Re: .020 400 block question
[Re: rbkt65]
#2724967
12/17/19 10:35 PM
12/17/19 10:35 PM
Posts: 2,678 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I don't really know what he is saying. If it's .020 over and it needs a bore job, 440 Source (and probably others) has .035 stroker kits.
2011 Drag Pak Challenger
[Re: rbkt65]
#2724984
12/17/19 11:28 PM
12/17/19 11:28 PM
Posts: 43,295 Bend,OR USA
Cab_Burge
If I was you I would have that block sonic tested by a good shop before making any choices on using it or not It is very possible it is useable but you won't know until it is tested If it will have less than .120 thick anywhere in the cylinder walls after boring and honing look for another, better block
[Re: Cab_Burge]
#2724999
12/18/19 12:13 AM
12/18/19 12:13 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
My 400 block (73 230 std web casting) is .040 over.... don’t understand what the problem is. “Only .020” from where he wants it”.... first: what does that mean??? Second: why would that stop him from going there?
Are you sure you’re understanding him properly?, or are you sure he’s understanding what you want to do?
[Re: rbkt65]
#2725185
12/18/19 06:39 PM
12/18/19 06:39 PM
Posts: 31,075 Oregon
AndyF
i revisited the machine shop and andy f is exactly correct in what he stated. so on to another block. thanks all and happy holidays. That is why they pay me the big bucks to answer questions on here.
[Re: AndyF]
#2725189
12/18/19 07:10 PM
12/18/19 07:10 PM
fast68plymouth
So. Burlington, Vt.
I guess I still don’t understand the problem exactly.
The common bore size for those blocks is 4.375. If it’s currently +.020 the bore is 4.363. .012 is not a problem to hone out at all, unless you’re using a hand held type of hone. Any power stroke hone would make short order of that job.
Now, if the wear at the top of the ring travel is already beyond 4.375, then you’d really want to sonic test the block first, and use a larger bore size(4.380 or 4.390). But then you’re likely looking at custom pistons as well.
[Re: rbkt65]
#2725190
12/18/19 07:13 PM
12/18/19 07:13 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
I'm curious as to why a machine shop wouldn't be able to bore a block out. I understand Andy said the machine, so I guess my question is what is the machines problem/ or lack of ability? rbkt65 if youd be interested in selling that block please contact me.
eBay-cdwmotorsports
[Re: fast68plymouth]
#2725200
12/18/19 08:03 PM
12/18/19 08:03 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Now, if the wear at the top of the ring travel is already beyond 4.375, then you’d really want to sonic test the block first, and use a larger bore size(4.380 or 4.390). But then you’re likely looking at custom pistons as well. My source kit came with 4.380 pistons
[Re: rbkt65]
#2725353
12/19/19 11:38 AM
12/19/19 11:38 AM
Cab_Burge
I've built a bunch of 400 block motors with 3.750 stroke up to 4.300 stroke crankshafts, all but the first one where sonic tested by me after having the first block crack the #1 cylinder wall on the camshaft side of the cylinder wall while breaking in the cam on a engine dyno it was right at .035 thick after prying apiece out of it while I having it bored out for a ductile iron sleeve That block was not salvable due to much core shift on the drivers side What I have found in the past on bore size is the lack of a good set of piston rings after you get above 4.380 bore size 4.440 bore size rings are available but not many stock blocks will be safe at that size My first pump gas 400 stroker motor (511 C.I.) I built for myself ended up with four ductile iron sleeves in it due to deck damage between the #4 and #6 cylinders due to a blown head gasket torching that out, #1 and #7 had to much pitting in them to clean up at 4.375 bore size so I had the shop sleeve all four at the same time due to not being able at that time to find another block in SO CA back in 2001 That motor made a bunch of power and took a lot of abuse by me on the track and street on pump gas, it had a set of ported big valve 906 heads with 9.25 to 1 compression ratio to start with and it made 612 HP at 5500 RPM and 644 Ft. Ls. at 4500 RPM with a low deck six pack. I ended up swapping heads several times and crankshaft stroke once to 4.300 stroke (517 C.I.) to make it make more power, it ended up with a set of Indy SR M.W. intake ports with a 400-3 intake and a 1050 CFM Holley Dominator, that combination made 727 HP at 7000 RPM and around 680 Ft . Lbs. of torque with 10,78 to 1 compression using Oregon 91 octane non ethanol pump swill. That combination ran a best of 9.993 at 134.+ MPH corked up with the air cleaner on in my old street Duster weighing 3450 Lbs. with me in it, it ended up being way faster than I expected Test, test and test some more, don't be afraid to try something different to make more power My current S/P bracket 400 cold weather block that I bought form AndyF on here ended up only needing being bored to 4.350 to straighten out the bore That motor has pushed my 1970 S/P chrome moly tube chassis Cuda (2750 lbs with me in it) (517 C.I.) to 5.50 at 120.+ MPH in the 1/8 mile and 8.886 at 150.+ MPH in the 1.4 mile so far IHTHs
[Re: Cab_Burge]
#2725607
12/20/19 12:25 PM
12/20/19 12:25 PM
fast68plymouth
So. Burlington, Vt.
I see rings listed for: 4.380, 4.385, 4.390, 4.395, 4.400
#2725609
12/20/19 12:29 PM
12/20/19 12:29 PM
Cab_Burge
That's good to know, which company?
