I put a couple of 1/2 dowels in my lathe and turned them down.. took a couple of minutes or you can
just chuck up a couple of 1/2" bolts and run a file on them(simple and cheap)
Just adding to this old post for anyone who searches for this topic in the future.
If you are going with that approach, I can suggest starting with these Hillman axle bolts #882944.
After cutting the hex head off, there is about 1.312" length left.
The ones I bought from a local hardware store were 0.4965-0.4970 dia. So I sanded the block end to my satisfaction.
A little bevel on the end helps get them started.
