Re: Fuel atomization: Carb vs. EFI
[Re: Cab_Burge]
#2725363
12/19/19 12:01 PM
12/19/19 12:01 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
There's really no debate to be had on which technology atomises better. You've had at least two people who have worked in the industry say the same thing (Mr P Body and myself). Higher pressure gives better atomisation. EFI is ALWAYS higher pressure therefore, leaving the carb or injector, better atomisation, every time, period.
Per my original reply - what you do with it after that is getting a lot of good discussion here, but there's no uncertainty about which device atomises better. I am still in doubt about which system, EFI or a dual quad tunnel ram set up, is better for a all out drag race motor Hence NHRA Pro Stock not going faster now with EFI than they did with dual carbs on a tunnel ram intakes I remember several different mechanical fuel injector companies testing the location of the injectors heights in there all out race set ups for dirt and asphalt track roundy round all out race cars My understanding is that the higher up you can place the injector the more power you can make, downside is they are a little harder to dial in for street driving with the injector way up the intake. It would have been interesting to see what happened with pro stock if the EFI conversion didn't require the loss of the scoops and tunnel rams. Holley makes a 4500 bolt pattern throttle body that is 2500CFM, a pair of those on a tunnel ram would be fun.
68 Barracuda Formula S 340
[Re: Gavin]
#2725372
12/19/19 12:28 PM
12/19/19 12:28 PM
Thumperdart
State of confusion
If EFI is so much better(which I don't believe it is in every case)then why did Pro Stock slow down across the board. Plus there's some well known heads up racers I know that sold there's and went BACK to carbs and picked up LOTS of power......My opinion on the 2 places it shines, 1, on our daily drivers get to work stuff and 2, super high end high power(2000+hp)stuff but in between that carbs shine and I've been part of it personally...........
[Re: Thumperdart]
#2725390
12/19/19 02:22 PM
12/19/19 02:22 PM
Bad340fish
Tulsa OK
If EFI is so much better(which I don't believe it is in every case)then why did Pro Stock slow down across the board. Plus there's some well known heads up racers I know that sold there's and went BACK to carbs and picked up LOTS of power......My opinion on the 2 places it shines, 1, on our daily drivers get to work stuff and 2, super high end high power(2000+hp)stuff but in between that carbs shine and I've been part of it personally........... Pro stock didn't just swap to EFI, they also got a 10,500 RPM limit, lost the scoop, and run a spec throttle body and intake tube. Not to say that the carb still wouldn't make more power but I feel it would be MUCH closer or equal had they got to keep the tunnel rams.
[Re: Gavin]
#2725441
12/19/19 07:18 PM
12/19/19 07:18 PM
Posts: 117 Aus
hysteric
Aus
Per my original reply - what you do with it after that is getting a lot of good discussion here, but there's no uncertainty about which device atomises better. But does that mean that it produces a better homogenized mixture?
[Re: hysteric]
#2725443
12/19/19 07:38 PM
12/19/19 07:38 PM
Posts: 31,050 Oregon
AndyF
Per my original reply - what you do with it after that is getting a lot of good discussion here, but there's no uncertainty about which device atomises better. But does that mean that it produces a better homogenized mixture? Exactly. When I look down the throttle bores of a Sniper it drools big drops of fuel into the intake manifold just like a carb does. The injectors in a Sniper do not spray fuel into the intake which is what most people seem to be assuming.
[Re: AndyF]
#2725447
12/19/19 07:50 PM
12/19/19 07:50 PM
Posts: 117 Aus
hysteric
Aus
Can anyone please explain how a carb atomizes fuel better than fuel injection.
For the sake of my question both the carb and fuel injection are tuned properly. I don't think anyone on this thread knows the answer to that question. That is a very complicated technical question and nobody would be able to prove it one way or the other without a lab full of equipment. A carb works opposite of injection so the behavior is totally different. In a carb the low pressure area in the venturi sucks the fuel out of the bowl. The pressure differential in a carb is only 5 or 6 psi while an injector operates around 50 psi. The metering block in a carb adds air bubbles to the fuel which helps. There is no air bubble system in an injector. If someone really wants to know the answer to this question they would need to talk to an injector engineer at Bosch. My guess is that they know how to measure it and and could explain it. My understanding is that a 5 gas analyzer would tell you how the fractions are being converted. What happens to the flame front when the mixture isn't ideally homogenized? Just because you atomize fuel doesn't mean the mixture is ideal at the time of ignition. I'm no expert but maybe the question of atomization is just one part of the puzzle. Maybe a thorough reading of Ricardo's work might shed some light on the matter
[Re: AndyF]
#2725448
12/19/19 07:54 PM
12/19/19 07:54 PM
Posts: 117 Aus
hysteric
Aus
Per my original reply - what you do with it after that is getting a lot of good discussion here, but there's no uncertainty about which device atomises better. But does that mean that it produces a better homogenized mixture? Exactly. When I look down the throttle bores of a Sniper it drools big drops of fuel into the intake manifold just like a carb does. The injectors in a Sniper do not spray fuel into the intake which is what most people seem to be assuming. Would be interesting to make a clear manifold and actually see the differences in fuel delivery between a Holley a Carter TQ/Rochestor Qjet and a Sniper.
[Re: AndyF]
#2725453
12/19/19 08:05 PM
12/19/19 08:05 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
I still have some tuning to do, because self tuning EFI is more of a selling point & not a true reality, but the EFI HILBORN 8 Stack I have on my Street Strip car is AWESOME, Individual runners, so the low vacuum, drivabilty issues from a large duration cam are gone, cam is a hyd roller 255, 258 @ .050 & it idles like a stock 440 & drives just as smooth. a carb on a common plenum intake CANNOT do what this EFI set up does, also I can change runner length to tune for power @ different RPM's, as I said earlier I can run much leaner without lean misfires, that tells me better fuel atomization & Obviously better fuel distribution than my ported Indy SP intake. Will keep Y'all updated on my progress at the track.
[Re: Bad340fish]
#2725460
12/19/19 08:24 PM
12/19/19 08:24 PM
Posts: 4,457 Washington
madscientist
Washington
If EFI is so much better(which I don't believe it is in every case)then why did Pro Stock slow down across the board. Plus there's some well known heads up racers I know that sold there's and went BACK to carbs and picked up LOTS of power......My opinion on the 2 places it shines, 1, on our daily drivers get to work stuff and 2, super high end high power(2000+hp)stuff but in between that carbs shine and I've been part of it personally........... Pro stock didn't just swap to EFI, they also got a 10,500 RPM limit, lost the scoop, and run a spec throttle body and intake tube. Not to say that the carb still wouldn't make more power but I feel it would be MUCH closer or equal had they got to keep the tunnel rams. The RPM limit didn't hurt the GM architecture. The hood scoop was on of the MOST cried about pieces of a Pro Stock car ever. WJ sniveled about them for years and claimed a huge gain in MPH if the big "mail box" was gone from the car. EFI retarded Pro Stock in more than one way.
[Re: hysteric]
#2725530
12/20/19 02:05 AM
12/20/19 02:05 AM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Per my original reply - what you do with it after that is getting a lot of good discussion here, but there's no uncertainty about which device atomises better. But does that mean that it produces a better homogenized mixture? Exactly. When I look down the throttle bores of a Sniper it drools big drops of fuel into the intake manifold just like a carb does. The injectors in a Sniper do not spray fuel into the intake which is what most people seem to be assuming. Would be interesting to make a clear manifold and actually see the differences in fuel delivery between a Holley a Carter TQ/Rochestor Qjet and a Sniper. A buddy of mine in the R&D biz did that years ago. First thing he learned was that fuel staying in suspension in a wet manifold is basically a myth. There is a cloud of it directly under the carburetor and then 90% of it goes directly to the floor of the intake manifold. Kevin
[Re: BradH]
#2725552
12/20/19 09:01 AM
12/20/19 09:01 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I never heard of direct injection above the valve. Direct injection has always been in-cylinder nozzles at extremely high pressures. Port injection, as used on sprint car engines generally have the nozzles entering the port from the exhaust side of the head, straight into the bowl. Other than the clarification, I think you/ he is spot-on. The higher the rpm range, the farther away from the intake valve the injector should be. F1 engines live life way above 10,000 rpm. They have had injectors at great distances for years.
[Re: TRENDZ]
#2725566
12/20/19 09:45 AM
12/20/19 09:45 AM
BradH
Port injection, as used on sprint car engines generally have the nozzles entering the port from the exhaust side of the head, straight into the bowl. Yes, that's what I mean; I'm not familiar with all the correct terminology.
[Re: Bad340fish]
#2725723
12/20/19 08:38 PM
12/20/19 08:38 PM
Thumperdart
State of confusion
I remember they changed a few things but most interviews I saw it seemed the drivers/tuners preferred carbs and a forward scoop plus I'm sure singing the HEMI'S way up is missed as well...........I saw the spec sheet on Erica Enders carbs and it was quite eye opening..........
