throttle response AND additional injectors farther upstream in the runners, because the upstream location is more flexible in its tuning parameters and makes more power at high(er) RPM.
Re: Fuel atomization: Carb vs. EFI [Re: BradH] #2725552
12/20/19 09:01 AM
12/20/19 09:01 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I never heard of direct injection above the valve. Direct injection has always been in-cylinder nozzles at extremely high pressures. Port injection, as used on sprint car engines generally have the nozzles entering the port from the exhaust side of the head, straight into the bowl. Other than the clarification, I think you/ he is spot-on. The higher the rpm range, the farther away from the intake valve the injector should be. F1 engines live life way above 10,000 rpm. They have had injectors at great distances for years.
Re: Fuel atomization: Carb vs. EFI [Re: TRENDZ] #2725566
12/20/19 09:45 AM
12/20/19 09:45 AM
BradH Offline
BradH  Offline
Yes, that's what I mean; I'm not familiar with all the correct terminology. up
Re: Fuel atomization: Carb vs. EFI [Re: BradH] #2725628
12/20/19 01:07 PM
12/20/19 01:07 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
https://www.youtube.com/watch?v=y2iBbwocYZw
this is how the most expensive highest tech engines are done
Re: Fuel atomization: Carb vs. EFI [Re: Twostick] #2725706
12/20/19 07:11 PM
12/20/19 07:11 PM
Aus
hysteric Offline
hysteric  Offline
Aus
I would imagine the "Mist" component could change direction very quickly to go to the cylinder with the opening valve. It would be harder for the fuel on the walls of the manifold to change direction.
Anyway a heated manifold would help vaporize some/most of the fuel on the walls and floor of the intake helping it find its way into the cylinder in a better state than liquid.
Re: Fuel atomization: Carb vs. EFI [Re: BradH] #2725708
12/20/19 07:14 PM
12/20/19 07:14 PM
Aus
hysteric Offline
hysteric  Offline
Aus
Well known road race car here in Australia had the injector nozzles mounted before the entrance of the IR trumpet.
Re: Fuel atomization: Carb vs. EFI [Re: Bad340fish] #2725723
12/20/19 08:38 PM
12/20/19 08:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I remember they changed a few things but most interviews I saw it seemed the drivers/tuners preferred carbs and a forward scoop plus I'm sure singing the HEMI'S way up is missed as well...........I saw the spec sheet on Erica Enders carbs and it was quite eye opening..........
Page 3 of 3 1 2 3
